Well known I2C addresses
Posted: Thu Mar 22, 2018 1:53 am
by MonkeyFist
Is there a list of well known I2C addresses? I have a pi camera, pi display and a PiModules PIco UPS. I think I have a conflict. I know the PiModule address range, but cannot find the others.
Re: Well known I2C addresses
Posted: Thu Mar 22, 2018 9:46 am
by 6by9
The camera and display are on i2c-0 and addressed by the GPU firmware (not the Linux kernel). Assuming the Pico UPS is connected to i2c-1 (it appears to be from "i2cdetect -y 1" in the docs), then there should be no conflicts at all.
And no, there isn't really a list of I2C addresses as many devices can be reconfigured to alternate addresses. For info, the V1 camera is 0x36, the V2 is on 0x10 and 0x64, whilst the display is on 0x38 and 0x45.
Posted: Thu Mar 22, 2018 1:41 pm
by MonkeyFist
Thanks, much appreciated.
Something I am doing is causing an interference. I have to do some troubleshooting.
I2cdetect reports zeroes at all ports when I plug in the camera (rev 1.3). Cabling or other problem.
Thanks!
Posted: Thu Mar 22, 2018 4:53 pm
by 6by9
If you've got the display connected as well, you do NOT need the SCL and SDA lines connected from GPIOs 2&3 to the display board except on the original model A&B. If you do then you will have bridged the two I2C busses and that will cause issues. Annoyingly several 3rd party instructions for the display still tell you to connect them.
Posted: Thu Mar 22, 2018 5:13 pm
by MonkeyFist
Ah.... Could be the problem. Thanks for the info - I'll check as soon as I get back to the lab. I really appreciate the help.
Mike
Posted: Thu Mar 22, 2018 7:58 pm
by GordonTGopher
https://pinout.xyz has the I2C addresses for many add on boards.
Gordon
Posted: Thu Mar 22, 2018 8:10 pm
by Douglas6
Adafruit has fairly extensive list of general I2c addresses: https://learn.adafruit.com/i2c-addresses/the-list
