Raspberry Pi zero w Chromium problem
Posted: Mon Jun 25, 2018 4:20 pm
by johno50
I just bought a new Pi zero w and loaded Raspbian using the noobs install. The wifi is connected and seems to be working fine. I updated and upgraded the system as instructed. My problems is when trying to open the Chromium browser it, will not run.
The hourglass comes on for a few seconds and then just goes away. I tried it several times and rebooted etc. This is a genuine Raspberry pi product as I bought it from one of your recommended dealers.
Re: Raspberry Pi zero w Chromium problem
Posted: Tue Jun 26, 2018 8:17 am
by lmarmisa
Open a terminal and type:
chromium-browser
If the browser does not start, you will see some type of error message.
Posted: Tue Jun 26, 2018 8:32 am
by LTolledo
Please read contents of the attached link, currently being discussed there
viewtopic.php?f=66&t=216349
Posted: Tue Jun 26, 2018 12:13 pm
by johno50
From the discussion, this problem is way to deep for me. What browser would be the most likely to work on my new Pi Zero W ?
Posted: Tue Jun 26, 2018 9:18 pm
by LTolledo
If your havent installed a lot of apps/packages requiring detailed setups on your new RPiZW then I suggest
1. re-flashing the microSD card with the latest Raspbian Stretch with Desktop image
2. I recommend not using NOOBS/PINN, use Etcher to flash image (or Apple Pi Baker for Mac) to microSD
3. after flashing, run update and upgrade. DONT/NEVER USE dist-upgrade on your RPiZW (for now)
the chromium version should remain at:
Version 60.0.3112.89 (Developer Build) Built on Ubuntu 14.04, running on Raspbian 9.1 (32-bit)
and you should be able to use it
lets wait awhile until a new and reliable fix is available....
Posted: Tue Jun 26, 2018 10:33 pm
by W. H. Heydt
I'd be interested in seeing your reasons for avoiding dist-upgrade.
And I would add a 4th step...run "apt-get clean".
Posted: Wed Jun 27, 2018 7:23 am
by mikerr
As it turned out the problem was rpi-chromium-mods version 20180605 which was only installed via dist-upgrade.
A fixed version is now available, and will come in via a standard upgrade :
 sudo apt-get update && sudo apt-get upgrade
Posted: Wed Jun 27, 2018 10:26 am
by fanoush
Standard upgrade is dist-upgrade ;-)
Plain 'upgrade' is for advanced use, not the one to use if you want things to 'just work'.
see also answer 9.1.2 in https://www.debian.org/doc/manuals/debi ... te.en.html
Posted: Wed Jun 27, 2018 11:03 am
by LTolledo
well apparently a fix was issued
I tried it this morning (before going to work)
it worked!
I can use Chromium again on my RPiZW (well all Broadcom BCM2835 RPis).
just do sudo apt-get update and sudo apt-get upgrade to get the fix
Posted: Fri Jun 29, 2018 7:06 pm
by johno50
I am pleased, the update fixed the browser problem. This issue is solved for me.
