hatrabbit
What is commanding this .py to run?
Tue Feb 20, 2018 3:46 am
I wanted a python scrip to run at startup so I edited '/etc/rc.local' to include the line:
python /home/pi/program.py &
It worked and the program was running, but when I entered 'ps -aef | grep python' in Terminal I saw that there were two instances of program.py running, one at the user level and one at root. I went back and edited '/etc/rc.local', removing the line I had added. Now the program starts every time my Pi boots, but only at the user level, but there's nothing in rc.local to tell it to start. Where is the command to run coming from?
topguy
Re: What is commanding this .py to run?
Tue Feb 20, 2018 11:37 am
You have added it somewhere else too, but forgotten it.
Check your ".bashrc" file in "/home/pi" for example.
n67
Tue Feb 20, 2018 12:26 pm
As I recommended in a similar thread posted about a week ago, the way to fix this is to delete or rename (same thing for our purposes) the script, then reboot, and watch carefully for error messages.
You should be able to figure out what part of the system is trying to run it, but failing to do so.
BTW, it might be in cron (also known on the forum as "crontab -e"), in which case you will have to check the syslog (and similar) file(s) in /var/log.
Also, another thing to try - before you delete/rename the file, that is, while it is still running, figure out its pid (via the ps command that you've already mastered) and then do:
less /proc/<pid>/status
This will tell you (among other things) the parent process ID of the Python script - and this may help determine who started it.
"L'enfer, c'est les autres"
Epmu Sn!
topguy
Tue Feb 20, 2018 1:52 pm
"ps -ef" also print process pid and pid of parent process.
hatrabbit
Tue Feb 20, 2018 4:05 pm
Thanks for the clues. The parent process was the key, I found it in ~/.config/lxsession/LXDE-xo.
rados-dataplicity
Contact: Website Facebook Twitter
Wed Feb 21, 2018 10:05 am
Also, the reason it's running as root from rc.local is because rc.local file is executed from systemd service which runs as root
I tinker around with Raspberry Pis daily and make sure that people can easily access theirs remotely.
Community outreach @ dataplicity.com
bensimmo
Wed Feb 21, 2018 12:16 pm
I believe if you use
su pi -c "python3 prog.py" &
it launches as the Pi user.
Correct me if I am wrong though.
