ejolson
No Red LED [solved]
Wed Sep 12, 2018 4:29 pm
I have a Pi 2B and the red LED seems dark now. If remember correctly it used to light up. The system otherwise seems functional.
So what does it being dark mean? Is this a low voltage indicator, a burned out light, software changes or something else?
If you have a 2B running the latest Raspbian, is the red LED illuminated while the system is powered?
mahjongg
Re: No Red LED
Wed Sep 12, 2018 4:41 pm
A 2B has the undervoltage protection circuit, which turns the power LED off when the input voltage drops under 4.65V, but you should also get a lightening icon when that happens.
In principle software can turn the LED off, if the GPIO that senses an undervoltage is switched to an output, and outputs a low, that will turn the FET that drives the LED off.
Otherwise I would not know why the LED would be dim, except when the 3V3 supply drops to a far lower voltage, but then the PI would also stop working.
often the power (micro-USB) cable is the source of low input voltages.
allfox
Re: No Red LED
Wed Sep 12, 2018 4:43 pm
My BCM2836 Pi 2B's red LED is illuminating here.
ejolson
Re: No Red LED
Wed Sep 12, 2018 4:55 pm
There is no monitor connected so I'm not sure about the lightning icon. Thanks, I will swap power supplies and report back.
W. H. Heydt
Re: No Red LED
Wed Sep 12, 2018 5:22 pm
I was going to point out that there are two--rather different--versions of the Pi2B.
ejolson
Re: No Red LED
Wed Sep 12, 2018 9:21 pm
This is one of the original Pi 2B computers. Seems a different power supply did the trick. The red light came on and has remained lit for a couple hours now. I'll mark the topic as solved. Thanks for the help.
