chuckf201
getting assigned value from 'system call' to an HTML button value
Sat Jun 02, 2018 6:59 pm
Trying to assign a variable from PHP 'system' command to a button value based upon a pin value ( 0 or 1).
My code looks like this:
$closepin = system("gpio -g read 27"); [displays a '1' or '0' depending on mag switch open or closed.] it's ok
//************TEST********************
if ($closepin = 1)
$closepin= "open";
if ($closepin = 0)
$closepin= "closed";
echo fprintf("A String " , $clospin); [displays nothing]
echo $closepin; [displays '0']
Where is my error? I eventually want to change a button label from 'open' to 'close'
bob_binz
Re: getting assigned value from 'system call' to an HTML button value
Sun Jun 03, 2018 7:06 am
Php tests for equality needs doeble equals operator, e.g.
if ($closepin == 1)
BBz]
Sun Jun 03, 2018 7:20 am
Not surprising. There are at least four errors in that statement (assuming they aren't just copy/paste tyops).
echo fprintf(....). What?
echo is used to display stuff. The fprintf after it is pointless.
echo "My name is rpdom\n";
fprintf is used to write formatted things to a file.
fprintf($file, "My name is %s\n", "rpdom");
$clospin isn't defined. It's $closepin.
If you intended to use printf instead of fprintf, you haven't put any format command in the string to make it output the value.
The line I'd use would be
printf("A String %s\n" , $closepin);
The %s will be substituted with the contents of $closepin and the "\n" on the end will force a new line
chuckf201
Sun Jun 03, 2018 4:05 pm
Thanks to you all. BBj] double equal worked.
Also, understanding printf was helpful. thanks.
chuckf201
Sun Jun 03, 2018 4:21 pm
Works great.
Now, can I assign $closepin to a button label in w3-btn ?
umair123
Mon Apr 08, 2019 10:53 am
Because of all of you. BBj] twofold equivalent worked.
Additionally, understanding printf was useful. much obliged.
https://malikexpress.com/Flight/Airblue
Eastern highway
Sat May 04, 2019 7:35 am
Having the same issue from somedays BB], Trying this out and i guess its kind of working for me.
Now, can is assign button labels in w3-btn programme ? seems its the good way for this to be worked.
https://easternhighway.com
rankray
Thu May 30, 2019 6:28 pm
This kinda worked for me. I didnt understand though but right now the problem is solved. Thanks, great tip. Much appreciated.
https://rankray.com
