Re: No Wifi connection to Pi Zero W after Raspbian update
Fri Feb 23, 2018 11:53 am
Thank you for the very comprehensive report. One thing, is this a Ipv4 or Ipv6 network?
Also, if you following the IP blacklisting here
viewtopic.php?f=63&t=204882&start=50#p1275508
Does that help?
carriba
Contact: ICQ
Fri Feb 23, 2018 12:19 pm
Does that help?
It is an IPv4 network, and disabling IPv6 settings on the RPi 0 W device did not help me further as described in one of my previous post under viewtopic.php?f=63&t=204882&start=25#p1271196
I keep doing some further tests as console access seems to be required to further troubleshoot with the RPi 0 W device on this issue...
The challenge I'm having right now is that whenever the console port gets flooded by an endless(?) stream of messages originating from the RPi 0 W device, my PC is ending up with a fatal "Blue Screen of Death"; have to force switch off my PC and then manually power it up again. And, unfortunately, I cannot capture all this debug output into a file.
carriba
Contact: ICQ
Fri Feb 23, 2018 3:11 pm
Plagued with the situation that the flood of console messages is causing my PC to die in a Blue Screen of Death, I have installed a different terminal program that allows recording all the messages stream from the console.
I have installed the SmarTTY program, and connected again to the console port of my RPi 0 W device. I kept the configuration of my network to be the same: IPv4 network, though the Wifi AP can serve both, IPv4 and IPv6 addresses. The RPi 0 W devices is left intact with its original configuration supporting IPv4 and IPv6. The Wifi AP does not advertise its SSID (hidden network); see my previous posts on this.
I powered up again the RPi 0 W device, and can observe the usual console messages when booting up. Logged in again, and even not 3 to 5 seconds passed with no activity from my side on the keyboard, the console gets flooded with endless messages until the console stays frozen. No reaction on the console, when hitting the keyboard. My PC still alive though.
Thus, in several posts, I'm posting here all the console messages that I've been able to capture. As the messages output on the console is very huge, I'm posting them in several posts based on functional parts that I have been able to identify when scrolling through the entire console output.
The 1st part of the console messages:
Message from syslogd@raspberrypi at Feb 22 18:17:17 ...
 kernel:[  671.645828] Internal error: Oops -
[  672.062848] Unable to handle kernel paging request at virtual address fffffff0
[  672.070489] pgd = c0004000
[  672.073235] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  672.079617] Internal error: Oops: 37 [#2] ARM
[  672.084037] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fix
ed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  672.100877] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  672.108910] Hardware name: BCM2835
[  672.112370] task: d876df60 task.stack: d9154000
[  672.116987] PC is at kthread_data+0x18/0x20
[  672.121238] LR is at wq_worker_sleeping+0x18/0xc4
[  672.126012] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000093
[  672.126012] sp : d9155a70  ip : d9155a80  fp : d9155a7c
[  672.137659] r10: c00485c0  r9 : 68050093  r8 : c08b17f0
[  672.142958] r7 : d876e2ac  r6 : 00000000  r5 : d9155814  r4 : d876df60
[  672.149579] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  672.156202] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  672.163531] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  672.169360] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  672.175894] Stack: (0xd9155a70 to 0xd9156000)
[  672.180317] 5a60:                                     d9155a8c d9155a80 c0039b60 c003f494
[  672.188620] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  672.196922] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  672.205224] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  672.213526] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  672.221826] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  672.230128] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  672.238429] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  672.246732] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  672.255033] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  672.263335] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  672.271636] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  672.279937] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  672.288238] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  672.296540] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  672.304841] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  672.313143] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  672.321444] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  672.329746] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  672.338047] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  672.346349] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  672.354650] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  672.362951] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  672.371253] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  672.379555] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  672.387857] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  672.396159] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  672.404460] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  672.412762] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  672.421064] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  672.429364] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  672.437666] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  672.445967] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  672.454269] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  672.462570] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  672.470872] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  672.479173] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  672.487475] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  672.495776] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  672.504077] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  672.512378] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  672.520678] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  672.528980] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  672.537280] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  672.545580] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  672.553901] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  672.562136] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  672.570361] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  672.577884] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  672.585326] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  672.591961] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  672.599036] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  672.607170] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  672.615203] Exception stack(0xd9155c70 to 0xd9155cb8)
[  672.620330] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  672.628632] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  672.636933] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  672.643667] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  672.652153] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  672.660728] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  672.669743] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  672.678315] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  672.686069] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  672.695644] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  672.705633] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  672.713858] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  672.721293] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  672.728630] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  672.734819] ---[ end trace d9489205bcc517a6 ]---
carriba
Contact: ICQ
Fri Feb 23, 2018 3:13 pm
The 2nd part of the console messages:
[  672.739503] Fixing recursive fault but reboot is needed!
[  672.744919] Unable to handle kernel paging request at virtual address fffffff0
[  672.752249] pgd = c0004000
[  672.754991] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  672.761365] Internal error: Oops: 37 [#3] ARM
[  672.765785] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fix
[  672.782619] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  672.790654] Hardware name: BCM2835
[  672.794113] task: d876df60 task.stack: d9154000
[  672.798719] PC is at kthread_data+0x18/0x20
[  672.802968] LR is at wq_worker_sleeping+0x18/0xc4
[  672.807743] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  672.807743] sp : d91557b8  ip : d91557c8  fp : d91557c4
[  672.819390] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  672.824689] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  672.831309] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  672.837931] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  672.845258] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  672.851086] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  672.857620] Stack: (0xd91557b8 to 0xd9156000)
[  672.862041] 57a0:                                                       d91557d4 d91557c8
[  672.870343] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  672.878644] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  672.886946] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  672.895247] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  672.903550] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  672.911851] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  672.920152] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  672.928453] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  672.936754] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  672.945055] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  672.953357] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  672.961657] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  672.969959] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  672.978260] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  672.986561] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  672.994861] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  673.003163] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  673.011464] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  673.019764] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  673.028066] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  673.036367] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  673.044669] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  673.052971] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  673.061272] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  673.069574] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  673.077875] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  673.086176] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  673.094477] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  673.102780] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  673.111082] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  673.119383] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  673.127685] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  673.135984] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  673.144286] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  673.152587] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  673.160888] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  673.169190] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  673.177489] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  673.185789] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  673.194090] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  673.202390] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  673.210691] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  673.218993] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  673.227294] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  673.235596] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  673.243897] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  673.252198] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  673.260500] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  673.268802] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  673.277102] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  673.285403] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  673.293704] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  673.302006] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  673.310307] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  673.318608] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  673.326909] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  673.335210] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  673.343511] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  673.351811] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  673.360112] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  673.368413] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  673.376714] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  673.385015] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  673.393316] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  673.401616] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  673.409916] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  673.418234] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  673.426467] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  673.434689] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  673.441858] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  673.448942] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  673.455577] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  673.463624] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  673.472636] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  673.480413] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  673.487917] Exception stack(0xd9155a20 to 0xd9155a68)
[  673.493046] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  673.501349] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  673.509644] 5a60: 20000093 ffffffff
[  673.513196] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  673.520711] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  673.528934] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  673.537152] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  673.544665] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  673.552095] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  673.558731] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  673.565805] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  673.573936] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  673.581969] Exception stack(0xd9155c70 to 0xd9155cb8)
[  673.587095] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  673.595397] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  673.603696] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  673.610426] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  673.618914] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  673.627488] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  673.636503] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  673.645075] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  673.652744] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  673.662317] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  673.672306] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  673.680530] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  673.687963] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  673.695298] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  673.701483] ---[ end trace d9489205bcc517a7 ]---
The 3rd part of the console messages:
[  673.706167] Fixing recursive fault but reboot is needed!
[  673.711582] Unable to handle kernel paging request at virtual address fffffff0
[  673.718912] pgd = c0004000
[  673.721655] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  673.728030] Internal error: Oops: 37 [#4] ARM
[  673.732447] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  673.749280] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  673.757314] Hardware name: BCM2835
[  673.760772] task: d876df60 task.stack: d9154000
[  673.765378] PC is at kthread_data+0x18/0x20
[  673.769627] LR is at wq_worker_sleeping+0x18/0xc4
[  673.774401] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  673.774401] sp : d9155500  ip : d9155510  fp : d915550c
[  673.786048] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  673.791347] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  673.797968] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  673.804590] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  673.811917] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  673.817746] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  673.824279] Stack: (0xd9155500 to 0xd9156000)
[  673.828704] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  673.837005] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  673.845306] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  673.853608] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  673.861910] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  673.870211] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  673.878512] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  673.886814] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  673.895116] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  673.903417] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  673.911719] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  673.920020] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  673.928321] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  673.936623] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  673.944924] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  673.953226] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  673.961528] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  673.969828] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  673.978129] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  673.986430] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  673.994732] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  674.003033] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  674.011334] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  674.019634] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  674.027935] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  674.036235] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  674.044536] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  674.052836] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  674.061137] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  674.069437] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  674.077739] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  674.086039] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  674.094340] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  674.102641] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  674.110942] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  674.119244] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  674.127545] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  674.135845] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  674.144146] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  674.152447] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  674.160749] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  674.169050] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  674.177350] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  674.185652] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  674.193953] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  674.202254] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  674.210555] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  674.218855] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  674.227157] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  674.235457] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  674.243758] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  674.252059] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  674.260360] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  674.268662] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  674.276962] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  674.285263] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  674.293565] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  674.301867] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  674.310168] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  674.318469] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  674.326771] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  674.335072] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  674.343372] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  674.351673] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  674.359974] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  674.368275] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  674.376576] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  674.384877] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  674.393177] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  674.401478] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  674.409780] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  674.418081] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  674.426383] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  674.434684] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  674.442986] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  674.451286] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  674.459588] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  674.467889] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  674.476191] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  674.484493] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  674.492794] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  674.501094] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  674.509395] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  674.517697] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  674.525997] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  674.534298] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  674.542599] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  674.550899] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  674.559218] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  674.567450] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  674.575671] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  674.582838] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  674.589921] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  674.596556] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  674.604602] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  674.613614] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  674.621390] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  674.628893] Exception stack(0xd9155768 to 0xd91557b0)
[  674.634021] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  674.642323] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  674.650622] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  674.655759] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  674.663274] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  674.671497] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  674.679716] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  674.686879] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  674.693957] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  674.700591] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  674.708634] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  674.717646] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  674.725421] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  674.732926] Exception stack(0xd9155a20 to 0xd9155a68)
[  674.738055] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  674.746357] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  674.754654] 5a60: 20000093 ffffffff
[  674.758204] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  674.765719] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  674.773942] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  674.782161] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  674.789676] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  674.797105] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  674.803737] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  674.810811] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  674.818941] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  674.826974] Exception stack(0xd9155c70 to 0xd9155cb8)
[  674.832101] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  674.840403] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  674.848703] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  674.855434] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  674.863921] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  674.872496] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  674.881511] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  674.890083] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  674.897761] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  674.907335] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  674.917324] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  674.925549] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  674.932982] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  674.940317] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  674.946503] ---[ end trace d9489205bcc517a8 ]---
carriba
Contact: ICQ
Fri Feb 23, 2018 3:15 pm
The 4th part of the console messages:
[  674.951186] Fixing recursive fault but reboot is needed!
[  674.956601] Unable to handle kernel paging request at virtual address fffffff0
[  674.963931] pgd = c0004000
[  674.966674] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  674.973051] Internal error: Oops: 37 [#5] ARM
[  674.977469] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  674.994298] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  675.002330] Hardware name: BCM2835
[  675.005790] task: d876df60 task.stack: d9154000
[  675.010398] PC is at kthread_data+0x18/0x20
[  675.014647] LR is at wq_worker_sleeping+0x18/0xc4
[  675.019422] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  675.019422] sp : d9155248  ip : d9155258  fp : d9155254
[  675.031069] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  675.036368] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  675.042989] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  675.049611] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  675.056938] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  675.062767] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  675.069300] Stack: (0xd9155248 to 0xd9156000)
[  675.073724] 5240:                   d9155264 d9155258 c0039b60 c003f494 d91552b4 d9155268
[  675.082026] 5260: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  675.090326] 5280: d91552a4 d9155290 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  675.098626] 52a0: 60000193 c003f4a2 d91552cc d91552b8 c05d1ca4 c05d1690 d876df60 d876df60
[  675.106927] 52c0: d915530c d91552d0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  675.115228] 52e0: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  675.123528] 5300: d915538c d9155310 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  675.131830] 5320: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  675.140131] 5340: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  675.148432] 5360: c071d0cc fffffff0 00000037 d91554b0 00000000 00000000 d9154000 c05d1ca4
[  675.156733] 5380: d91553a4 d9155390 c001db84 c0013ca0 d91554b0 fffffff0 d91553fc d91553a8
[  675.165034] 53a0: c05d5fe0 c001db2c d91553cc d91553b8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  675.173335] 53c0: d91553ec d91553d0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  675.181637] 53e0: fffffff0 d91554b0 d9154000 c05d1ca4 d91554ac d9155400 c0009204 c05d5db0
[  675.189937] 5400: 000002a1 000ac677 c092c1ac c0922294 00000000 c0922294 00000001 c005b3e8
[  675.198238] 5420: d915544c d9155430 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  675.206539] 5440: 00000000 00009b10 d9155464 c004b5fc d876df90 c08b1820 399e1b58 c004b668
[  675.214841] 5460: d876df90 c08b1820 d91554ac d9155478 c004b668 c00564a0 d91554b4 d9155488
[  675.223143] 5480: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d91554e4 c08b17f0
[  675.231444] 54a0: d915550c d91554b0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  675.239745] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  675.248047] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  675.256348] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  675.264650] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  675.272951] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  675.281253] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  675.289554] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  675.297856] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  675.306157] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  675.314458] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  675.322760] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  675.331061] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  675.339362] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  675.347664] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  675.355966] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  675.364267] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  675.372568] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  675.380870] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  675.389171] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  675.397471] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  675.405773] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  675.414073] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  675.422374] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  675.430676] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  675.438978] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  675.447278] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  675.455579] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  675.463881] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  675.472182] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  675.480483] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  675.488785] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  675.497086] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  675.505386] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  675.513686] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  675.521987] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  675.530289] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  675.538591] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  675.546891] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  675.555192] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  675.563493] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  675.571795] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  675.580096] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  675.588397] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  675.596698] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  675.605000] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  675.613302] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  675.621603] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  675.629904] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  675.638205] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  675.646506] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  675.654807] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  675.663108] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  675.671409] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  675.679711] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  675.688013] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  675.696313] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  675.704614] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  675.712915] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  675.721216] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  675.729517] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  675.737819] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  675.746121] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  675.754422] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  675.762724] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  675.771025] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  675.779327] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  675.787628] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  675.795929] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  675.804230] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  675.812531] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  675.820833] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  675.829134] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  675.837435] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  675.845736] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  675.854037] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  675.862338] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  675.870639] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  675.878940] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  675.887241] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  675.895542] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  675.903843] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  675.912145] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  675.920446] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  675.928747] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  675.937048] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  675.945350] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  675.953651] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  675.961952] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  675.970252] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  675.978552] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  675.986871] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  675.995104] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  676.003326] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  676.010493] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  676.017577] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  676.024212] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  676.032259] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  676.041270] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  676.049047] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  676.056551] Exception stack(0xd91554b0 to 0xd91554f8)
[  676.061678] 54a0:                                     d876df60 d876df60 00000000 00000000
[  676.069979] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  676.078279] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff
[  676.085002] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  676.092516] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  676.100739] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  676.108959] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  676.116123] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  676.123202] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  676.129837] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  676.137880] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  676.146892] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  676.154670] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  676.162174] Exception stack(0xd9155768 to 0xd91557b0)
[  676.167302] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  676.175605] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  676.183903] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  676.189039] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  676.196554] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  676.204776] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  676.212995] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  676.220158] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  676.227236] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  676.233869] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  676.241910] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  676.250922] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  676.258699] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  676.266202] Exception stack(0xd9155a20 to 0xd9155a68)
[  676.271332] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  676.279634] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  676.287931] 5a60: 20000093 ffffffff
[  676.291480] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  676.298995] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  676.307217] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  676.315437] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  676.322952] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  676.330381] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  676.337016] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  676.344090] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  676.352222] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  676.360256] Exception stack(0xd9155c70 to 0xd9155cb8)
[  676.365382] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  676.373684] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  676.381984] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  676.388715] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  676.397203] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  676.405779] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  676.414793] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  676.423364] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  676.431035] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  676.440608] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  676.450596] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  676.458819] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  676.466252] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  676.473586] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  676.479773] ---[ end trace d9489205bcc517a9 ]---
The 5th part of the console messages:
[  676.484457] Fixing recursive fault but reboot is needed!
[  676.489870] Unable to handle kernel paging request at virtual address fffffff0
[  676.497201] pgd = c0004000
[  676.499944] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  676.506319] Internal error: Oops: 37 [#6] ARM
[  676.510739] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  676.527569] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  676.535602] Hardware name: BCM2835
[  676.539061] task: d876df60 task.stack: d9154000
[  676.543666] PC is at kthread_data+0x18/0x20
[  676.547912] LR is at wq_worker_sleeping+0x18/0xc4
[  676.552687] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  676.552687] sp : d9154f90  ip : d9154fa0  fp : d9154f9c
[  676.564333] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  676.569632] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  676.576253] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  676.582876] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  676.590202] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  676.596031] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  676.602565] Stack: (0xd9154f90 to 0xd9156000)
[  676.606985] 4f80:                                     d9154fac d9154fa0 c0039b60 c003f494
[  676.615287] 4fa0: d9154ffc d9154fb0 c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001
[  676.623588] 4fc0: 60000193 c003f4a2 d9154fec d9154fd8 c005cd50 d9154000 0000000b c08abfc0
[  676.631890] 4fe0: 0000000b 00000001 60000193 c003f4a2 d9155014 d9155000 c05d1ca4 c05d1690
[  676.640192] 5000: d876df60 d876df60 d9155054 d9155018 c002503c c05d1c60 00000006 c091f104
[  676.648493] 5020: 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0 0000000b 00000001
[  676.656795] 5040: 60000193 c003f4a2 d91550d4 d9155058 c0013e18 c0024858 d9154188 0000000b
[  676.665096] 5060: d9154000 bf000000 00000008 00000000 6505cd50 62633432 20343030 64323565
[  676.673397] 5080: 34303065 62386520 30303464 35652030 33333039 28203032 33313565 30313030
[  676.681699] 50a0: c0002029 c00e4690 c071d0cc fffffff0 00000037 d91551f8 00000000 00000000
[  676.690001] 50c0: d9154000 c05d1ca4 d91550ec d91550d8 c001db84 c0013ca0 d91551f8 fffffff0
[  676.698304] 50e0: d9155144 d91550f0 c05d5fe0 c001db2c d9155114 d9155100 c03a23f0 c03a1b1c
[  676.706606] 5100: c09222d0 c03a2194 d9155134 d9155118 c03a2194 c09abbb8 60000193 c08ac6d4
[  676.714907] 5120: 00000037 c05d5da4 fffffff0 d91551f8 d9154000 c05d1ca4 d91551f4 d9155148
[  676.723209] 5140: c0009204 c05d5db0 000002a2 000e8392 c092f978 c0922294 00000000 c0922294
[  676.731511] 5160: 00000001 c005b3e8 d9155194 d9155178 c005a758 c08f9304 0000003c c09426cc
[  676.739812] 5180: 00000000 c0921d80 00000000 0000d2dc d91551ac c004b5fc d876df90 c08b1820
[  676.748113] 51a0: 4a357f60 c004b668 d876df90 c08b1820 d91551f4 d91551c0 c004b668 c00564a0
[  676.756415] 51c0: d91551fc d91551d0 c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff
[  676.764717] 51e0: d915522c c08b17f0 d9155254 d91551f8 c05d56d4 c00091cc d876df60 d876df60
[  676.773018] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  676.781320] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  676.789622] 5240: 00000002 bf000000 d9155264 d9155258 c0039b60 c003f494 d91552b4 d9155268
[  676.797924] 5260: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  676.806226] 5280: d91552a4 d9155290 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  676.814527] 52a0: 60000193 c003f4a2 d91552cc d91552b8 c05d1ca4 c05d1690 d876df60 d876df60
[  676.822829] 52c0: d915530c d91552d0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  676.831130] 52e0: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  676.839431] 5300: d915538c d9155310 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  676.847732] 5320: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  676.856034] 5340: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  676.864336] 5360: c071d0cc fffffff0 00000037 d91554b0 00000000 00000000 d9154000 c05d1ca4
[  676.872638] 5380: d91553a4 d9155390 c001db84 c0013ca0 d91554b0 fffffff0 d91553fc d91553a8
[  676.880939] 53a0: c05d5fe0 c001db2c d91553cc d91553b8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  676.889241] 53c0: d91553ec d91553d0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  676.897541] 53e0: fffffff0 d91554b0 d9154000 c05d1ca4 d91554ac d9155400 c0009204 c05d5db0
[  676.905842] 5400: 000002a1 000ac677 c092c1ac c0922294 00000000 c0922294 00000001 c005b3e8
[  676.914143] 5420: d915544c d9155430 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  676.922444] 5440: 00000000 00009b10 d9155464 c004b5fc d876df90 c08b1820 399e1b58 c004b668
[  676.930745] 5460: d876df90 c08b1820 d91554ac d9155478 c004b668 c00564a0 d91554b4 d9155488
[  676.939047] 5480: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d91554e4 c08b17f0
[  676.947349] 54a0: d915550c d91554b0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  676.955651] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  676.963952] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  676.972254] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  676.980555] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  676.988857] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  676.997158] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  677.005460] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  677.013760] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  677.022062] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  677.030364] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  677.038665] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  677.046967] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  677.055269] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  677.063571] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  677.071873] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  677.080174] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  677.088475] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  677.096777] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  677.105079] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  677.113381] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  677.121683] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  677.129985] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  677.138286] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  677.146588] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  677.154890] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  677.163192] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  677.171494] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  677.179796] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  677.188097] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  677.196399] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  677.204699] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  677.213001] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  677.221303] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  677.229602] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  677.237904] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  677.246206] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  677.254506] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  677.262808] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  677.271109] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  677.279411] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  677.287712] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  677.296014] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  677.304316] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  677.312618] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  677.320920] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  677.329220] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  677.337521] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  677.345823] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  677.354125] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  677.362427] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  677.370728] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  677.379030] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  677.387332] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  677.395635] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  677.403937] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  677.412239] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  677.420540] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  677.428841] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  677.437143] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  677.445445] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  677.453747] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  677.462048] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  677.470350] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  677.478652] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  677.486954] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  677.495256] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  677.503557] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  677.511859] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  677.520161] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  677.528463] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  677.536765] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  677.545067] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  677.553368] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  677.561669] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  677.569971] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  677.578272] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  677.586574] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  677.594875] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  677.603176] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  677.611478] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  677.619779] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  677.628079] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  677.636381] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  677.644682] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  677.652984] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  677.661284] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  677.669585] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  677.677886] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  677.686187] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  677.694485] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  677.702805] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  677.711038] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  677.719260] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  677.726427] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  677.733511] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  677.740148] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  677.748196] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  677.757209] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  677.764986] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  677.772489] Exception stack(0xd91551f8 to 0xd9155240)
[  677.777614] 51e0:                                                       d876df60 d876df60
[  677.785916] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  677.794217] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  677.802527] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  677.810044] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  677.818267] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  677.826487] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  677.833650] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  677.840729] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  677.847364] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  677.855407] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  677.864417] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  677.872193] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  677.879697] Exception stack(0xd91554b0 to 0xd91554f8)
[  677.884824] 54a0:                                     d876df60 d876df60 00000000 00000000
[  677.893126] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  677.901424] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff
[  677.908147] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  677.915661] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  677.923884] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  677.932104] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  677.939268] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  677.946347] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  677.952983] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  677.961025] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  677.970035] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  677.977812] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  677.985317] Exception stack(0xd9155768 to 0xd91557b0)
[  677.990444] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  677.998747] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  678.007044] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  678.012181] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  678.019698] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  678.027920] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  678.036142] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  678.043304] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  678.050383] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  678.057016] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  678.065059] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  678.074069] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  678.081845] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  678.089349] Exception stack(0xd9155a20 to 0xd9155a68)
[  678.094478] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  678.102780] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  678.111076] 5a60: 20000093 ffffffff
[  678.114626] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  678.122140] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  678.130363] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  678.138582] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  678.146097] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  678.153528] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  678.160163] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  678.167237] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  678.175369] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  678.183402] Exception stack(0xd9155c70 to 0xd9155cb8)
[  678.188528] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  678.196831] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  678.205131] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  678.211864] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  678.220351] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  678.228925] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  678.237939] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  678.246511] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  678.254195] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  678.263769] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  678.273759] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  678.281983] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  678.289415] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  678.296750] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  678.302937] ---[ end trace d9489205bcc517aa ]---
carriba
Contact: ICQ
Re: No Wifi connection to Pi Zero W after Raspbian update
Fri Feb 23, 2018 3:20 pm
The 6th part of the console messages:
[  678.307621] Fixing recursive fault but reboot is needed!
[  678.313036] Unable to handle kernel paging request at virtual address fffffff0
[  678.320368] pgd = c0004000
[  678.323111] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  678.329485] Internal error: Oops: 37 [#7] ARM
[  678.333904] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  678.350736] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  678.358771] Hardware name: BCM2835
[  678.362230] task: d876df60 task.stack: d9154000
[  678.366838] PC is at kthread_data+0x18/0x20
[  678.371085] LR is at wq_worker_sleeping+0x18/0xc4
[  678.375857] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  678.375857] sp : d9154cd8  ip : d9154ce8  fp : d9154ce4
[  678.387505] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  678.392805] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  678.399426] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  678.406048] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  678.413374] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  678.419202] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  678.425736] Stack: (0xd9154cd8 to 0xd9156000)
[  678.430156] 4cc0:                                                       d9154cf4 d9154ce8
[  678.438458] 4ce0: c0039b60 c003f494 d9154d44 d9154cf8 c05d1ad8 c0039b54 0000000b c08abfc0
[  678.446759] 4d00: 0000000b 00000001 60000193 c003f4a2 d9154d34 d9154d20 c005cd50 d9154000
[  678.455060] 4d20: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154d5c d9154d48
[  678.463362] 4d40: c05d1ca4 c05d1690 d876df60 d876df60 d9154d9c d9154d60 c002503c c05d1c60
[  678.471663] 4d60: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  678.479964] 4d80: 0000000b 00000001 60000193 c003f4a2 d9154e1c d9154da0 c0013e18 c0024858
[  678.488265] 4da0: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  678.496566] 4dc0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  678.504867] 4de0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9154f40
[  678.513169] 4e00: 00000000 00000000 d9154000 c05d1ca4 d9154e34 d9154e20 c001db84 c0013ca0
[  678.521469] 4e20: d9154f40 fffffff0 d9154e8c d9154e38 c05d5fe0 c001db2c d9154e5c d9154e48
[  678.529770] 4e40: c03a23f0 c03a1b1c c09222d0 c03a2194 d9154e7c d9154e60 c03a2194 c09abbb8
[  678.538072] 4e60: 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9154f40 d9154000 c05d1ca4
[  678.546373] 4e80: d9154f3c d9154e90 c0009204 c05d5db0 000002a4 00076469 c0933e34 c0922294
[  678.554674] 4ea0: 00000000 c0922294 00000001 c005b3e8 d9154edc d9154ec0 c005a758 c08f9304
[  678.562975] 4ec0: 0000003c c09426cc 00000000 c0921d80 00000000 00011798 d9154ef4 c004b5fc
[  678.571276] 4ee0: d876df90 c08b1820 5b63d7f0 c004b668 d876df90 c08b1820 d9154f3c d9154f08
[  678.579578] 4f00: c004b668 c00564a0 d9154f44 d9154f18 c0079a50 c08b1820 d876df90 c003f4a0
[  678.587880] 4f20: 20000193 ffffffff d9154f74 c08b17f0 d9154f9c d9154f40 c05d56d4 c00091cc
[  678.596180] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  678.604482] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  678.612784] 4f80: 20000193 ffffffff 00000002 bf000000 d9154fac d9154fa0 c0039b60 c003f494
[  678.621085] 4fa0: d9154ffc d9154fb0 c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001
[  678.629386] 4fc0: 60000193 c003f4a2 d9154fec d9154fd8 c005cd50 d9154000 0000000b c08abfc0
[  678.637688] 4fe0: 0000000b 00000001 60000193 c003f4a2 d9155014 d9155000 c05d1ca4 c05d1690
[  678.645989] 5000: d876df60 d876df60 d9155054 d9155018 c002503c c05d1c60 00000006 c091f104
[  678.654291] 5020: 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0 0000000b 00000001
[  678.662593] 5040: 60000193 c003f4a2 d91550d4 d9155058 c0013e18 c0024858 d9154188 0000000b
[  678.670894] 5060: d9154000 bf000000 00000008 00000000 6505cd50 62633432 20343030 64323565
[  678.679196] 5080: 34303065 62386520 30303464 35652030 33333039 28203032 33313565 30313030
[  678.687496] 50a0: c0002029 c00e4690 c071d0cc fffffff0 00000037 d91551f8 00000000 00000000
[  678.695797] 50c0: d9154000 c05d1ca4 d91550ec d91550d8 c001db84 c0013ca0 d91551f8 fffffff0
[  678.704098] 50e0: d9155144 d91550f0 c05d5fe0 c001db2c d9155114 d9155100 c03a23f0 c03a1b1c
[  678.712400] 5100: c09222d0 c03a2194 d9155134 d9155118 c03a2194 c09abbb8 60000193 c08ac6d4
[  678.720702] 5120: 00000037 c05d5da4 fffffff0 d91551f8 d9154000 c05d1ca4 d91551f4 d9155148
[  678.729004] 5140: c0009204 c05d5db0 000002a2 000e8392 c092f978 c0922294 00000000 c0922294
[  678.737305] 5160: 00000001 c005b3e8 d9155194 d9155178 c005a758 c08f9304 0000003c c09426cc
[  678.745606] 5180: 00000000 c0921d80 00000000 0000d2dc d91551ac c004b5fc d876df90 c08b1820
[  678.753907] 51a0: 4a357f60 c004b668 d876df90 c08b1820 d91551f4 d91551c0 c004b668 c00564a0
[  678.762209] 51c0: d91551fc d91551d0 c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff
[  678.770511] 51e0: d915522c c08b17f0 d9155254 d91551f8 c05d56d4 c00091cc d876df60 d876df60
[  678.778813] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  678.787114] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  678.795416] 5240: 00000002 bf000000 d9155264 d9155258 c0039b60 c003f494 d91552b4 d9155268
[  678.803717] 5260: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  678.812018] 5280: d91552a4 d9155290 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  678.820320] 52a0: 60000193 c003f4a2 d91552cc d91552b8 c05d1ca4 c05d1690 d876df60 d876df60
[  678.828621] 52c0: d915530c d91552d0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  678.836922] 52e0: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  678.845224] 5300: d915538c d9155310 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  678.853526] 5320: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  678.861828] 5340: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  678.870128] 5360: c071d0cc fffffff0 00000037 d91554b0 00000000 00000000 d9154000 c05d1ca4
[  678.878429] 5380: d91553a4 d9155390 c001db84 c0013ca0 d91554b0 fffffff0 d91553fc d91553a8
[  678.886730] 53a0: c05d5fe0 c001db2c d91553cc d91553b8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  678.895030] 53c0: d91553ec d91553d0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  678.903332] 53e0: fffffff0 d91554b0 d9154000 c05d1ca4 d91554ac d9155400 c0009204 c05d5db0
[  678.911633] 5400: 000002a1 000ac677 c092c1ac c0922294 00000000 c0922294 00000001 c005b3e8
[  678.919934] 5420: d915544c d9155430 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  678.928236] 5440: 00000000 00009b10 d9155464 c004b5fc d876df90 c08b1820 399e1b58 c004b668
[  678.936536] 5460: d876df90 c08b1820 d91554ac d9155478 c004b668 c00564a0 d91554b4 d9155488
[  678.944838] 5480: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d91554e4 c08b17f0
[  678.953138] 54a0: d915550c d91554b0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  678.961439] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  678.969741] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  678.978043] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  678.986344] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  678.994645] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  679.002946] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  679.011247] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  679.019548] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  679.027848] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  679.036149] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  679.044450] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  679.052752] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  679.061053] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  679.069353] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  679.077654] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  679.085955] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  679.094256] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  679.102557] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  679.110858] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  679.119160] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  679.127461] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  679.135760] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  679.144061] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  679.152361] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  679.160663] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  679.168963] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  679.177264] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  679.185565] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  679.193866] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  679.202167] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  679.210469] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  679.218770] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  679.227070] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  679.235372] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  679.243673] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  679.251974] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  679.260274] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  679.268576] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  679.276877] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  679.285177] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  679.293479] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  679.301781] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  679.310082] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  679.318383] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  679.326684] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  679.334986] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  679.343287] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  679.351590] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  679.359891] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  679.368193] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  679.376493] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  679.384794] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  679.393096] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  679.401397] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  679.409699] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  679.418000] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  679.426301] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  679.434603] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  679.442904] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  679.451206] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  679.459507] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  679.467808] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  679.476110] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  679.484411] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  679.492712] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  679.501014] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  679.509316] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  679.517617] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  679.525918] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  679.534219] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  679.542520] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  679.550822] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  679.559124] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  679.567425] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  679.575727] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  679.584028] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  679.592330] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  679.600631] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  679.608932] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  679.617233] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  679.625535] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  679.633835] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  679.642136] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  679.650436] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  679.658737] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  679.667037] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  679.675338] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  679.683638] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  679.691938] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  679.700238] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  679.708559] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  679.716793] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  679.725016] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  679.732182] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  679.739263] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  679.745900] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  679.753945] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  679.762956] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  679.770731] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  679.778236] Exception stack(0xd9154f40 to 0xd9154f88)
[  679.783365] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  679.791666] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  679.799963] 4f80: 20000193 ffffffff
[  679.803515] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  679.811030] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  679.819253] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  679.827473] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  679.834637] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  679.841716] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  679.848350] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  679.856393] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  679.865405] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  679.873180] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  679.880685] Exception stack(0xd91551f8 to 0xd9155240)
[  679.885810] 51e0:                                                       d876df60 d876df60
[  679.894112] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  679.902414] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  679.910725] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  679.918240] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  679.926463] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  679.934682] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  679.941844] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  679.948921] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  679.955554] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  679.963596] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  679.972606] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  679.980381] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  679.987884] Exception stack(0xd91554b0 to 0xd91554f8)
[  679.993009] 54a0:                                     d876df60 d876df60 00000000 00000000
[  680.001311] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  680.009611] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff
[  680.016332] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  680.023846] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  680.032069] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  680.040288] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  680.047452] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  680.054529] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  680.061164] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  680.069206] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  680.078217] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  680.085992] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  680.093495] Exception stack(0xd9155768 to 0xd91557b0)
[  680.098623] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  680.106925] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  680.115223] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  680.120359] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  680.127876] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  680.136099] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  680.144321] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  680.151484] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  680.158562] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  680.165196] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  680.173240] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  680.182251] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  680.190027] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  680.197531] Exception stack(0xd9155a20 to 0xd9155a68)
[  680.202660] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  680.210962] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  680.219258] 5a60: 20000093 ffffffff
[  680.222807] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  680.230322] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  680.238546] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  680.246767] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  680.254281] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  680.261710] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  680.268345] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  680.275419] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  680.283549] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  680.291582] Exception stack(0xd9155c70 to 0xd9155cb8)
[  680.296709] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  680.305011] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  680.313311] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  680.320040] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  680.328525] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  680.337099] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  680.346112] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  680.354683] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  680.362363] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  680.371937] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  680.381925] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  680.390148] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  680.397584] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  680.404919] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  680.411105] ---[ end trace d9489205bcc517ab ]---
The 7th part of the console messages:
[  680.415788] Fixing recursive fault but reboot is needed!
[  680.421202] Unable to handle kernel paging request at virtual address fffffff0
[  680.428533] pgd = c0004000
[  680.431276] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  680.437652] Internal error: Oops: 37 [#8] ARM
[  680.442072] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  680.458909] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  680.466942] Hardware name: BCM2835
[  680.470401] task: d876df60 task.stack: d9154000
[  680.475007] PC is at kthread_data+0x18/0x20
[  680.479256] LR is at wq_worker_sleeping+0x18/0xc4
[  680.484031] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  680.484031] sp : d9154a20  ip : d9154a30  fp : d9154a2c
[  680.495679] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  680.500977] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  680.507598] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  680.514221] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  680.521547] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  680.527375] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  680.533909] Stack: (0xd9154a20 to 0xd9156000)
[  680.538333] 4a20: d9154a3c d9154a30 c0039b60 c003f494 d9154a8c d9154a40 c05d1ad8 c0039b54
[  680.546635] 4a40: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154a7c d9154a68
[  680.554936] 4a60: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  680.563239] 4a80: d9154aa4 d9154a90 c05d1ca4 c05d1690 d876df60 d876df60 d9154ae4 d9154aa8
[  680.571539] 4aa0: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  680.579841] 4ac0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154b64 d9154ae8
[  680.588143] 4ae0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  680.596445] 4b00: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  680.604747] 4b20: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  680.613047] 4b40: 00000037 d9154c88 00000000 00000000 d9154000 c05d1ca4 d9154b7c d9154b68
[  680.621349] 4b60: c001db84 c0013ca0 d9154c88 fffffff0 d9154bd4 d9154b80 c05d5fe0 c001db2c
[  680.629650] 4b80: d9154ba4 d9154b90 c03a23f0 c03a1b1c c09222d0 c03a2194 d9154bc4 d9154ba8
[  680.637952] 4ba0: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9154c88
[  680.646252] 4bc0: d9154000 c05d1ca4 d9154c84 d9154bd8 c0009204 c05d5db0 000002a6 0004b1a5
[  680.654553] 4be0: c0938ff4 c0922294 00000000 c0922294 00000001 c005b3e8 d9154c24 d9154c08
[  680.662855] 4c00: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00016958
[  680.671156] 4c20: d9154c3c c004b5fc d876df90 c08b1820 6cab4e30 c004b668 d876df90 c08b1820
[  680.679457] 4c40: d9154c84 d9154c50 c004b668 c00564a0 d9154c8c d9154c60 c0079a50 c08b1820
[  680.687759] 4c60: d876df90 c003f4a0 20000193 ffffffff d9154cbc c08b17f0 d9154ce4 d9154c88
[  680.696060] 4c80: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  680.704362] 4ca0: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154ce4 d9154ce8 d9154cd8
[  680.712664] 4cc0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d9154cf4 d9154ce8
[  680.720965] 4ce0: c0039b60 c003f494 d9154d44 d9154cf8 c05d1ad8 c0039b54 0000000b c08abfc0
[  680.729266] 4d00: 0000000b 00000001 60000193 c003f4a2 d9154d34 d9154d20 c005cd50 d9154000
[  680.737568] 4d20: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154d5c d9154d48
[  680.745870] 4d40: c05d1ca4 c05d1690 d876df60 d876df60 d9154d9c d9154d60 c002503c c05d1c60
[  680.754172] 4d60: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  680.762474] 4d80: 0000000b 00000001 60000193 c003f4a2 d9154e1c d9154da0 c0013e18 c0024858
[  680.770775] 4da0: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  680.779077] 4dc0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  680.787378] 4de0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9154f40
[  680.795679] 4e00: 00000000 00000000 d9154000 c05d1ca4 d9154e34 d9154e20 c001db84 c0013ca0
[  680.803981] 4e20: d9154f40 fffffff0 d9154e8c d9154e38 c05d5fe0 c001db2c d9154e5c d9154e48
[  680.812282] 4e40: c03a23f0 c03a1b1c c09222d0 c03a2194 d9154e7c d9154e60 c03a2194 c09abbb8
[  680.820583] 4e60: 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9154f40 d9154000 c05d1ca4
[  680.828885] 4e80: d9154f3c d9154e90 c0009204 c05d5db0 000002a4 00076469 c0933e34 c0922294
[  680.837184] 4ea0: 00000000 c0922294 00000001 c005b3e8 d9154edc d9154ec0 c005a758 c08f9304
[  680.845486] 4ec0: 0000003c c09426cc 00000000 c0921d80 00000000 00011798 d9154ef4 c004b5fc
[  680.853788] 4ee0: d876df90 c08b1820 5b63d7f0 c004b668 d876df90 c08b1820 d9154f3c d9154f08
[  680.862089] 4f00: c004b668 c00564a0 d9154f44 d9154f18 c0079a50 c08b1820 d876df90 c003f4a0
[  680.870391] 4f20: 20000193 ffffffff d9154f74 c08b17f0 d9154f9c d9154f40 c05d56d4 c00091cc
[  680.878693] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  680.886994] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  680.895295] 4f80: 20000193 ffffffff 00000002 bf000000 d9154fac d9154fa0 c0039b60 c003f494
[  680.903597] 4fa0: d9154ffc d9154fb0 c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001
[  680.911898] 4fc0: 60000193 c003f4a2 d9154fec d9154fd8 c005cd50 d9154000 0000000b c08abfc0
[  680.920199] 4fe0: 0000000b 00000001 60000193 c003f4a2 d9155014 d9155000 c05d1ca4 c05d1690
[  680.928500] 5000: d876df60 d876df60 d9155054 d9155018 c002503c c05d1c60 00000006 c091f104
[  680.936802] 5020: 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0 0000000b 00000001
[  680.945103] 5040: 60000193 c003f4a2 d91550d4 d9155058 c0013e18 c0024858 d9154188 0000000b
[  680.953405] 5060: d9154000 bf000000 00000008 00000000 6505cd50 62633432 20343030 64323565
[  680.961707] 5080: 34303065 62386520 30303464 35652030 33333039 28203032 33313565 30313030
[  680.970008] 50a0: c0002029 c00e4690 c071d0cc fffffff0 00000037 d91551f8 00000000 00000000
[  680.978310] 50c0: d9154000 c05d1ca4 d91550ec d91550d8 c001db84 c0013ca0 d91551f8 fffffff0
[  680.986612] 50e0: d9155144 d91550f0 c05d5fe0 c001db2c d9155114 d9155100 c03a23f0 c03a1b1c
[  680.994914] 5100: c09222d0 c03a2194 d9155134 d9155118 c03a2194 c09abbb8 60000193 c08ac6d4
[  681.003215] 5120: 00000037 c05d5da4 fffffff0 d91551f8 d9154000 c05d1ca4 d91551f4 d9155148
[  681.011517] 5140: c0009204 c05d5db0 000002a2 000e8392 c092f978 c0922294 00000000 c0922294
[  681.019818] 5160: 00000001 c005b3e8 d9155194 d9155178 c005a758 c08f9304 0000003c c09426cc
[  681.028120] 5180: 00000000 c0921d80 00000000 0000d2dc d91551ac c004b5fc d876df90 c08b1820
[  681.036420] 51a0: 4a357f60 c004b668 d876df90 c08b1820 d91551f4 d91551c0 c004b668 c00564a0
[  681.044722] 51c0: d91551fc d91551d0 c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff
[  681.053023] 51e0: d915522c c08b17f0 d9155254 d91551f8 c05d56d4 c00091cc d876df60 d876df60
[  681.061325] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  681.069626] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  681.077926] 5240: 00000002 bf000000 d9155264 d9155258 c0039b60 c003f494 d91552b4 d9155268
[  681.086228] 5260: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  681.094530] 5280: d91552a4 d9155290 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  681.102830] 52a0: 60000193 c003f4a2 d91552cc d91552b8 c05d1ca4 c05d1690 d876df60 d876df60
[  681.111133] 52c0: d915530c d91552d0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  681.119434] 52e0: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  681.127735] 5300: d915538c d9155310 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  681.136037] 5320: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  681.144337] 5340: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  681.152638] 5360: c071d0cc fffffff0 00000037 d91554b0 00000000 00000000 d9154000 c05d1ca4
[  681.160940] 5380: d91553a4 d9155390 c001db84 c0013ca0 d91554b0 fffffff0 d91553fc d91553a8
[  681.169242] 53a0: c05d5fe0 c001db2c d91553cc d91553b8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  681.177543] 53c0: d91553ec d91553d0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  681.185844] 53e0: fffffff0 d91554b0 d9154000 c05d1ca4 d91554ac d9155400 c0009204 c05d5db0
[  681.194146] 5400: 000002a1 000ac677 c092c1ac c0922294 00000000 c0922294 00000001 c005b3e8
[  681.202447] 5420: d915544c d9155430 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  681.210749] 5440: 00000000 00009b10 d9155464 c004b5fc d876df90 c08b1820 399e1b58 c004b668
[  681.219051] 5460: d876df90 c08b1820 d91554ac d9155478 c004b668 c00564a0 d91554b4 d9155488
[  681.227353] 5480: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d91554e4 c08b17f0
[  681.235654] 54a0: d915550c d91554b0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  681.243956] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  681.252258] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  681.260559] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  681.268861] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  681.277163] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  681.285465] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  681.293765] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  681.302067] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  681.310369] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  681.318671] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  681.326973] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  681.335273] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  681.343575] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  681.351876] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  681.360177] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  681.368479] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  681.376780] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  681.385082] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  681.393384] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  681.401686] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  681.409988] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  681.418289] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  681.426590] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  681.434892] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  681.443193] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  681.451495] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  681.459797] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  681.468098] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  681.476401] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  681.484702] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  681.493003] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  681.501304] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  681.509606] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  681.517907] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  681.526208] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  681.534510] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  681.542810] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  681.551113] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  681.559414] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  681.567715] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  681.576017] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  681.584318] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  681.592619] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  681.600919] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  681.609221] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  681.617521] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  681.625822] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  681.634124] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  681.642426] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  681.650728] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  681.659032] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  681.667334] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  681.675635] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  681.683937] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  681.692238] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  681.700541] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  681.708842] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  681.717144] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  681.725445] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  681.733747] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  681.742049] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  681.750351] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  681.758652] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  681.766954] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  681.775257] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  681.783559] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  681.791860] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  681.800161] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  681.808463] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  681.816764] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  681.825065] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  681.833367] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  681.841669] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  681.849971] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  681.858271] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  681.866572] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  681.874873] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  681.883173] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  681.891475] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  681.899778] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  681.908079] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  681.916381] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  681.924683] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  681.932984] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  681.941285] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  681.949587] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  681.957887] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  681.966187] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  681.974488] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  681.982788] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  681.991110] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  681.999344] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.007568] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.014737] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.021820] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.028456] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.036503] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.045517] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.053294] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.060798] Exception stack(0xd9154c88 to 0xd9154cd0)
[  682.065925] 4c80:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  682.074228] 4ca0: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154ce4 d9154ce8 d9154cd8
[  682.082527] 4cc0: c0039b60 c003f4a0 20000193 ffffffff
[  682.087667] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.095186] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.103411] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.111632] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.118795] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.125873] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.132508] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.140551] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.149562] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.157337] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.164842] Exception stack(0xd9154f40 to 0xd9154f88)
[  682.169971] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  682.178274] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  682.186570] 4f80: 20000193 ffffffff
[  682.190120] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.197636] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.205859] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.214078] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.221241] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.228319] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.234954] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.242997] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.252008] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.259786] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.267290] Exception stack(0xd91551f8 to 0xd9155240)
[  682.272415] 51e0:                                                       d876df60 d876df60
[  682.280717] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  682.289020] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  682.297330] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.304846] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.313069] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.321288] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.328451] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.335530] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.342164] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.350206] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.359218] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.366995] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.374499] Exception stack(0xd91554b0 to 0xd91554f8)
[  682.379625] 54a0:                                     d876df60 d876df60 00000000 00000000
[  682.387927] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  682.396227] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff
[  682.402950] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.410465] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.418688] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.426908] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.434071] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.441150] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.447786] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.455828] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.464839] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.472617] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.480122] Exception stack(0xd9155768 to 0xd91557b0)
[  682.485250] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  682.493553] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  682.501852] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  682.506990] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.514505] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.522729] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.530949] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  682.538112] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  682.545189] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.551825] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  682.559868] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  682.568879] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  682.576655] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  682.584157] Exception stack(0xd9155a20 to 0xd9155a68)
[  682.589288] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  682.597589] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  682.605886] 5a60: 20000093 ffffffff
[  682.609437] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  682.616951] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  682.625174] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  682.633394] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  682.640911] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  682.648342] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  682.654976] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  682.662050] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  682.670180] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  682.678212] Exception stack(0xd9155c70 to 0xd9155cb8)
[  682.683339] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  682.691641] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  682.699942] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  682.706673] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  682.715160] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  682.723735] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  682.732748] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  682.741321] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  682.749007] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  682.758581] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  682.768570] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  682.776794] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  682.784228] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  682.791564] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  682.797752] ---[ end trace d9489205bcc517ac ]---
carriba
Contact: ICQ
Fri Feb 23, 2018 3:23 pm
The 8th part of the console messages:
[  682.802435] Fixing recursive fault but reboot is needed!
[  682.807850] Unable to handle kernel paging request at virtual address fffffff0
[  682.815179] pgd = c0004000
[  682.817921] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  682.824296] Internal error: Oops: 37 [#9] ARM
[  682.828716] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  682.845547] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  682.853580] Hardware name: BCM2835
[  682.857039] task: d876df60 task.stack: d9154000
[  682.861645] PC is at kthread_data+0x18/0x20
[  682.865892] LR is at wq_worker_sleeping+0x18/0xc4
[  682.870666] pc : [<c003f4a0>]    lr : [<c0039b60>]    psr: 20000193
[  682.870666] sp : d9154768  ip : d9154778  fp : d9154774
[  682.882313] r10: c05d1ca4  r9 : 60000193  r8 : c08b17f0
[  682.887612] r7 : d876e2ac  r6 : 00000000  r5 : 0000000b  r4 : d876df60
[  682.894233] r3 : 00000000  r2 : 00000000  r1 : d876df60  r0 : d876df60
[  682.900855] Flags: nzCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  682.908182] Control: 00c5387d  Table: 19374008  DAC: 00000055
[  682.914012] Process kworker/u2:2 (pid: 741, stack limit = 0xd9154188)
[  682.920546] Stack: (0xd9154768 to 0xd9156000)
[  682.924969] 4760:                   d9154784 d9154778 c0039b60 c003f494 d91547d4 d9154788
[  682.933270] 4780: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  682.941571] 47a0: d91547c4 d91547b0 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  682.949873] 47c0: 60000193 c003f4a2 d91547ec d91547d8 c05d1ca4 c05d1690 d876df60 d876df60
[  682.958175] 47e0: d915482c d91547f0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  682.966476] 4800: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  682.974777] 4820: d91548ac d9154830 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  682.983079] 4840: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  682.991380] 4860: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  682.999682] 4880: c071d0cc fffffff0 00000037 d91549d0 00000000 00000000 d9154000 c05d1ca4
[  683.007984] 48a0: d91548c4 d91548b0 c001db84 c0013ca0 d91549d0 fffffff0 d915491c d91548c8
[  683.016286] 48c0: c05d5fe0 c001db2c d91548ec d91548d8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  683.024588] 48e0: d915490c d91548f0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  683.032890] 4900: fffffff0 d91549d0 d9154000 c05d1ca4 d91549cc d9154920 c0009204 c05d5db0
[  683.041192] 4920: 000002a8 0006582c c093ee80 c0922294 00000000 c0922294 00000001 c005b3e8
[  683.049493] 4940: d915496c d9154950 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  683.057795] 4960: 00000000 0001c7e4 d9154984 c004b5fc d876df90 c08b1820 7da80f70 c004b668
[  683.066096] 4980: d876df90 c08b1820 d91549cc d9154998 c004b668 c00564a0 d91549d4 d91549a8
[  683.074398] 49a0: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d9154a04 c08b17f0
[  683.082700] 49c0: d9154a2c d91549d0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  683.091000] 49e0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154a2c
[  683.099302] 4a00: d9154a30 d9154a20 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  683.107604] 4a20: d9154a3c d9154a30 c0039b60 c003f494 d9154a8c d9154a40 c05d1ad8 c0039b54
[  683.115906] 4a40: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154a7c d9154a68
[  683.124206] 4a60: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  683.132509] 4a80: d9154aa4 d9154a90 c05d1ca4 c05d1690 d876df60 d876df60 d9154ae4 d9154aa8
[  683.140808] 4aa0: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  683.149110] 4ac0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154b64 d9154ae8
[  683.157411] 4ae0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  683.165713] 4b00: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  683.174015] 4b20: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  683.182317] 4b40: 00000037 d9154c88 00000000 00000000 d9154000 c05d1ca4 d9154b7c d9154b68
[  683.190618] 4b60: c001db84 c0013ca0 d9154c88 fffffff0 d9154bd4 d9154b80 c05d5fe0 c001db2c
[  683.198919] 4b80: d9154ba4 d9154b90 c03a23f0 c03a1b1c c09222d0 c03a2194 d9154bc4 d9154ba8
[  683.207221] 4ba0: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9154c88
[  683.215523] 4bc0: d9154000 c05d1ca4 d9154c84 d9154bd8 c0009204 c05d5db0 000002a6 0004b1a5
[  683.223824] 4be0: c0938ff4 c0922294 00000000 c0922294 00000001 c005b3e8 d9154c24 d9154c08
[  683.232126] 4c00: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00016958
[  683.240428] 4c20: d9154c3c c004b5fc d876df90 c08b1820 6cab4e30 c004b668 d876df90 c08b1820
[  683.248730] 4c40: d9154c84 d9154c50 c004b668 c00564a0 d9154c8c d9154c60 c0079a50 c08b1820
[  683.257031] 4c60: d876df90 c003f4a0 20000193 ffffffff d9154cbc c08b17f0 d9154ce4 d9154c88
[  683.265333] 4c80: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  683.273634] 4ca0: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154ce4 d9154ce8 d9154cd8
[  683.281936] 4cc0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d9154cf4 d9154ce8
[  683.290237] 4ce0: c0039b60 c003f494 d9154d44 d9154cf8 c05d1ad8 c0039b54 0000000b c08abfc0
[  683.298539] 4d00: 0000000b 00000001 60000193 c003f4a2 d9154d34 d9154d20 c005cd50 d9154000
[  683.306840] 4d20: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d9154d5c d9154d48
[  683.315142] 4d40: c05d1ca4 c05d1690 d876df60 d876df60 d9154d9c d9154d60 c002503c c05d1c60
[  683.323445] 4d60: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  683.331746] 4d80: 0000000b 00000001 60000193 c003f4a2 d9154e1c d9154da0 c0013e18 c0024858
[  683.340048] 4da0: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  683.348349] 4dc0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  683.356651] 4de0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9154f40
[  683.364952] 4e00: 00000000 00000000 d9154000 c05d1ca4 d9154e34 d9154e20 c001db84 c0013ca0
[  683.373253] 4e20: d9154f40 fffffff0 d9154e8c d9154e38 c05d5fe0 c001db2c d9154e5c d9154e48
[  683.381555] 4e40: c03a23f0 c03a1b1c c09222d0 c03a2194 d9154e7c d9154e60 c03a2194 c09abbb8
[  683.389857] 4e60: 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9154f40 d9154000 c05d1ca4
[  683.398158] 4e80: d9154f3c d9154e90 c0009204 c05d5db0 000002a4 00076469 c0933e34 c0922294
[  683.406458] 4ea0: 00000000 c0922294 00000001 c005b3e8 d9154edc d9154ec0 c005a758 c08f9304
[  683.414760] 4ec0: 0000003c c09426cc 00000000 c0921d80 00000000 00011798 d9154ef4 c004b5fc
[  683.423062] 4ee0: d876df90 c08b1820 5b63d7f0 c004b668 d876df90 c08b1820 d9154f3c d9154f08
[  683.431364] 4f00: c004b668 c00564a0 d9154f44 d9154f18 c0079a50 c08b1820 d876df90 c003f4a0
[  683.439666] 4f20: 20000193 ffffffff d9154f74 c08b17f0 d9154f9c d9154f40 c05d56d4 c00091cc
[  683.447967] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  683.456269] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  683.464571] 4f80: 20000193 ffffffff 00000002 bf000000 d9154fac d9154fa0 c0039b60 c003f494
[  683.472872] 4fa0: d9154ffc d9154fb0 c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001
[  683.481173] 4fc0: 60000193 c003f4a2 d9154fec d9154fd8 c005cd50 d9154000 0000000b c08abfc0
[  683.489474] 4fe0: 0000000b 00000001 60000193 c003f4a2 d9155014 d9155000 c05d1ca4 c05d1690
[  683.497776] 5000: d876df60 d876df60 d9155054 d9155018 c002503c c05d1c60 00000006 c091f104
[  683.506077] 5020: 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0 0000000b 00000001
[  683.514379] 5040: 60000193 c003f4a2 d91550d4 d9155058 c0013e18 c0024858 d9154188 0000000b
[  683.522679] 5060: d9154000 bf000000 00000008 00000000 6505cd50 62633432 20343030 64323565
[  683.530981] 5080: 34303065 62386520 30303464 35652030 33333039 28203032 33313565 30313030
[  683.539281] 50a0: c0002029 c00e4690 c071d0cc fffffff0 00000037 d91551f8 00000000 00000000
[  683.547582] 50c0: d9154000 c05d1ca4 d91550ec d91550d8 c001db84 c0013ca0 d91551f8 fffffff0
[  683.555883] 50e0: d9155144 d91550f0 c05d5fe0 c001db2c d9155114 d9155100 c03a23f0 c03a1b1c
[  683.564185] 5100: c09222d0 c03a2194 d9155134 d9155118 c03a2194 c09abbb8 60000193 c08ac6d4
[  683.572486] 5120: 00000037 c05d5da4 fffffff0 d91551f8 d9154000 c05d1ca4 d91551f4 d9155148
[  683.580788] 5140: c0009204 c05d5db0 000002a2 000e8392 c092f978 c0922294 00000000 c0922294
[  683.589089] 5160: 00000001 c005b3e8 d9155194 d9155178 c005a758 c08f9304 0000003c c09426cc
[  683.597391] 5180: 00000000 c0921d80 00000000 0000d2dc d91551ac c004b5fc d876df90 c08b1820
[  683.605693] 51a0: 4a357f60 c004b668 d876df90 c08b1820 d91551f4 d91551c0 c004b668 c00564a0
[  683.613995] 51c0: d91551fc d91551d0 c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff
[  683.622296] 51e0: d915522c c08b17f0 d9155254 d91551f8 c05d56d4 c00091cc d876df60 d876df60
[  683.630597] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  683.638899] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  683.647201] 5240: 00000002 bf000000 d9155264 d9155258 c0039b60 c003f494 d91552b4 d9155268
[  683.655503] 5260: c05d1ad8 c0039b54 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  683.663803] 5280: d91552a4 d9155290 c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001
[  683.672104] 52a0: 60000193 c003f4a2 d91552cc d91552b8 c05d1ca4 c05d1690 d876df60 d876df60
[  683.680405] 52c0: d915530c d91552d0 c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0
[  683.688706] 52e0: 0000000b c091f104 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2
[  683.697007] 5300: d915538c d9155310 c0013e18 c0024858 d9154188 0000000b d9154000 bf000000
[  683.705308] 5320: 00000008 00000000 6505cd50 62633432 20343030 64323565 34303065 62386520
[  683.713608] 5340: 30303464 35652030 33333039 28203032 33313565 30313030 c0002029 c00e4690
[  683.721909] 5360: c071d0cc fffffff0 00000037 d91554b0 00000000 00000000 d9154000 c05d1ca4
[  683.730209] 5380: d91553a4 d9155390 c001db84 c0013ca0 d91554b0 fffffff0 d91553fc d91553a8
[  683.738511] 53a0: c05d5fe0 c001db2c d91553cc d91553b8 c03a23f0 c03a1b1c c09222d0 c03a2194
[  683.746812] 53c0: d91553ec d91553d0 c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4
[  683.755113] 53e0: fffffff0 d91554b0 d9154000 c05d1ca4 d91554ac d9155400 c0009204 c05d5db0
[  683.763415] 5400: 000002a1 000ac677 c092c1ac c0922294 00000000 c0922294 00000001 c005b3e8
[  683.771716] 5420: d915544c d9155430 c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80
[  683.780017] 5440: 00000000 00009b10 d9155464 c004b5fc d876df90 c08b1820 399e1b58 c004b668
[  683.788319] 5460: d876df90 c08b1820 d91554ac d9155478 c004b668 c00564a0 d91554b4 d9155488
[  683.796621] 5480: c0079a50 c08b1820 d876df90 c003f4a0 20000193 ffffffff d91554e4 c08b17f0
[  683.804923] 54a0: d915550c d91554b0 c05d56d4 c00091cc d876df60 d876df60 00000000 00000000
[  683.813224] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  683.821526] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000
[  683.829828] 5500: d915551c d9155510 c0039b60 c003f494 d915556c d9155520 c05d1ad8 c0039b54
[  683.838129] 5520: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915555c d9155548
[  683.846431] 5540: c005cd50 d9154000 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2
[  683.854732] 5560: d9155584 d9155570 c05d1ca4 c05d1690 d876df60 d876df60 d91555c4 d9155588
[  683.863033] 5580: c002503c c05d1c60 00000006 c091f104 60000193 c08abfc0 0000000b c091f104
[  683.871335] 55a0: 60000193 c08abfc0 0000000b 00000001 60000193 c003f4a2 d9155644 d91555c8
[  683.879636] 55c0: c0013e18 c0024858 d9154188 0000000b d9154000 bf000000 00000008 00000000
[  683.887936] 55e0: 6505cd50 62633432 20343030 64323565 34303065 62386520 30303464 35652030
[  683.896238] 5600: 33333039 28203032 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0
[  683.904539] 5620: 00000037 d9155768 00000000 00000000 d9154000 c05d1ca4 d915565c d9155648
[  683.912841] 5640: c001db84 c0013ca0 d9155768 fffffff0 d91556b4 d9155660 c05d5fe0 c001db2c
[  683.921143] 5660: d9155684 d9155670 c03a23f0 c03a1b1c c09222d0 c03a2194 d91556a4 d9155688
[  683.929444] 5680: c03a2194 c09abbb8 60000193 c08ac6d4 00000037 c05d5da4 fffffff0 d9155768
[  683.937746] 56a0: d9154000 c05d1ca4 d9155764 d91556b8 c0009204 c05d5db0 000002a0 000b48af
[  683.946048] 56c0: c0929660 c0922294 00000000 c0922294 00000001 c005b3e8 d9155704 d91556e8
[  683.954350] 56e0: c005a758 c08f9304 0000003c c09426cc 00000000 c0921d80 00000000 00006fc4
[  683.962652] 5700: d915571c c004b5fc d876df90 c08b1820 28a7da28 c004b668 d876df90 c08b1820
[  683.970954] 5720: d9155764 d9155730 c004b668 c00564a0 d915576c d9155740 c0079a50 c08b1820
[  683.979254] 5740: d876df90 c003f4a0 20000193 ffffffff d915579c c08b17f0 d91557c4 d9155768
[  683.987556] 5760: c05d56d4 c00091cc d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  683.995858] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  684.004159] 57a0: c0039b60 c003f4a0 20000193 ffffffff 00000002 bf000000 d91557d4 d91557c8
[  684.012461] 57c0: c0039b60 c003f494 d9155824 d91557d8 c05d1ad8 c0039b54 0000000b c08abfc0
[  684.020763] 57e0: 0000000b 00000001 60000193 c003f4a2 d9155814 d9155800 c005cd50 d9154000
[  684.029064] 5800: 0000000b c08abfc0 0000000b 00000001 60000193 c003f4a2 d915583c d9155828
[  684.037366] 5820: c05d1ca4 c05d1690 d876df60 d876df60 d915587c d9155840 c002503c c05d1c60
[  684.045667] 5840: 00000006 c091f104 60000193 c08abfc0 0000000b c091f104 60000193 c08abfc0
[  684.053970] 5860: 0000000b 00000001 60000193 c003f4a2 d91558fc d9155880 c0013e18 c0024858
[  684.062271] 5880: d9154188 0000000b d9154000 bf000000 00000008 00000000 6505cd50 62633432
[  684.070573] 58a0: 20343030 64323565 34303065 62386520 30303464 35652030 33333039 28203032
[  684.078874] 58c0: 33313565 30313030 c0002029 c00e4690 c071d0cc fffffff0 00000037 d9155a20
[  684.087176] 58e0: 00000000 00000000 d9154000 c00485c0 d9155914 d9155900 c001db84 c0013ca0
[  684.095478] 5900: d9155a20 fffffff0 d915596c d9155918 c05d5fe0 c001db2c d9155934 d9155928
[  684.103779] 5920: c0419bcc c0419a04 d9155964 d9155938 c0069444 c0419bc0 00000003 7fffffff
[  684.112081] 5940: d9155994 c08ac6d4 00000037 c05d5da4 fffffff0 d9155a20 d9154000 c00485c0
[  684.120382] 5960: d9155a1c d9155970 c0009204 c05d5db0 d91559b4 d9155980 ff69ee08 ffffffff
[  684.128682] 5980: d91559b4 c004ba8c c004b9a8 c031fc1c 00000000 d876df90 daca9b70 d876df60
[  684.136982] 59a0: 00000000 c004baa0 d876df90 c004baf4 d91559ec d91559c0 c004baf4 c00474e0
[  684.145284] 59c0: d91559ec c08b17f0 d876df60 c08b17f0 20000093 00000000 c08b17f0 68050093
[  684.153586] 59e0: d9155a04 c004c4b8 c0047a6c c004b9b8 00000001 c08b1820 d876df90 c003f4a0
[  684.161888] 5a00: 20000093 ffffffff d9155a54 c08b17f0 d9155a7c d9155a20 c05d56d4 c00091cc
[  684.170190] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  684.178491] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  684.186792] 5a60: 20000093 ffffffff 00000040 bf000000 d9155a8c d9155a80 c0039b60 c003f494
[  684.195095] 5a80: d9155adc d9155a90 c05d1ad8 c0039b54 d9155abc d9155aa0 c02f556c c0134904
[  684.203396] 5aa0: 00000000 d876df60 daefe690 60000013 d9155adc d876df60 d9155814 d9155af8
[  684.211698] 5ac0: d876e228 00000001 68050093 daca8000 d9155aec d9155ae0 c00485c0 c05d1690
[  684.220000] 5ae0: d9155b2c d9155af0 c0024f1c c0048580 00000006 c091f104 d9155af8 d9155af8
[  684.228301] 5b00: 0000000b c091f104 68050093 c08abfc0 0000000b 00000001 68050093 c01243f2
[  684.236602] 5b20: d9155bac d9155b30 c0013e18 c0024858 d9154188 0000000b c05d1ca4 bf000000
[  684.244903] 5b40: 00000008 00000000 32155bc4 30623135 20303530 66666132 31656666 66376520
[  684.253205] 5b60: 66313030 37652032 31303066 28203266 30663765 32663130 c0002029 c00bec20
[  684.261507] 5b80: ffffffff 00030001 e7f001f2 c01243f0 d9155c70 00000000 68050093 d9154000
[  684.269808] 5ba0: d9155bbc d9155bb0 c0014034 c0013ca0 d9155c6c d9155bc0 c0009160 c0014014
[  684.278109] 5bc0: 00000006 c00bf4b4 00000004 00000000 00030001 c01243f0 00000100 00000200
[  684.286410] 5be0: d9155c84 dae76800 d9155c84 d9155c94 00000000 00000001 d9155c14 d9155c08
[  684.294713] 5c00: c05d2748 c0479230 d9155c3c d9155c18 c0479230 c047d594 00000000 d9155c84
[  684.303015] 5c20: d9155ca0 dae76800 00000000 cd87e320 d9155c5c d9155c40 c047931c c0479158
[  684.311315] 5c40: 00000040 dae77800 c01243f4 a8050013 ffffffff d9155ca4 c08c2898 c05d5808
[  684.319616] 5c60: d9155d5c d9155c70 c05d5808 c000900c 00000000 d84f9258 dc800000 00000000
[  684.327918] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  684.336220] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff 00000035 00000000
[  684.344521] 5cc0: d9155cfc d9155cd0 c0133d8c c05d1e5c d84f9240 d84f924c d9155cfc d9155ce8
[  684.352822] 5ce0: c012403c c03205cc d84f9240 00000001 d9155d5c d9155d00 c01243b0 c0123fc4
[  684.361124] 5d00: 00000200 00000000 dc800000 d84f9240 00400000 00000001 dc804000 00000000
[  684.369425] 5d20: 00000001 dc800000 c0133d8c c0133de8 00000040 00004000 00000022 024080c2
[  684.377726] 5d40: 00000001 dc800000 d90c80e0 da69fe28 d9155d8c d9155d60 c01244cc c012409c
[  684.386028] 5d60: ffffffff 024080c2 00002220 ffffffff dac02800 ffffffff da69fe28 024080c2
[  684.394330] 5d80: d9155dcc d9155d90 c0125478 c012442c ff800000 ffffffff 024080c2 bf2539f0
[  684.402632] 5da0: c04d5e28 bf2539f0 ffffffff dac02800 bf269c44 da69fe28 0000000c da69fe28
[  684.410933] 5dc0: d9155dfc d9155dd0 c0125668 c012541c 024080c2 0000024f 00000000 ffffffff
[  684.419235] 5de0: bf2539f0 00000000 00000020 da6ef7e0 d9155e14 d9155e00 c0125700 c0125620
[  684.427536] 5e00: ffffffff bf2539f0 d9155ef4 d9155e18 bf2539f0 c01256d0 d9155e44 d9155e28
[  684.435838] 5e20: c004bc68 c00401a0 da46e340 da408da0 da69fd32 00000000 00000032 00000014
[  684.444138] 5e40: da69fc0c c00bf4b4 d876df60 00000032 00000040 da69fc00 d9155e7c d876df60
[  684.452440] 5e60: 00000000 da69fd50 0000009c 00000000 00000000 d9155e80 c05d1910 c0045f4c
[  684.460740] 5e80: d9155ea4 d9155e90 c0038b2c 68050013 00000000 00000000 d9155f2c c0035960
[  684.469042] 5ea0: dac02800 da5d7b00 d9155ed4 d9155eb8 c0035960 c0035868 00000000 da5d7b00
[  684.477342] 5ec0: da5d7b00 c0038500 d9155ef4 da69fe28 cd81cae0 dac02800 00000000 00000000
[  684.485643] 5ee0: da5d7b00 cd81cae0 d9155f2c d9155ef8 c0038b3c bf25196c c08b54c0 00000088
[  684.493944] 5f00: dac02800 dac02800 cd81caf8 dac02814 c08b54c0 00000088 dac02800 cd81cae0
[  684.502245] 5f20: d9155f64 d9155f30 c0038df4 c0038a2c c0038db8 00000000 00000000 00000000
[  684.510545] 5f40: d92ba620 cd81cae0 c0038db8 00000000 00000000 00000000 d9155fac d9155f68
[  684.518847] 5f60: c003e954 c0038dc4 d9154000 00000000 d9155f94 cd81cae0 00000000 d9155f7c
[  684.527149] 5f80: d9155f7c 00000001 d9155f88 d9155f88 d92ba620 c003e85c 00000000 00000000
[  684.535449] 5fa0: 00000000 d9155fb0 c000fec8 c003e868 00000000 00000000 00000000 00000000
[  684.543749] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[  684.552050] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000 000027ff 00002800
[  684.560371] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  684.568605] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  684.576827] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  684.583995] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  684.591081] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  684.597717] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  684.605763] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  684.614775] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  684.622551] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  684.630054] Exception stack(0xd91549d0 to 0xd9154a18)
[  684.635181] 49c0:                                     d876df60 d876df60 00000000 00000000
[  684.643483] 49e0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154a2c
[  684.651783] 4a00: d9154a30 d9154a20 c0039b60 c003f4a0 20000193 ffffffff
[  684.658508] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  684.666023] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  684.674246] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  684.682466] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  684.689630] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  684.696708] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  684.703343] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  684.711386] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  684.720398] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  684.728174] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  684.735678] Exception stack(0xd9154c88 to 0xd9154cd0)
[  684.740805] 4c80:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  684.749108] 4ca0: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d9154ce4 d9154ce8 d9154cd8
[  684.757405] 4cc0: c0039b60 c003f4a0 20000193 ffffffff
[  684.762544] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  684.770060] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  684.778283] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  684.786505] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  684.793668] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  684.800745] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  684.807381] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  684.815423] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  684.824435] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  684.832210] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  684.839713] Exception stack(0xd9154f40 to 0xd9154f88)
[  684.844842] 4f40: d876df60 d876df60 00000000 00000000 d876df60 0000000b 00000000 d876e2ac
[  684.853144] 4f60: c08b17f0 60000193 c05d1ca4 d9154f9c d9154fa0 d9154f90 c0039b60 c003f4a0
[  684.861440] 4f80: 20000193 ffffffff
[  684.864989] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  684.872506] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  684.880729] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  684.888950] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  684.896113] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  684.903190] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  684.909824] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  684.917867] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  684.926877] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  684.934654] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  684.942158] Exception stack(0xd91551f8 to 0xd9155240)
[  684.947283] 51e0:                                                       d876df60 d876df60
[  684.955586] 5200: 00000000 00000000 d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193
[  684.963888] 5220: c05d1ca4 d9155254 d9155258 d9155248 c0039b60 c003f4a0 20000193 ffffffff
[  684.972197] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  684.979714] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  684.987937] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  684.996157] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  685.003319] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  685.010396] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  685.017030] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  685.025073] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  685.034084] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  685.041861] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  685.049364] Exception stack(0xd91554b0 to 0xd91554f8)
[  685.054490] 54a0:                                     d876df60 d876df60 00000000 00000000
[  685.062792] 54c0: d876df60 0000000b 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d915550c
[  685.071092] 54e0: d9155510 d9155500 c0039b60 c003f4a0 20000193 ffffffff
[  685.077815] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  685.085331] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  685.093554] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  685.101776] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  685.108939] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  685.116016] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  685.122650] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  685.130694] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  685.139705] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  685.147482] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  685.154986] Exception stack(0xd9155768 to 0xd91557b0)
[  685.160115] 5760:                   d876df60 d876df60 00000000 00000000 d876df60 0000000b
[  685.168417] 5780: 00000000 d876e2ac c08b17f0 60000193 c05d1ca4 d91557c4 d91557c8 d91557b8
[  685.176715] 57a0: c0039b60 c003f4a0 20000193 ffffffff
[  685.181851] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  685.189367] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  685.197591] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  685.205813] [<c05d1ad8>] (__schedule) from [<c05d1ca4>] (schedule+0x50/0xa8)
[  685.212976] [<c05d1ca4>] (schedule) from [<c002503c>] (do_exit+0x7f0/0x9d0)
[  685.220053] [<c002503c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  685.226688] [<c0013e18>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  685.234731] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  685.243741] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  685.251518] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  685.259021] Exception stack(0xd9155a20 to 0xd9155a68)
[  685.264151] 5a20: d876df60 d876df60 00000000 00000000 d876df60 d9155814 00000000 d876e2ac
[  685.272451] 5a40: c08b17f0 68050093 c00485c0 d9155a7c d9155a80 d9155a70 c0039b60 c003f4a0
[  685.280748] 5a60: 20000093 ffffffff
[  685.284298] [<c05d56d4>] (__dabt_svc) from [<c003f4a0>] (kthread_data+0x18/0x20)
[  685.291814] [<c003f4a0>] (kthread_data) from [<c0039b60>] (wq_worker_sleeping+0x18/0xc4)
[  685.300038] [<c0039b60>] (wq_worker_sleeping) from [<c05d1ad8>] (__schedule+0x454/0x5d0)
[  685.308260] [<c05d1ad8>] (__schedule) from [<c00485c0>] (do_task_dead+0x4c/0x50)
[  685.315774] [<c00485c0>] (do_task_dead) from [<c0024f1c>] (do_exit+0x6d0/0x9d0)
[  685.323204] [<c0024f1c>] (do_exit) from [<c0013e18>] (die+0x184/0x374)
[  685.329839] [<c0013e18>] (die) from [<c0014034>] (arm_notify_die+0x2c/0x64)
[  685.336912] [<c0014034>] (arm_notify_die) from [<c0009160>] (do_undefinstr+0x160/0x1c0)
[  685.345043] [<c0009160>] (do_undefinstr) from [<c05d5808>] (__und_svc_finish+0x0/0x38)
[  685.353076] Exception stack(0xd9155c70 to 0xd9155cb8)
[  685.358202] 5c60:                                     00000000 d84f9258 dc800000 00000000
[  685.366503] 5c80: d84f9240 00000001 dc800000 c09a2cec c08c2898 ff800000 ffffffff d9155d5c
[  685.374803] 5ca0: d9155ce8 d9155d00 c012403c c01243f0 a8050013 ffffffff
[  685.381537] [<c05d5808>] (__und_svc_finish) from [<c01243f0>] (alloc_vmap_area+0x360/0x390)
[  685.390024] [<c01243f0>] (alloc_vmap_area) from [<c01244cc>] (__get_vm_area_node+0xac/0x144)
[  685.398599] [<c01244cc>] (__get_vm_area_node) from [<c0125478>] (__vmalloc_node_range+0x68/0x204)
[  685.407613] [<c0125478>] (__vmalloc_node_range) from [<c0125668>] (__vmalloc_node+0x54/0x64)
[  685.416184] [<c0125668>] (__vmalloc_node) from [<c0125700>] (vzalloc+0x3c/0x4c)
[  685.423870] [<c0125700>] (vzalloc) from [<bf2539f0>] (brcmf_sdio_dataworker+0x2090/0x2358 [brcmfmac])
[  685.433444] [<bf2539f0>] (brcmf_sdio_dataworker [brcmfmac]) from [<c0038b3c>] (process_one_work+0x11c/0x398)
[  685.443434] [<c0038b3c>] (process_one_work) from [<c0038df4>] (worker_thread+0x3c/0x508)
[  685.451657] [<c0038df4>] (worker_thread) from [<c003e954>] (kthread+0xf8/0x114)
[  685.459091] [<c003e954>] (kthread) from [<c000fec8>] (ret_from_fork+0x14/0x2c)
[  685.466426] Code: e24cb004 e52de004 e8bd4000 e5903320 (e5130010)
[  685.472612] ---[ end trace d9489205bcc517ad ]---
The 9th and last part of the console messages until the console gets frozen with garbage characters:
[  685.477296] Fixing recursive fault but reboot is needed!
[  685.482712] Unable to handle kernel paging request at virtual address fffffff0
[  685.490043] pgd = c0004000
[  685.492786] [fffffff0] *pgd=1bffa861, *pte=00000000, *ppte=00000000
[  685.499162] Internal error: Oops: 37 [#10] ARM
[  685.503670] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem fixed uio_pdrv_genirq uio i2c_dev ip_tables x_tables ipv6
[  685.520503] CPU: 0 PID: 741 Comm: kworker/u2:2 Tainted: G      D         4.9.59+ #1047
[  685.528535] Hardware name: BCM2835
[  685.532046] Unable to handle kernel NULL pointer dereference at virtual address 00000250
[  685.540262] Unable to handle kernel paging request at virtual address 6e656781
[  685.547594] Unable to handle kernel paging request at virtual address 6e656781
[  685.554927] Unable to handle kernel paging request at virtual address 6e656781
[  685.562258] Unable to handle kernel paging request at virtual address 6e656781
[  685.569590] Unable to handle kernel paging request at virtual address 6e656781
[  685.576922] Unable to handle kernel paging request at virtual address 6e656781
[  685.584253] Unable to handle kernel paging request at virtual address 6e656781
[  685.591586] Unable to handle kernel paging request at virtual address 6e656781
[  685.598918] Unable to handle kernel paging request at virtual address 6e656781
[  685.606250] Unable to handle kernel paging request at virtual address 6e656781
[  685.613580] Unable to handle kernel paging request at virtual address 6e656781
[  685.620913] Unable to handle kernel paging request at virtual address 6e656781
[  685.628244] Unable to handle kernel paging request at virtual address 6e656781
[  685.635575] Unable to handle kernel paging request at virtual address 6e656781
[  685.642908] Unable to handle kernel paging request at virtual address 6e656781
[  685.650239] Unable to handle kernel paging request at virtual address 6e656781
[  685.657570] Unable to handle kernel paging request at virtual address 6e656781
[  685.664901] Unable to handle kernel paging request at virtual address 6e656781
[  685.673731] ------------[ cut here ]------------
[  685.678464] WARNING: CPU: 0 PID: 0 at mm/vmacache.c:100 vmacache_find+0xd8/0xec
[  685.685882] Modules linked in: fuse rfcomm cmac bnep hci_uart bt
bcm bluetooth ?????j??k?,k??j??V]???(OC)-??(POFE)
carriba
Contact: ICQ
Re: No Wifi connection to Pi Zero W after Raspbian update
Fri Feb 23, 2018 4:36 pm
As a side note to the previous posts made: Having the Wifi AP device switched off and hooking up a Raspberry Pi Compatible USB-Ethernet Adapter on the 'USB On-The-Go' port of the RPI 0 W device allows the Raspbian Stretch OS working fine with the same configuration of having all the OS packages being updated and despite of no access to a Wifi AP. In my case, I'm using a Realtek RTL8152 Fast Ethernet Adapter with a USB MicroB OTG male to A female cable, and is connected to an IPv4 network.
The contents of the "/var/log/syslog file" looks like this:
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Booting Linux on physical CPU 0x0
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Linux version 4.9.59+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1047 Sun Oct 29 11:47:10 GMT 2017
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] cma: Reserved 8 MiB at 0x1b400000
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Memory policy: Data cache writeback
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] On node 0 totalpages: 114688
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] free_area_init_node: node 0, pgdat c0914e10, node_mem_map db010000
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]   Normal zone: 1008 pages used for memmap
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]   Normal zone: 0 pages reserved
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]   Normal zone: 114688 pages, LIFO batch:31
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] pcpu-alloc: [0] 0
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 113680
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:9E:23:52 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait logo.nologo plymouth.ignore-serial-consoless
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Memory: 435944K/458752K available (5950K kernel code, 491K rwdata, 1948K rodata, 396K init, 725K bss, 14616K reserved, 8192K cma-reserved)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] Virtual kernel memory layout:
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]     vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]     lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]       .text : 0xc0008000 - 0xc05d7a48   (5951 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]       .init : 0xc0841000 - 0xc08a4000   ( 396 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]       .data : 0xc08a4000 - 0xc091ef48   ( 492 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000]        .bss : 0xc091ef48 - 0xc09d4648   ( 726 kB)
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Feb 22 18:14:52 raspberrypi kernel: [    0.000000] NR_IRQS:16 nr_irqs:16 16
Feb 22 18:14:52 raspberrypi kernel: [    0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
Feb 22 18:14:52 raspberrypi kernel: [    0.000075] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
Feb 22 18:14:52 raspberrypi kernel: [    0.000177] bcm2835: system timer (irq = 27)
Feb 22 18:14:52 raspberrypi kernel: [    0.000649] Console: colour dummy device 80x30
Feb 22 18:14:52 raspberrypi kernel: [    0.001419] console [tty1] enabled
Feb 22 18:14:52 raspberrypi kernel: [    0.001482] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
Feb 22 18:14:52 raspberrypi kernel: [    0.060364] pid_max: default: 32768 minimum: 301
Feb 22 18:14:52 raspberrypi kernel: [    0.060833] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.060905] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.062202] Disabling memory control group subsystem
Feb 22 18:14:52 raspberrypi kernel: [    0.062413] CPU: Testing write buffer coherency: ok
Feb 22 18:14:52 raspberrypi kernel: [    0.062516] ftrace: allocating 21715 entries in 64 pages
Feb 22 18:14:52 raspberrypi kernel: [    0.180830] Setting up static identity map for 0x8200 - 0x8238
Feb 22 18:14:52 raspberrypi kernel: [    0.182903] devtmpfs: initialized
Feb 22 18:14:52 raspberrypi kernel: [    0.192713] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
Feb 22 18:14:52 raspberrypi kernel: [    0.193223] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Feb 22 18:14:52 raspberrypi kernel: [    0.193322] futex hash table entries: 256 (order: -1, 3072 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.194636] pinctrl core: initialized pinctrl subsystem
Feb 22 18:14:52 raspberrypi kernel: [    0.196165] NET: Registered protocol family 16
Feb 22 18:14:52 raspberrypi kernel: [    0.198723] DMA: preallocated 1024 KiB pool for atomic coherent allocations
Feb 22 18:14:52 raspberrypi kernel: [    0.208390] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
Feb 22 18:14:52 raspberrypi kernel: [    0.208485] hw-breakpoint: maximum watchpoint size is 4 bytes.
Feb 22 18:14:52 raspberrypi kernel: [    0.208624] Serial: AMBA PL011 UART driver
Feb 22 18:14:52 raspberrypi kernel: [    0.211578] bcm2835-mbox 2000b880.mailbox: mailbox enabled
Feb 22 18:14:52 raspberrypi kernel: [    0.212406] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
Feb 22 18:14:52 raspberrypi kernel: [    0.212941] irq: no irq domain found for /soc/aux@0x7e215000 !
Feb 22 18:14:52 raspberrypi kernel: [    0.262828] bcm2835-dma 20007000.dma: DMA legacy API manager at dc80d000, dmachans=0x1
Feb 22 18:14:52 raspberrypi kernel: [    0.265588] SCSI subsystem initialized
Feb 22 18:14:52 raspberrypi kernel: [    0.265921] usbcore: registered new interface driver usbfs
Feb 22 18:14:52 raspberrypi kernel: [    0.266110] usbcore: registered new interface driver hub
Feb 22 18:14:52 raspberrypi kernel: [    0.266356] usbcore: registered new device driver usb
Feb 22 18:14:52 raspberrypi kernel: [    0.270904] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-10-24 17:09
Feb 22 18:14:52 raspberrypi kernel: [    0.272967] clocksource: Switched to clocksource timer
Feb 22 18:14:52 raspberrypi kernel: [    0.327161] VFS: Disk quotas dquot_6.6.0
Feb 22 18:14:52 raspberrypi kernel: [    0.327361] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.327733] FS-Cache: Loaded
Feb 22 18:14:52 raspberrypi kernel: [    0.328123] CacheFiles: Loaded
Feb 22 18:14:52 raspberrypi kernel: [    0.347552] NET: Registered protocol family 2
Feb 22 18:14:52 raspberrypi kernel: [    0.348981] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.349140] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.349272] TCP: Hash tables configured (established 4096 bind 4096)
Feb 22 18:14:52 raspberrypi kernel: [    0.349407] UDP hash table entries: 256 (order: 0, 4096 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.349476] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    0.349836] NET: Registered protocol family 1
Feb 22 18:14:52 raspberrypi kernel: [    0.350645] RPC: Registered named UNIX socket transport module.
Feb 22 18:14:52 raspberrypi kernel: [    0.350720] RPC: Registered udp transport module.
Feb 22 18:14:52 raspberrypi kernel: [    0.350761] RPC: Registered tcp transport module.
Feb 22 18:14:52 raspberrypi kernel: [    0.350796] RPC: Registered tcp NFSv4.1 backchannel transport module.
Feb 22 18:14:52 raspberrypi kernel: [    0.352032] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
Feb 22 18:14:52 raspberrypi kernel: [    0.354715] workingset: timestamp_bits=14 max_order=17 bucket_order=3
Feb 22 18:14:52 raspberrypi kernel: [    0.375445] FS-Cache: Netfs 'nfs' registered for caching
Feb 22 18:14:52 raspberrypi kernel: [    0.377292] NFS: Registering the id_resolver key type
Feb 22 18:14:52 raspberrypi kernel: [    0.377402] Key type id_resolver registered
Feb 22 18:14:52 raspberrypi kernel: [    0.377446] Key type id_legacy registered
Feb 22 18:14:52 raspberrypi kernel: [    0.381949] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
Feb 22 18:14:52 raspberrypi kernel: [    0.382440] io scheduler noop registered
Feb 22 18:14:52 raspberrypi kernel: [    0.382506] io scheduler deadline registered (default)
Feb 22 18:14:52 raspberrypi kernel: [    0.383107] io scheduler cfq registered
Feb 22 18:14:52 raspberrypi kernel: [    0.389039] BCM2708FB: allocated DMA memory 5b500000
Feb 22 18:14:52 raspberrypi kernel: [    0.389174] BCM2708FB: allocated DMA channel 0 @ dc80d000
Feb 22 18:14:52 raspberrypi kernel: [    0.397444] Console: switching to colour frame buffer device 82x26
Feb 22 18:14:52 raspberrypi kernel: [    0.407411] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
Feb 22 18:14:52 raspberrypi kernel: [    0.411803] bcm2835-aux-uart 20215040.serial: could not get clk: -517
Feb 22 18:14:52 raspberrypi kernel: [    0.417091] bcm2835-rng 20104000.rng: hwrng registered
Feb 22 18:14:52 raspberrypi kernel: [    0.420599] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
Feb 22 18:14:52 raspberrypi kernel: [    0.428111] vc-sm: Videocore shared memory driver
Feb 22 18:14:52 raspberrypi kernel: [    0.456216] brd: module loaded
Feb 22 18:14:52 raspberrypi kernel: [    0.471977] loop: module loaded
Feb 22 18:14:52 raspberrypi kernel: [    0.475397] Loading iSCSI transport class v2.0-870.
Feb 22 18:14:52 raspberrypi kernel: [    0.479791] usbcore: registered new interface driver smsc95xx
Feb 22 18:14:52 raspberrypi kernel: [    0.483373] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
Feb 22 18:14:52 raspberrypi kernel: [    0.715107] Core Release: 2.80a
Feb 22 18:14:52 raspberrypi kernel: [    0.718454] Setting default values for core params
Feb 22 18:14:52 raspberrypi kernel: [    0.721688] Finished setting default values for core params
Feb 22 18:14:52 raspberrypi kernel: [    0.925347] Using Buffer DMA mode
Feb 22 18:14:52 raspberrypi kernel: [    0.928595] Periodic Transfer Interrupt Enhancement - disabled
Feb 22 18:14:52 raspberrypi kernel: [    0.931857] Multiprocessor Interrupt Enhancement - disabled
Feb 22 18:14:52 raspberrypi kernel: [    0.935236] OTG VER PARAM: 0, OTG VER FLAG: 0
Feb 22 18:14:52 raspberrypi kernel: [    0.938558] Dedicated Tx FIFOs mode
Feb 22 18:14:52 raspberrypi kernel: [    0.942288] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xdb514000 dma = 0x5b514000 len=9024
Feb 22 18:14:52 raspberrypi kernel: [    0.949021] FIQ FSM acceleration enabled for :
Feb 22 18:14:52 raspberrypi kernel: [    0.949021] Non-periodic Split Transactions
Feb 22 18:14:52 raspberrypi kernel: [    0.949021] Periodic Split Transactions
Feb 22 18:14:52 raspberrypi kernel: [    0.949021] High-Speed Isochronous Endpoints
Feb 22 18:14:52 raspberrypi kernel: [    0.949021] Interrupt/Control Split Transaction hack enabled
Feb 22 18:14:52 raspberrypi kernel: [    0.965457] dwc_otg: Microframe scheduler enabled
Feb 22 18:14:52 raspberrypi kernel: [    0.965596] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc0451694
Feb 22 18:14:52 raspberrypi kernel: [    0.968949] WARN::hcd_init_fiq:460: FIQ ASM at 0xc0451970 length 36
Feb 22 18:14:52 raspberrypi kernel: [    0.972226] WARN::hcd_init_fiq:486: MPHI regs_base at 0xdc8a5000
Feb 22 18:14:52 raspberrypi kernel: [    0.975525] dwc_otg 20980000.usb: DWC OTG Controller
Feb 22 18:14:52 raspberrypi kernel: [    0.978733] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
Feb 22 18:14:52 raspberrypi kernel: [    0.982006] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
Feb 22 18:14:52 raspberrypi kernel: [    0.985278] Init: Port Power? op_state=1
Feb 22 18:14:52 raspberrypi kernel: [    0.988458] Init: Power Port (0)
Feb 22 18:14:52 raspberrypi kernel: [    0.991850] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
Feb 22 18:14:52 raspberrypi kernel: [    0.995186] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Feb 22 18:14:52 raspberrypi kernel: [    0.998432] usb usb1: Product: DWC OTG Controller
Feb 22 18:14:52 raspberrypi kernel: [    1.001589] usb usb1: Manufacturer: Linux 4.9.59+ dwc_otg_hcd
Feb 22 18:14:52 raspberrypi kernel: [    1.004838] usb usb1: SerialNumber: 20980000.usb
Feb 22 18:14:52 raspberrypi kernel: [    1.009153] hub 1-0:1.0: USB hub found
Feb 22 18:14:52 raspberrypi kernel: [    1.012432] hub 1-0:1.0: 1 port detected
Feb 22 18:14:52 raspberrypi kernel: [    1.016656] dwc_otg: FIQ enabled
Feb 22 18:14:52 raspberrypi kernel: [    1.016667] dwc_otg: NAK holdoff enabled
Feb 22 18:14:52 raspberrypi kernel: [    1.016673] dwc_otg: FIQ split-transaction FSM enabled
Feb 22 18:14:52 raspberrypi kernel: [    1.016695] Module dwc_common_port init
Feb 22 18:14:52 raspberrypi kernel: [    1.017208] usbcore: registered new interface driver usb-storage
Feb 22 18:14:52 raspberrypi kernel: [    1.020927] mousedev: PS/2 mouse device common for all mice
Feb 22 18:14:52 raspberrypi kernel: [    1.025764] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
Feb 22 18:14:52 raspberrypi kernel: [    1.029594] bcm2835-cpufreq: min=700000 max=1000000
Feb 22 18:14:52 raspberrypi kernel: [    1.033491] sdhci: Secure Digital Host Controller Interface driver
Feb 22 18:14:52 raspberrypi kernel: [    1.036653] sdhci: Copyright(c) Pierre Ossman
Feb 22 18:14:52 raspberrypi kernel: [    1.040171] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
Feb 22 18:14:52 raspberrypi kernel: [    1.045975] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
Feb 22 18:14:52 raspberrypi kernel: [    1.049502] sdhci-pltfm: SDHCI platform and OF driver helper
Feb 22 18:14:52 raspberrypi kernel: [    1.053474] ledtrig-cpu: registered to indicate activity on CPUs
Feb 22 18:14:52 raspberrypi kernel: [    1.057004] hidraw: raw HID events driver (C) Jiri Kosina
Feb 22 18:14:52 raspberrypi kernel: [    1.060588] usbcore: registered new interface driver usbhid
Feb 22 18:14:52 raspberrypi kernel: [    1.064058] usbhid: USB HID core driver
Feb 22 18:14:52 raspberrypi kernel: [    1.068710] vchiq: vchiq_init_state: slot_zero = 0xdb580000, is_master = 0
Feb 22 18:14:52 raspberrypi kernel: [    1.074157] [vc_sm_connected_init]: start
Feb 22 18:14:52 raspberrypi kernel: [    1.084793] [vc_sm_connected_init]: end - returning 0
Feb 22 18:14:52 raspberrypi kernel: [    1.088831] Initializing XFRM netlink socket
Feb 22 18:14:52 raspberrypi kernel: [    1.092194] NET: Registered protocol family 17
Feb 22 18:14:52 raspberrypi kernel: [    1.095858] Key type dns_resolver registered
Feb 22 18:14:52 raspberrypi kernel: [    1.101012] registered taskstats version 1
Feb 22 18:14:52 raspberrypi kernel: [    1.113544] uart-pl011 20201000.serial: cts_event_workaround enabled
Feb 22 18:14:52 raspberrypi kernel: [    1.117155] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
Feb 22 18:14:52 raspberrypi kernel: [    1.126383] console [ttyS0] disabled
Feb 22 18:14:52 raspberrypi kernel: [    1.129946] 20215040.serial: ttyS0 at MMIO 0x0 (irq = 214, base_baud = 31250000) is a 16550
Feb 22 18:14:52 raspberrypi kernel: [    2.024781] console [ttyS0] enabled
Feb 22 18:14:52 raspberrypi kernel: [    2.033233] sdhost: log_buf @ db513000 (5b513000)
Feb 22 18:14:52 raspberrypi kernel: [    2.113047] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
Feb 22 18:14:52 raspberrypi kernel: [    2.124869] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
Feb 22 18:14:52 raspberrypi kernel: [    2.134435] mmc-bcm2835 20300000.mmc: DMA channel allocated
Feb 22 18:14:52 raspberrypi kernel: [    2.165072] Indeed it is in host mode hprt0 = 00021501
Feb 22 18:14:52 raspberrypi kernel: [    2.234735] random: fast init done
Feb 22 18:14:52 raspberrypi kernel: [    2.263276] of_cfs_init
Feb 22 18:14:52 raspberrypi kernel: [    2.273569] of_cfs_init: OK
Feb 22 18:14:52 raspberrypi kernel: [    2.282276] Waiting for root device /dev/mmcblk0p2...
Feb 22 18:14:52 raspberrypi kernel: [    2.298869] mmc0: host does not support reading read-only switch, assuming write-enable
Feb 22 18:14:52 raspberrypi kernel: [    2.315902] mmc0: overclocking to 83333333Hz
Feb 22 18:14:52 raspberrypi kernel: [    2.323919] mmc0: new high speed SDHC card at address 0001
Feb 22 18:14:52 raspberrypi kernel: [    2.334278] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    2.343845] mmcblk0: mmc0:0001 00000 29.8 GiB
Feb 22 18:14:52 raspberrypi kernel: [    2.354156]  mmcblk0: p1 p2
Feb 22 18:14:52 raspberrypi kernel: [    2.360467] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    2.372970] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    2.383099] usb 1-1: new high-speed USB device number 2 using dwc_otg
Feb 22 18:14:52 raspberrypi kernel: [    2.393430] Indeed it is in host mode hprt0 = 00001101
Feb 22 18:14:52 raspberrypi kernel: [    2.464121] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
Feb 22 18:14:52 raspberrypi kernel: [    2.475561] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
Feb 22 18:14:52 raspberrypi kernel: [    2.486484] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
Feb 22 18:14:52 raspberrypi kernel: [    2.611077] mmc1: new high speed SDIO card at address 0001
Feb 22 18:14:52 raspberrypi kernel: [    2.634919] usb 1-1: New USB device found, idVendor=0bda, idProduct=8152
Feb 22 18:14:52 raspberrypi kernel: [    2.645226] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb 22 18:14:52 raspberrypi kernel: [    2.655899] usb 1-1: Product: USB 10/100 LAN
Feb 22 18:14:52 raspberrypi kernel: [    2.663519] usb 1-1: Manufacturer: Realtek
Feb 22 18:14:52 raspberrypi kernel: [    2.670888] usb 1-1: SerialNumber: 00E04C362A46
Feb 22 18:14:52 raspberrypi kernel: [    3.080300] EXT4-fs (mmcblk0p2): recovery complete
Feb 22 18:14:52 raspberrypi kernel: [    3.125619] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Feb 22 18:14:52 raspberrypi kernel: [    3.140478] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Feb 22 18:14:52 raspberrypi kernel: [    3.151913] devtmpfs: mounted
Feb 22 18:14:52 raspberrypi kernel: [    3.159855] Freeing unused kernel memory: 396K
Feb 22 18:14:52 raspberrypi kernel: [    3.167872] This architecture does not have kernel memory protection.
Feb 22 18:14:52 raspberrypi kernel: [    3.663566] NET: Registered protocol family 10
Feb 22 18:14:52 raspberrypi kernel: [    3.695712] ip_tables: (C) 2000-2006 Netfilter Core Team
Feb 22 18:14:52 raspberrypi kernel: [    5.079778] random: crng init done
Feb 22 18:14:52 raspberrypi kernel: [    5.226386] i2c /dev entries driver
Feb 22 18:14:52 raspberrypi kernel: [    7.699948] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Feb 22 18:14:52 raspberrypi kernel: [   10.599959] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
Feb 22 18:14:52 raspberrypi kernel: [   12.049897] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
Feb 22 18:14:52 raspberrypi kernel: [   12.080494] usbcore: registered new interface driver brcmfmac
Feb 22 18:14:52 raspberrypi kernel: [   12.512907] brcmfmac: Firmware version = wl0: Oct 23 2017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
Feb 22 18:14:52 raspberrypi kernel: [   12.522027] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data: 9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:14
Feb 22 18:14:52 raspberrypi kernel: [   12.896708] Indeed it is in host mode hprt0 = 00001101
Feb 22 18:14:52 raspberrypi kernel: [   12.973712] usbcore: registered new interface driver r8152
Feb 22 18:14:52 raspberrypi kernel: [   13.134079] usbcore: registered new interface driver cdc_ether
Feb 22 18:14:52 raspberrypi kernel: [   13.373351] usb 1-1: reset high-speed USB device number 2 using dwc_otg
Feb 22 18:14:52 raspberrypi kernel: [   13.373721] Indeed it is in host mode hprt0 = 00001101
Feb 22 18:14:52 raspberrypi kernel: [   14.023451] r8152 1-1:1.0 eth0: v1.08.8
Feb 22 18:14:52 raspberrypi kernel: [   16.612514] uart-pl011 20201000.serial: no DMA platform data
Feb 22 18:14:52 raspberrypi cron[234]: (CRON) INFO (pidfile fd = 3)
Feb 22 18:14:52 raspberrypi systemd[1]: Reached target Basic System.
Feb 22 18:14:52 raspberrypi systemd[1]: Starting Configure Bluetooth Modems connected by UART...
Feb 22 18:14:52 raspberrypi systemd[1]: Started Regular background program processing daemon.
Feb 22 18:14:52 raspberrypi cron[234]: (CRON) INFO (Running @reboot jobs)
Feb 22 18:14:52 raspberrypi systemd[1]: Starting triggerhappy global hotkey daemon...
Feb 22 18:14:52 raspberrypi systemd[1]: Starting LSB: Switch to ondemand cpu governor (unless shift key is pressed)...
Feb 22 18:14:52 raspberrypi thd[237]: Found socket passed from systemd
Feb 22 18:14:52 raspberrypi systemd[1]: Starting Check for v3d driver...
Feb 22 18:14:52 raspberrypi systemd[1]: Starting dhcpcd on all interfaces...
Feb 22 18:14:52 raspberrypi systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb 22 18:14:52 raspberrypi systemd[1]: Starting Login Service...
Feb 22 18:14:52 raspberrypi systemd[1]: Starting LSB: Autogenerate and use a swap file...
Feb 22 18:14:52 raspberrypi dhcpcd[247]: dev: loaded udev
Feb 22 18:14:52 raspberrypi systemd[1]: Starting System Logging Service...
Feb 22 18:14:52 raspberrypi dhcpcd[247]: no valid interfaces found
Feb 22 18:14:52 raspberrypi systemd[1]: Started D-Bus System Message Bus.
Feb 22 18:14:52 raspberrypi dhcpcd[247]: forked to background, child pid 268
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: Found user 'avahi' (UID 108) and group 'avahi' (GID 112).
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: Successfully dropped root privileges.
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: avahi-daemon 0.6.32 starting up.
Feb 22 18:14:52 raspberrypi liblogging-stdlog:  [origin software="rsyslogd" swVersion="8.24.0" x-pid="260" x-info="http://www.rsyslog.com"] start
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: Successfully called chroot().
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: Successfully dropped remaining capabilities.
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: No service file found in /etc/avahi/services.
Feb 22 18:14:52 raspberrypi avahi-daemon[248]: Network interface enumeration completed.
Feb 22 18:14:52 raspberrypi dbus[264]: [system] Successfully activated service 'org.freedesktop.systemd1'
Feb 22 18:14:53 raspberrypi avahi-daemon[248]: Server startup complete. Host name is raspberrypi.local. Local service cookie is 2931426605.
Feb 22 18:14:53 raspberrypi systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 22 18:14:53 raspberrypi systemd[1]: Started triggerhappy global hotkey daemon.
Feb 22 18:14:53 raspberrypi systemd[1]: Started System Logging Service.
Feb 22 18:14:53 raspberrypi systemd[1]: Started Check for v3d driver.
Feb 22 18:14:53 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Feb 22 18:14:53 raspberrypi systemd[1]: Started Login Service.
Feb 22 18:14:53 raspberrypi dphys-swapfile[258]: Starting dphys-swapfile swapfile setup ...
Feb 22 18:14:54 raspberrypi raspi-config[238]: Checking if shift key is held down:Error opening '/dev/input/event*': No such file or directory
Feb 22 18:14:54 raspberrypi raspi-config[238]:  No. Switching to ondemand scaling governor.
Feb 22 18:14:54 raspberrypi systemd[1]: Started LSB: Switch to ondemand cpu governor (unless shift key is pressed).
Feb 22 18:14:54 raspberrypi dphys-swapfile[258]: want /var/swap=100MByte, checking existing: keeping it
Feb 22 18:14:54 raspberrypi systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Feb 22 18:14:54 raspberrypi systemd[1]: Started Raise network interfaces.
Feb 22 18:14:54 raspberrypi systemd[1]: Starting Load/Save RF Kill Switch Status...
Feb 22 18:14:54 raspberrypi systemd[1]: Reached target Network.
Feb 22 18:14:54 raspberrypi systemd[1]: Starting /etc/rc.local Compatibility...
Feb 22 18:14:54 raspberrypi systemd[1]: Starting OpenBSD Secure Shell server...
Feb 22 18:14:54 raspberrypi systemd[1]: Starting Permit User Sessions...
Feb 22 18:14:55 raspberrypi kernel: [   19.090783] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SSFS
Feb 22 18:14:55 raspberrypi dphys-swapfile[258]: done.
Feb 22 18:14:55 raspberrypi systemd[1]: Started LSB: Autogenerate and use a swap file.
Feb 22 18:14:55 raspberrypi systemd[1]: Started Permit User Sessions.
Feb 22 18:14:55 raspberrypi systemd[1]: Starting Light Display Manager...
Feb 22 18:14:56 raspberrypi systemd[1]: Started OpenBSD Secure Shell server.
Feb 22 18:14:56 raspberrypi systemd[1]: Started Load/Save RF Kill Switch Status.
Feb 22 18:14:56 raspberrypi systemd-udevd[145]: Process '/sbin/crda' failed with exit code 249.
Feb 22 18:14:56 raspberrypi dhcpcd-run-hooks[361]: wlan0: starting wpa_supplicant
Feb 22 18:14:56 raspberrypi lightdm[340]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb 22 18:14:57 raspberrypi systemd-udevd[145]: Process '/sbin/crda' failed with exit code 249.
Feb 22 18:14:57 raspberrypi kernel: [   21.248801] Bluetooth: Core ver 2.22
Feb 22 18:14:57 raspberrypi kernel: [   21.248979] NET: Registered protocol family 31
Feb 22 18:14:57 raspberrypi kernel: [   21.248989] Bluetooth: HCI device and connection manager initialized
Feb 22 18:14:57 raspberrypi kernel: [   21.249016] Bluetooth: HCI socket layer initialized
Feb 22 18:14:57 raspberrypi kernel: [   21.249032] Bluetooth: L2CAP socket layer initialized
Feb 22 18:14:57 raspberrypi kernel: [   21.249086] Bluetooth: SCO socket layer initialized
Feb 22 18:14:57 raspberrypi kernel: [   21.265679] Bluetooth: HCI UART driver ver 2.3
Feb 22 18:14:57 raspberrypi kernel: [   21.265697] Bluetooth: HCI UART protocol H4 registered
Feb 22 18:14:57 raspberrypi kernel: [   21.265704] Bluetooth: HCI UART protocol Three-wire (H5) registered
Feb 22 18:14:57 raspberrypi kernel: [   21.265884] Bluetooth: HCI UART protocol Broadcom registered
Feb 22 18:14:57 raspberrypi btuart[232]: bcm43xx_init
Feb 22 18:14:57 raspberrypi btuart[232]: Flash firmware /lib/firmware/BCM43430A1.hcd
Feb 22 18:14:57 raspberrypi btuart[232]: Set BDADDR UART: b8:27:eb:34:89:f8
Feb 22 18:14:57 raspberrypi btuart[232]: Set Controller UART speed to 3000000 bit/s
Feb 22 18:14:57 raspberrypi btuart[232]: Device setup complete
Feb 22 18:14:57 raspberrypi systemd[1]: Started Configure Bluetooth Modems connected by UART.
Feb 22 18:14:57 raspberrypi systemd[1]: Starting Bluetooth service...
Feb 22 18:14:57 raspberrypi systemd[1]: Received SIGRTMIN+21 from PID 150 (plymouthd).
Feb 22 18:14:57 raspberrypi systemd[1]: Started Light Display Manager.
Feb 22 18:14:57 raspberrypi systemd[1]: Started /etc/rc.local Compatibility.
Feb 22 18:14:57 raspberrypi systemd[1]: Starting Hold until boot process finishes up...
Feb 22 18:14:57 raspberrypi bluetoothd[376]: Bluetooth daemon 5.43
Feb 22 18:14:57 raspberrypi systemd[1]: Starting Terminate Plymouth Boot Screen...
Feb 22 18:14:57 raspberrypi systemd[1]: Started Hold until boot process finishes up.
Feb 22 18:14:57 raspberrypi bluetoothd[376]: Starting SDP server
Feb 22 18:14:57 raspberrypi systemd[1]: Started Terminate Plymouth Boot Screen.
Feb 22 18:14:58 raspberrypi kernel: [   22.142179] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Feb 22 18:14:58 raspberrypi kernel: [   22.142195] Bluetooth: BNEP filters: protocol multicast
Feb 22 18:14:58 raspberrypi kernel: [   22.142251] Bluetooth: BNEP socket layer initialized
Feb 22 18:14:58 raspberrypi bluetoothd[376]: Bluetooth management interface 1.14 initialized
Feb 22 18:14:58 raspberrypi dbus[264]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service'
Feb 22 18:14:58 raspberrypi bluetoothd[376]: Failed to obtain handles for "Service Changed" characteristic
Feb 22 18:14:58 raspberrypi bluetoothd[376]: Sap driver initialization failed.
Feb 22 18:14:58 raspberrypi bluetoothd[376]: sap-server: Operation not permitted (1)
Feb 22 18:14:58 raspberrypi kernel: [   22.381384] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Feb 22 18:14:58 raspberrypi kernel: [   22.381406] brcmfmac: power management disabled
Feb 22 18:14:58 raspberrypi systemd[1]: Started Bluetooth service.
Feb 22 18:14:58 raspberrypi systemd[1]: Starting Hostname Service...
Feb 22 18:14:58 raspberrypi systemd[1]: Started BluezALSA proxy.
Feb 22 18:14:58 raspberrypi systemd[1]: Started Serial Getty on ttyS0.
Feb 22 18:14:58 raspberrypi systemd[1]: Started Getty on tty1.
Feb 22 18:14:58 raspberrypi systemd[1]: Reached target Login Prompts.
Feb 22 18:14:58 raspberrypi systemd[1]: Reached target Multi-User System.
Feb 22 18:14:58 raspberrypi systemd[1]: Reached target Graphical Interface.
Feb 22 18:14:58 raspberrypi systemd[1]: Starting Update UTMP about System Runlevel Changes...
Feb 22 18:14:59 raspberrypi bluetoothd[376]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Source/1
Feb 22 18:14:59 raspberrypi bluetoothd[376]: Endpoint registered: sender=:1.6 path=/A2DP/SBC/Sink/1
Feb 22 18:14:59 raspberrypi kernel: [   23.403366] Bluetooth: RFCOMM TTY layer initialized
Feb 22 18:14:59 raspberrypi kernel: [   23.403406] Bluetooth: RFCOMM socket layer initialized
Feb 22 18:14:59 raspberrypi kernel: [   23.403442] Bluetooth: RFCOMM ver 1.11
Feb 22 18:14:59 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Feb 22 18:14:59 raspberrypi dbus[264]: [system] Successfully activated service 'org.freedesktop.hostname1'
Feb 22 18:14:59 raspberrypi systemd[1]: Reached target Bluetooth.
Feb 22 18:14:59 raspberrypi systemd[1]: Started Hostname Service.
Feb 22 18:14:59 raspberrypi systemd[1]: Startup finished in 3.435s (kernel) + 20.269s (userspace) = 23.705s.
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: waiting for carrier
Feb 22 18:15:00 raspberrypi dhcpcd[268]: eth0: waiting for carrier
Feb 22 18:15:00 raspberrypi kernel: [   24.518519] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: carrier acquired
Feb 22 18:15:00 raspberrypi kernel: [   24.538110] r8152 1-1:1.0 eth0: carrier on
Feb 22 18:15:00 raspberrypi kernel: [   24.541807] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Feb 22 18:15:00 raspberrypi systemd[1]: Created slice User Slice of pi.
Feb 22 18:15:00 raspberrypi systemd[1]: Starting User Manager for UID 1000...
Feb 22 18:15:00 raspberrypi dhcpcd[268]: DUID 00:01:00:01:21:b0:de:6b:b8:27:eb:cb:76:07
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: IAID eb:cb:76:07
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: adding address fe80::4e91:f879:f4de:8fe6
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: carrier lost
Feb 22 18:15:00 raspberrypi systemd[1]: Started Session c1 of user pi.
Feb 22 18:15:00 raspberrypi dhcpcd[268]: wlan0: deleting address fe80::4e91:f879:f4de:8fe6
Feb 22 18:15:00 raspberrypi dhcpcd[268]: eth0: carrier acquired
Feb 22 18:15:00 raspberrypi dhcpcd[268]: eth0: IAID 4c:36:2a:46
Feb 22 18:15:00 raspberrypi dhcpcd[268]: eth0: adding address fe80::bb3d:150a:eeb1:b798
Feb 22 18:15:00 raspberrypi dhcpcd[268]: eth0: carrier lost
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: deleting address fe80::bb3d:150a:eeb1:b798
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: carrier acquired
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: IAID 4c:36:2a:46
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: adding address fe80::bb3d:150a:eeb1:b798
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: rebinding lease of 192.168.0.38
Feb 22 18:15:01 raspberrypi dhcpcd[268]: eth0: probing address 192.168.0.38/24
Feb 22 18:15:01 raspberrypi systemd[430]: Reached target Timers.
Feb 22 18:15:01 raspberrypi systemd[430]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
Feb 22 18:15:01 raspberrypi systemd[430]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
Feb 22 18:15:01 raspberrypi systemd[430]: Listening on GnuPG cryptographic agent (access for web browsers).
Feb 22 18:15:01 raspberrypi systemd[430]: Listening on GnuPG cryptographic agent and passphrase cache.
Feb 22 18:15:01 raspberrypi systemd[430]: Starting D-Bus User Message Bus Socket.
Feb 22 18:15:01 raspberrypi systemd[430]: Reached target Paths.
Feb 22 18:15:01 raspberrypi systemd[430]: Listening on D-Bus User Message Bus Socket.
Feb 22 18:15:01 raspberrypi systemd[430]: Reached target Sockets.
Feb 22 18:15:01 raspberrypi systemd[430]: Reached target Basic System.
Feb 22 18:15:01 raspberrypi systemd[430]: Reached target Default.
Feb 22 18:15:01 raspberrypi systemd[430]: Startup finished in 745ms.
Feb 22 18:15:01 raspberrypi systemd[1]: Started User Manager for UID 1000.
Feb 22 18:15:02 raspberrypi dhcpcd[268]: eth0: soliciting an IPv6 router
Feb 22 18:15:02 raspberrypi avahi-daemon[248]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::bb3d:150a:eeb1:b798.
Feb 22 18:15:02 raspberrypi avahi-daemon[248]: New relevant interface eth0.IPv6 for mDNS.
Feb 22 18:15:02 raspberrypi avahi-daemon[248]: Registering new address record for fe80::bb3d:150a:eeb1:b798 on eth0.*.
Feb 22 18:15:03 raspberrypi lightdm[472]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
Feb 22 18:15:03 raspberrypi systemd[1]: Started Session c2 of user pi.
Feb 22 18:15:03 raspberrypi lightdm[340]: Error opening audit socket: Protocol not supported
Feb 22 18:15:04 raspberrypi systemd[430]: Started D-Bus User Message Bus.
Feb 22 18:15:06 raspberrypi dhcpcd[268]: eth0: leased 192.168.0.38 for 864000 seconds
Feb 22 18:15:06 raspberrypi avahi-daemon[248]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.0.38.
Feb 22 18:15:06 raspberrypi avahi-daemon[248]: New relevant interface eth0.IPv4 for mDNS.
Feb 22 18:15:06 raspberrypi avahi-daemon[248]: Registering new address record for 192.168.0.38 on eth0.IPv4.
Feb 22 18:15:06 raspberrypi dhcpcd[268]: eth0: adding route to 192.168.0.0/24
Feb 22 18:15:06 raspberrypi dhcpcd[268]: eth0: adding default route via 192.168.0.254
Feb 22 18:15:07 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service'
Feb 22 18:15:07 raspberrypi systemd[430]: Starting Virtual filesystem service...
Feb 22 18:15:07 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.Daemon'
Feb 22 18:15:07 raspberrypi systemd[430]: Started Virtual filesystem service.
Feb 22 18:15:07 raspberrypi kernel: [   31.753203] fuse init (API version 7.26)
Feb 22 18:15:07 raspberrypi systemd[1]: Mounting FUSE Control File System...
Feb 22 18:15:08 raspberrypi systemd[1]: Mounted FUSE Control File System.
Feb 22 18:15:10 raspberrypi dbus[264]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Feb 22 18:15:10 raspberrypi systemd[1]: Starting Authorization Manager...
Feb 22 18:15:10 raspberrypi polkitd[628]: started daemon version 0.105 using authority implementation `local' version `0.105'
Feb 22 18:15:10 raspberrypi dbus[264]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Feb 22 18:15:10 raspberrypi systemd[1]: Started Authorization Manager.
Feb 22 18:15:14 raspberrypi dhcpcd[268]: eth0: no IPv6 Routers available
Feb 22 18:15:18 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.UDisks2VolumeMonitor' unit='gvfs-udisks2-volume-monitor.service'
Feb 22 18:15:18 raspberrypi systemd[430]: Starting Virtual filesystem service - disk device monitor...
Feb 22 18:15:18 raspberrypi dbus[264]: [system] Activating via systemd: service name='org.freedesktop.UDisks2' unit='udisks2.service'
Feb 22 18:15:18 raspberrypi systemd[1]: Starting Disk Manager...
Feb 22 18:15:19 raspberrypi udisksd[665]: udisks daemon version 2.1.8 starting
Feb 22 18:15:20 raspberrypi dbus[264]: [system] Successfully activated service 'org.freedesktop.UDisks2'
Feb 22 18:15:20 raspberrypi systemd[1]: Started Disk Manager.
Feb 22 18:15:20 raspberrypi udisksd[665]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Feb 23 16:31:50 raspberrypi systemd-timesyncd[207]: Synchronized to time server 195.154.174.209:123 (2.europe.pool.ntp.org).
Feb 23 16:31:50 raspberrypi systemd[430]: Time has been changed
Feb 23 16:31:50 raspberrypi systemd[1]: Time has been changed
Feb 23 16:31:50 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.UDisks2VolumeMonitor'
Feb 23 16:31:50 raspberrypi systemd[430]: Started Virtual filesystem service - disk device monitor.
Feb 23 16:31:51 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.GPhoto2VolumeMonitor' unit='gvfs-gphoto2-volume-monitor.service'
Feb 23 16:31:51 raspberrypi systemd[430]: Starting Virtual filesystem service - digital camera monitor...
Feb 23 16:31:51 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.GPhoto2VolumeMonitor'
Feb 23 16:31:51 raspberrypi systemd[430]: Started Virtual filesystem service - digital camera monitor.
Feb 23 16:31:51 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.MTPVolumeMonitor' unit='gvfs-mtp-volume-monitor.service'
Feb 23 16:31:51 raspberrypi systemd[430]: Starting Virtual filesystem service - Media Transfer Protocol monitor...
Feb 23 16:31:51 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.MTPVolumeMonitor'
Feb 23 16:31:51 raspberrypi systemd[430]: Started Virtual filesystem service - Media Transfer Protocol monitor.
Feb 23 16:31:51 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.AfcVolumeMonitor' unit='gvfs-afc-volume-monitor.service'
Feb 23 16:31:51 raspberrypi systemd[430]: Starting Virtual filesystem service - Apple File Conduit monitor...
Feb 23 16:31:52 raspberrypi gvfs-afc-volume-monitor[683]: Volume monitor alive
Feb 23 16:31:52 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.AfcVolumeMonitor'
Feb 23 16:31:52 raspberrypi systemd[430]: Started Virtual filesystem service - Apple File Conduit monitor.
Feb 23 16:31:52 raspberrypi dbus-daemon[490]: Activating via systemd: service name='org.gtk.vfs.GoaVolumeMonitor' unit='gvfs-goa-volume-monitor.service'
Feb 23 16:31:52 raspberrypi systemd[430]: Starting Virtual filesystem service - GNOME Online Accounts monitor...
Feb 23 16:31:52 raspberrypi dbus-daemon[490]: Successfully activated service 'org.gtk.vfs.GoaVolumeMonitor'
Feb 23 16:31:52 raspberrypi systemd[430]: Started Virtual filesystem service - GNOME Online Accounts monitor.
Feb 23 16:32:36 raspberrypi systemd[1]: Started Session c3 of user pi.
From the console I can fire ifconfig -a showing that RPi 0 W is hooked up on the LAN (and no WLAN details as the Wifi AP is switched off):
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.38  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::bb3d:150a:eeb1:b798  prefixlen 64  scopeid 0x20<link>
        ether 00:e0:4c:36:2a:46  txqueuelen 1000  (Ethernet)
        RX packets 389  bytes 35055 (34.2 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 350  bytes 540540 (527.8 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 0  bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:cb:76:07  txqueuelen 1000  (Ethernet)
carriba
Contact: ICQ
Fri Feb 23, 2018 5:12 pm
jamesh wrote:
Fri Feb 23, 2018 11:53 am
Also, if you following the IP blacklisting here
viewtopic.php?f=63&t=204882&start=50#p1275508
Does that help?
I have modified "/boot/cmdline.txt" by disabling the IPv6 support with the command:
sudo sed -i 's/$/ ipv6.disable=1/' /boot/cmdline.txt
I hooked up the Ethernet adapter, and powered up the RPi 0 W device. Firing the ifconfig -a command shows:
        RX packets 61  bytes 7772 (7.5 KiB)
        TX packets 73  bytes 9802 (9.5 KiB)
Firing the dmesg command shows a line containing:
[    3.120879] IPv6: Loaded, but administratively disabled, reboot required to enable
Powering down the RPi 0 W device, unplugging the Ethernet adapter, and powering on the RPi 0 W device, I can quickly log in through the console, and firing the ifconfig -a command shows:
And in less then 3 seconds, I'm getting the same flood of messages on the console, and the RPi 0 W device hangs as described in previous posts.
Conclusion: Administratively disabling IPv6 does not change anything (at least for me). The RPi 0 W device keeps on crashing :-(
d_older
Sat Feb 24, 2018 12:09 am
Hi Carriba,
If I've followed your diagnosis correctly the fault only occurs when your ssid is hidden - is this correct?
In your posted wpa_supplicant.conf you don't have the scan_ssid=1 stanza usually required for such a setup - are you saying that with the previous firmware you connected to a hidden network without that line?
If added now does it affect the behaviour ?
Just trying to help.
Dave
RobertLoblaw89213783
Sat Feb 24, 2018 3:11 pm
Carriba,
Can you tell us what AP you have that you're connecting to wirelessly (make/model)?
Sat Feb 24, 2018 3:27 pm
I am having the EXACT same issue with a brand new Pi 3 model B:
Everything works perfectly until I do an "sudo apt-get update && sudo apt-get dist-upgrade". Once I do that and configure wifi, I run into serious issues. The RPi becomes unresponsive and kernel panics.
Like I said before, everything works fine if I don't upgrade. Everything also works fine if I upgrade but don't configure Wifi. I get the kernel panics after I upgrade AND configure Wifi. Based on that, the issue seems to be related to the latest wifi drivers and/or firmware.
To reproduce:
1. Flash SD card with Raspbian Lite
2. Copy "ssh" file to /boot, to enable SSH
3. SSH into RPi.
4. sudo apt-get update && sudo apt-get dist-upgrade
5. sudo reboot
6. sudo raspi-config
7. In raspi-config, configure Wifi by setting the SSID and password.
8. Several seconds later kernel panic
9. Reboot device, login prompt comes up, kernel panics follow.
My options are:
1. Never upgrade and use Wifi. As long as I don't upgrade, I can use Wifi.
OR
2. Upgrade but don't use Wifi. As long as I don't use Wifi, I can run with the latest patches.
HOWEVER.... After reading these posts, I discovered another solution:
My SSID that I'm connecting to is not broadcasted. If I make it broadcast, this problem goes away, meaning that I can use the latest updates AND use wifi.
Conclusion:
There is a serious bug in the LATEST wifi firmware / drivers that causes kernel panics if you try to connect to an SSID that isn't being broadcasted. I confirmed this by doing the following:
1. Ensure SSID is broadcasting.
2. Install Raspbian Lite, update everything with apt-get.
3. Connect to broadcasted SSID.
4. Start using it, everything works.
5. Disable broadcasted SSID on the AP.
6. Reboot the Rpi, after it reboots, it kernel panics within a minute
7. Enable the broadcasted SSID on the AP
8. Reboot the Rpi, after it reboots, it works, and continues working.
I am curious as to what kind of access point carriba is using, because I am wondering if it has something to do with the way the wireless frames are being generated. I am using a Unifi AP AC-Pro.
Dflex
Sat Feb 24, 2018 3:58 pm
The new firmware crashes Raspbian even if the SSID is not disabled. It is necessary only for the Wi-Fi connection to be lost, then restored. The fault is seen with an ASUS access point and with a recent Motorola Android phone (configured for "tethering"). I have given details here: viewtopic.php?f=66&t=205485.
The fault is not intermittent: it always crashes Raspbian. That should be a usable starting point for resolution by the firmware writer.
If the broken firmware enters the next "image" release of Raspbian then the whole image will be worthless unless a fix is released after that: we'll have to stay with the November 2017 version and suppress updates to the broken firmware module.
The new driver seems to have been subjected to extremely limited testing. A request for volunteer testers went out on 24th January: viewtopic.php?t=203508, yet the module appeared in an update only a few days later.
ShiftPlusOne
Sat Feb 24, 2018 5:50 pm
Dflex wrote: The new driver seems to have been subjected to extremely limited testing. A request for volunteer testers went out on 24th January: viewtopic.php?t=203508, yet the module appeared in an update only a few days later.
To be fair, it was two weeks, not a few days and the feedback was that it has resolved other issues for people.
There's a limited number of people who would be willing to do testing, so some issues only come out once the firmware goes out to more people, no matter how long you leave it up beforehand.
You're right in that we may have to roll back if we see more people having problems and don't get a fix from the manufacturer beforehand.
Sat Feb 24, 2018 10:24 pm
Is there a way to go back to the previous version of the firmware with apt-get? I'd like to install the version before the latest, since the latest has serious issues.
Additionally, it would be nice to know what if any security vulnerabilities were resolved in the latest firmware. I'd hate to go back to a stable version but then be exposed to security bugs.
I'd prefer to do this without reinstalling Rasbian....
ShiftPlusOne
Sat Feb 24, 2018 10:38 pm
Try this:
wget http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpi2_all.deb
sudo dpkg -i firmware-brcm80211_20161130-3+rpi2_all.deb
Sat Feb 24, 2018 11:46 pm
Thanks for that link.
Looking at the directory, I see that there are rpi and rpt packages:
example:
[ ] firmware-brcm80211_20161130-3+rpi2_all.deb 07-Feb-2018 12:26 3.4M
[ ] firmware-brcm80211_20161130-3+rpt1_all.deb 07-Feb-2018 12:37 3.4M
Whats does rpi2 vs rpt1 mean? I imagine they are for the different versions of the Rpi, but I don't know which one would correspond with what model...
ShiftPlusOne
Sun Feb 25, 2018 12:33 am
No, that doesn't mean anything. We used to add +rpiN to packages we modified where N is the revision of our modification. Since raspbian.org also uses the same approach and we have clashing names, I'm changing rpi to rpt. rpt packages are newer than rpi packages.
carriba
Contact: ICQ
Mon Feb 26, 2018 11:52 am
If added now does it affect the behaviour?
Yes, the symptoms of a "no access to a Wifi AP" always occur when the SSID is not being broadcasted; situation of "hidden network". I've tested this against to different Wifi AP devices of different vendors.
I've followed the reocmmendation to add the parameter "scan_ssid=1" and thus the contents of the "wpa_supplicant.conf" text file looks now similar to this:
update_config=1
scan_ssid=1
country=GB
network={
	ssid="MyWifiNetworkSSID"
	psk="password"
	key_mgmt=WPA-PSK
And this setup causes the Raspbian OS to crash, too.
On the console port, I kept a "sudo tail -f /var/log/syslog" running to see whether anything else is being protocolled, and am getting this before a complete freezing of the console output:
[  312.233275] Unable to handle kernel paging request at virtual address 000e1363
[  312.241175] Unable to handle kernel paging request at virtual address 00edf03d
[  312.249072] Unable to handle kernel paging request at virtual address 00edf037
[  312.258165] Unable to handle kernel paging request at virtual address 004d9b45
[  312.266112] Unable to handle kernel paging request at virtual address 008a82d1
[  312.281236] Unable to handle kernel paging request at virtual address dd38d000
[  312.288583] pgd =   (null)
[  312.291342] Unable to handle kernel paging request at virtual address 00003748
[  312.298673] pgd =   (null)
[  312.301427] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.309639] pgd =   (null)
[  312.312389] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.320602] pgd =   (null)
[  312.323352] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.331563] pgd =   (null)
[  312.334313] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.342524] pgd =   (null)
[  312.345279] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.353490] pgd =   (null)
[  312.356240] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  312.364451] pgd =   (null)
carriba
Contact: ICQ
Mon Feb 26, 2018 12:10 pm
I am curious as to what kind of access point Carriba is using, because I am wondering if it has something to do with the way the wireless frames are being generated. I am using a Unifi AP AC-Pro.
This describes the same situation that I'm facing, too.
As Wifi AP devices, I'm using an "Apple AirPort Express 802.11n 1st Generation" and a "TP-Link TL-WPA4220 300Mbps AV500 Wi-Fi Powerline Extender". Both AP devices are setup in a default Ethernet-to-Wireless Bridge mode (no NATting or any other specific setup).
For my testing, I always used one Wifi AP device at a time, never both together. All other Wifi devices work fine with either of the mentioned Wifi AP devices in an IPv4 LAN setup. Both Wifi APs use the same SSID setup (same WLAN identifier & same access password).
carriba
Contact: ICQ
Mon Feb 26, 2018 1:18 pm
Here the console output when adding parameter "scan_ssid=1" in the "wpa_supplicant.conf" text file when using different Wifi APs and having setup the SSID broacast to be disabled, to speak, "hidden network":
[  371.344307] Unable to handle kernel paging request at virtual address 007371c7
[  371.351688] Unable to handle kernel paging request at virtual address 17380036
[  371.359051] Unable to handle kernel paging request at virtual address 17380036
[  371.366412] Unable to handle kernel paging request at virtual address 17380036
[  371.373773] Unable to handle kernel paging request at virtual address 17380036
[  371.381131] Unable to handle kernel paging request at virtual address 17380036
[  371.388489] Unable to handle kernel paging request at virtual address 17380036
[  371.395849] Unable to handle kernel paging request at virtual address 17380036
[  371.403210] Unable to handle kernel paging request at virtual address 17380036
[  371.410569] Unable to handle kernel paging request at virtual address 17380036
[  371.417927] Unable to handle kernel paging request at virtual address 17380036
[  371.425287] Unable to handle kernel paging request at virtual address 17380036
[  371.432646] Unable to handle kernel paging request at virtual address 17380036
[  371.440007] Unable to handle kernel paging request at virtual address 17380036
[  371.447368] Unable to handle kernel paging request at virtual address 17380036
[  371.454726] Unable to handle kernel paging request at virtual address 17380036
[  371.462086] Unable to handle kernel paging request at virtual address 17380036
[  371.469444] Unable to handle kernel paging request at virtual address 17380036
[  371.476804] Unable to handle kernel paging request at virtual address 17380036
[  371.484163] Unable to handle kernel paging request at virtual address 17380036
[  371.491520] Unable to handle kernel paging request at virtual address 0d243820
[  371.498881] Unable to handle kernel paging request at virtual address 0d243820
[  371.506240] Unable to handle kernel paging request at virtual address 0d243820
[  371.513598] Unable to handle kernel paging request at virtual address 0d243820
[  371.520957] Unable to handle kernel paging request at virtual address 0d243820
[  371.528317] Unable to handle kernel paging request at virtual address 0d243820
[  371.535676] Unable to handle kernel paging request at virtual address 0d243820
[  371.543035] Unable to handle kernel paging request at virtual address 0d243820
[  371.550395] Unable to handle kernel paging request at virtual address 0d243820
[  371.557753] Unable to handle kernel paging request at virtual address 0d243820
[  371.565112] Unable to handle kernel paging request at virtual address 0d243820
[  371.572470] Unable to handle kernel paging request at virtual address 0d243820
[  371.579828] Unable to handle kernel paging request at virtual address 0d243820
[  371.587187] Unable to handle kernel paging request at virtual address 0d243820
[  371.594546] Unable to handle kernel paging request at virtual address 0d243820
[  371.601906] Unable to handle kernel paging request at virtual address 0d243820
[  371.609263] Unable to handle kernel paging request at virtual address 0d243820
[  371.616623] Unable to handle kernel paging request at virtual address 0d243820
[  371.624020] Unable to handle kernel paging request at virtual address 00070d5f
[  371.631378] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.639617] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.647858] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.656098] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.664336] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.672573] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.680811] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.689048] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.697288] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.705527] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.713765] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.722005] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.730244] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.738482] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.746720] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.754960] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.763201] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.771441] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.779679] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.787918] Unable to handle kernel NULL pointer dereference at virtual address 00000021
[  371.796193] Unable to handle kernel paging request at virtual address 00080e60
[  371.803545] pgd = c0004000
[  371.806314] [00080e60] *pgd=00000000
[  371.809990] Unable to handle kernel paging request at virtual address 000e1c19
[  371.817343] pgd = c0004000
[  371.820111] [000e1c19] *pgd=00000000
[  371.823779] Unable to handle kernel paging request at virtual address 000e1c19
[  371.831129] pgd = c0004000
[  371.833895] [000e1c19] *pgd=00000000
[  371.837561] Unable to handle kernel paging request at virtual address 000e1c19
[  371.844914] pgd = c0004000
[  371.847680] [000e1c19] *pgd=00000000
[  371.851347] Unable to handle kernel paging request at virtual address 000e1c19
[  371.858700] pgd = c0004000
[  371.861468] [000e1c19] *pgd=00000000
[  371.865131] Unable to handle kernel paging request at virtual address 000e1c19
[  371.872483] pgd = c0004000
[  371.875252] [000e1c19] *pgd=00000000
[  371.878921] Unable to handle kernel paging request at virtual address 000e1c19
[  371.886272] pgd = c0004000
[  371.889039] [000e1c19] *pgd=00000000
[  371.892706] Unable to handle kernel paging request at virtual address 000e1c19
[  371.900057] pgd = c0004000
[  371.902825] [000e1c19] *pgd=00000000
[  371.906493] Unable to handle kernel paging request at virtual address 000e1c19
[  371.913843] pgd = c0004000
[  371.916611] [000e1c19] *pgd=00000000
[  371.920275] Unable to handle kernel paging request at virtual address 000e1c19
[  371.927627] pgd = c0004000
[  371.930393] [000e1c19] *pgd=00000000
[  371.934055] Unable to handle kernel paging request at virtual address 000e1c19
[  371.941407] pgd = c0004000
[  371.944174] [000e1c19] *pgd=00000000
[  371.947839] Unable to handle kernel paging request at virtual address 000e1c19
[  371.955191] pgd = c0004000
[  371.957958] [000e1c19] *pgd=00000000
[  371.961624] Unable to handle kernel paging request at virtual address 000e1c19
[  371.968976] pgd = c0004000
[  371.971743] [000e1c19] *pgd=00000000
[  371.975407] Unable to handle kernel paging request at virtual address 000e1c19
[  371.982760] pgd = c0004000
[  371.985525] [000e1c19] *pgd=00000000
[  371.989186] ------------[ cut here ]------------
[  371.993903] Unable to handle kernel NULL pointer dereference at virtual address 000002b8
[  372.002144] Unable to handle kernel paging request at virtual address 00070020
[  372.009502] Unable to handle kernel paging request at virtual address 00070020
[  372.016862] Unable to handle kernel paging request at virtual address 00070020
[  372.024219] Unable to handle kernel paging request at virtual address 00070020
[  372.031577] Unable to handle kernel paging request at virtual address 00070020
[  372.038934] Unable to handle kernel paging request at virtual address 00070020
[  372.046294] Unable to handle kernel paging request at virtual address 00070020
[  372.053652] Unable to handle kernel paging request at virtual address 00070020
[  372.061010] Unable to handle kernel paging request at virtual address 00070020
[  372.068370] Unable to handle kernel paging request at virtual address 00070020
[  372.075727] Unable to handle kernel paging request at virtual address 00070020
[  372.083085] Unable to handle kernel paging request at virtual address 00070020
[  372.090442] Unable to handle kernel paging request at virtual address 00070020
[  372.097800] Unable to handle kernel paging request at virtual address 00070020
[  372.105158] Unable to handle kernel paging request at virtual address 00070020
[  372.112517] Unable to handle kernel paging request at virtual address 00070020
[  372.119875] Unable to handle kernel paging request at virtual address 00070020
[  372.127234] Unable to handle kernel paging request at virtual address 00070020
[  372.134594] Unable to handle kernel paging request at virtual address 00070020
[  372.141954] Unable to handle kernel NULL pointer dereference at virtual address 00000251
[  372.150188] pgd = c0004000
[  372.152954] [00000251] *pgd=00000000
[  372.156622] Unable to handle kernel paging request at virtual address 001d2924
[  372.163975] pgd = c0004000
[  372.166742] [001d2924] *pgd=00000000
[  372.170409] Unable to handle kernel paging request at virtual address 001d2924
[  372.177760] pgd = c0004000
[  372.180526] [001d2924] *pgd=00000000
[  372.184190] Unable to handle kernel paging request at virtual address 001d2924
[  372.191543] pgd = c0004000
[  372.194310] [001d2924] *pgd=00000000
[  372.197976] Unable to handle kernel paging request at virtual address 001d2924
[  372.205329] pgd = c0004000
[  372.208096] [001d2924] *pgd=00000000
[  372.211763] Unable to handle kernel paging request at virtual address 001d2924
[  372.219115] pgd = c0004000
[  372.221883] [001d2924] *pgd=00000000
[  372.225552] Unable to handle kernel paging request at virtual address 001d2924
[  372.232902] pgd = c0004000
[  372.235671] [001d2924] *pgd=00000000
[  372.239337] Unable to handle kernel paging request at virtual address 001d2924
[  372.246689] pgd = c0004000
[  372.249456] [001d2924] *pgd=00000000
[  372.253120] Unable to handle kernel paging request at virtual address 001d2924
[  372.260474] pgd = c0004000
[  372.263242] [001d2924] *pgd=00000000
[  372.266905] Unable to handle kernel paging request at virtual address 001d2924
[  372.274258] pgd = c0004000
[  372.277026] [001d2924] *pgd=00000000
[  372.280691] Unable to handle kernel paging request at virtual address 001d2924
[  372.288042] pgd = c0004000
[  372.290808] [001d2924] *pgd=00000000
[  372.294475] Unable to handle kernel paging request at virtual address 001d2924
[  372.301827] pgd = c0004000
[  372.304594] [001d2924] *pgd=00000000
[  372.308262] Unable to handle kernel paging request at virtual address 001d2924
[  372.315613] pgd = c0004000
[  372.318380] [001d2924] *pgd=00000000
[  372.322048] Unable to handle kernel paging request at virtual address 001d2924
[  372.329400] pgd = c0004000
[  372.332167] [001d2924] *pgd=00000000
[  372.335646] ------------[ cut here ]------------
[  372.340472] Unable to handle kernel paging request at virtual address 0004095a
[  372.347832] Unable to handle kernel paging request at virtual address 08000d44
[  372.355191] Unable to handle kernel paging request at virtual address 08000d44
[  372.362552] Unable to handle kernel paging request at virtual address 08000d44
[  372.369913] Unable to handle kernel paging request at virtual address 08000d44
[  372.377271] Unable to handle kernel paging request at virtual address 08000d44
[  372.384631] Unable to handle kernel paging request at virtual address 08000d44
[  372.391990] Unable to handle kernel paging request at virtual address 08000d44
[  372.399350] Unable to handle kernel paging request at virtual address 08000d44
[  372.406707] Unable to handle kernel paging request at virtual address 08000d44
[  372.414066] Unable to handle kernel paging request at virtual address 08000d44
[  372.421425] Unable to handle kernel paging request at virtual address 08000d44
[  372.428784] Unable to handle kernel paging request at virtual address 08000d44
[  372.436144] Unable to handle kernel paging request at virtual address 08000d44
[  372.443506] Unable to handle kernel paging request at virtual address 08000d44
[  372.450866] Unable to handle kernel paging request at virtual address 08000d44
[  372.458227] Unable to handle kernel paging request at virtual address 08000d44
[  372.465585] Unable to handle kernel paging request at virtual address 08000d44
[  372.472985] Unable to handle kernel paging request at virtual address 002e2873
[  372.480336] pgd = c0004000
[  372.483103] [002e2873] *pgd=00000000
[  372.486774] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.494127] pgd = c0004000
[  372.496893] [000e1d1c] *pgd=00000000
[  372.500561] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.507913] pgd = c0004000
[  372.510680] [000e1d1c] *pgd=00000000
[  372.514344] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.521696] pgd = c0004000
[  372.524464] [000e1d1c] *pgd=00000000
[  372.528129] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.535482] pgd = c0004000
[  372.538250] [000e1d1c] *pgd=00000000
[  372.541913] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.549265] pgd = c0004000
[  372.552033] [000e1d1c] *pgd=00000000
[  372.555695] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.563047] pgd = c0004000
[  372.565814] [000e1d1c] *pgd=00000000
[  372.569478] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.576831] pgd = c0004000
[  372.579598] [000e1d1c] *pgd=00000000
[  372.583267] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.590618] pgd = c0004000
[  372.593384] [000e1d1c] *pgd=00000000
[  372.597048] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.604401] pgd = c0004000
[  372.607168] [000e1d1c] *pgd=00000000
[  372.610835] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.618188] pgd = c0004000
[  372.620954] [000e1d1c] *pgd=00000000
[  372.624623] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.631975] pgd = c0004000
[  372.634742] [000e1d1c] *pgd=00000000
[  372.638410] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.645762] pgd = c0004000
[  372.648530] [000e1d1c] *pgd=00000000
[  372.652195] Unable to handle kernel paging request at virtual address 000e1d1c
[  372.659546] pgd = c0004000
[  372.662314] [000e1d1c] *pgd=00000000
[  372.665794] ------------[ cut here ]------------
carriba
Contact: ICQ
Re: No Wifi connection to Pi Zero W after Raspbian update
Mon Feb 26, 2018 1:20 pm
Here a much more detailled console output trying to reproduce the same situation under the same conditions as elaborated in previous posts:
[  372.670512] Unable to handle kernel NULL pointer dereference at virtual address 000002b8
[  372.678745] pgd = c0004000
[  372.681515] [000002b8] *pgd=00000000
[  372.685182] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.692533] pgd = c0004000
[  372.695302] [000e1e1b] *pgd=00000000
[  372.698965] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.706315] pgd = c0004000
[  372.709083] [000e1e1b] *pgd=00000000
[  372.712746] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.720098] pgd = c0004000
[  372.722867] [000e1e1b] *pgd=00000000
[  372.726530] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.733883] pgd = c0004000
[  372.736650] [000e1e1b] *pgd=00000000
[  372.740317] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.747671] pgd = c0004000
[  372.750436] [000e1e1b] *pgd=00000000
[  372.754103] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.761455] pgd = c0004000
[  372.764220] [000e1e1b] *pgd=00000000
[  372.767885] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.775238] pgd = c0004000
[  372.778005] [000e1e1b] *pgd=00000000
[  372.781669] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.789021] pgd = c0004000
[  372.791789] [000e1e1b] *pgd=00000000
[  372.795464] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.802817] pgd = c0004000
[  372.805584] [000e1e1b] *pgd=00000000
[  372.809252] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.816603] pgd = c0004000
[  372.819369] [000e1e1b] *pgd=00000000
[  372.823034] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.830385] pgd = c0004000
[  372.833152] [000e1e1b] *pgd=00000000
[  372.836819] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.844173] pgd = c0004000
[  372.846943] [000e1e1b] *pgd=00000000
[  372.850611] Unable to handle kernel paging request at virtual address 000e1e1b
[  372.857962] pgd = c0004000
[  372.860730] [000e1e1b] *pgd=00000000[  372.865149] Unable to handle kernel paging request at virtual address 00edf03d
[  372.874298] Unable to handle kernel paging request at virtual address 00edf03d
[  372.882209] Unable to handle kernel paging request at virtual address 00e2dd2a
[  372.898343] Unable to handle kernel paging request at virtual address dd32b004
[  372.905683] pgd = c0004000
[  372.908430] [dd32b004] *pgd=193eb811, *pte=00000000, *ppte=00000000
[  372.914815] Internal error: Oops: 807 [#1] ARM
[  372.919331] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
fixed i2c_dev ip_tables x_tables ipv6
[  372.936200] CPU: 0 PID: 0 Comm:  Not tainted 4.9.59+ #1047
[  372.941773] Hardware name: BCM2835
[  372.945231] task: d909b880 task.stack:   (null)
[  372.949848] PC is at __dabt_svc+0xc/0x80
[  372.953840] LR is at do_translation_fault+0x7c/0xb4
[  372.958796] pc : [<c05d568c>]    lr : [<c05d61ec>]    psr: 68050193
[  372.958796] sp : dd32b004  ip : dd3b0000  fp : dd3b1fd4
[  372.970448] r10: 00000000  r9 : dd3b0000  r8 : dd3b20a8
[  372.975752] r7 : dd3b1044  r6 : ffffffff  r5 : 28050193  r4 : c05d56b8
[  372.982377] r3 : c05d61ec  r2 : dd3b1060  r1 : 00000005  r0 : c091f0ac
[  372.989003] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  372.996335] Control: 00c5387d  Table: 1861c008  DAC: 00000055
[  373.002167] Process  (pid: 0, stack limit = 0x00000188)
[  373.007473] Stack: (0xdd32b004 to 0x00002000)
[  373.011916] Unable to handle kernel paging request at virtual address dd32b004
[  373.019249] pgd = c0004000
[  373.021993] [dd32b004] *pgd=193eb811, *pte=00000000, *ppte=00000000
[  373.028376] Internal error: Oops: 7 [#2] ARM
[  373.032709] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  373.049564] CPU: 0 PID: 0 Comm:  Not tainted 4.9.59+ #1047
[  373.055136] Hardware name: BCM2835
[  373.058591] task: d909b880 task.stack:   (null)
[  373.063203] PC is at unwind_frame+0x40c/0x5b0
[  373.067630] LR is at 0xdd32c000
[  373.070821] pc : [<c0015fa4>]    lr : [<dd32c000>]    psr: 68050193
[  373.070821] sp : dd32ad60  ip : 00000000  fp : dd32ade4
[  373.082472] r10: d909b880  r9 : 00000807  r8 : c05d568c
[  373.087775] r7 : 00000000  r6 : 00000001  r5 : dd32ade8  r4 : dd32b004
[  373.094400] r3 : dd32ad64  r2 : dd32ad64  r1 : dd32b004  r0 : 0000000f
[  373.101030] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  373.108361] Control: 00c5387d  Table: 1861c008  DAC: 00000055
[  373.114192] Process  (pid: 0, stack limit = 0x00000188)
[  373.119495] Stack: (0xdd32ad60 to 0x00002000)
[  373.123938] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.132094] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.139533] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.147588] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.156607] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.164391] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.171898] Exception stack(0xdd32afb0 to 0xdd32aff8)
[  373.177030] afa0:                                     c091f0ac 00000005 dd3b1060 c05d61ec
[  373.185340] afc0: c05d56b8 28050193 ffffffff dd3b1044 dd3b20a8 dd3b0000 00000000 dd3b1fd4
[  373.193645] afe0: dd3b0000 dd32b004 c05d61ec c05d568c 68050193 ffffffff
[  373.200369] [<c05d56d4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  373.207627] Unable to handle kernel paging request at virtual address dd32b004
[  373.214959] pgd = c0004000
[  373.217704] [dd32b004] *pgd=193eb811, *pte=00000000, *ppte=00000000
[  373.224088] Internal error: Oops: 7 [#3] ARM
[  373.228422] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  373.245283] CPU: 0 PID: 0 Comm:  Not tainted 4.9.59+ #1047
[  373.250855] Hardware name: BCM2835
[  373.254310] task: d909b880 task.stack:   (null)
[  373.258919] PC is at unwind_frame+0x40c/0x5b0
[  373.263344] LR is at 0xdd32c000
[  373.266535] pc : [<c0015fa4>]    lr : [<dd32c000>]    psr: 68050193
[  373.266535] sp : dd32aac0  ip : 00000000  fp : dd32ab44
[  373.278186] r10: d909b880  r9 : 00000007  r8 : c05d568c
[  373.283490] r7 : 00000000  r6 : 00000001  r5 : dd32ab48  r4 : dd32b004
[  373.290114] r3 : dd32aac4  r2 : dd32aac4  r1 : dd32b004  r0 : 0000000f
[  373.296740] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  373.304072] Control: 00c5387d  Table: 1861c008  DAC: 00000055
[  373.309907] Process  (pid: 0, stack limit = 0x00000188)
[  373.315210] Stack: (0xdd32aac0 to 0x00002000)
[  373.319648] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.327797] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.335239] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.343291] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.352310] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.360096] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.367604] Exception stack(0xdd32ad10 to 0xdd32ad58)
[  373.372735] ad00:                                     0000000f dd32b004 dd32ad64 dd32ad64
[  373.381044] ad20: dd32b004 dd32ade8 00000001 00000000 c05d568c 00000807 d909b880 dd32ade4
[  373.389350] ad40: 00000000 dd32ad60 dd32c000 c0015fa4 68050193 ffffffff
[  373.396076] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  373.403773] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.411911] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.419344] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.427396] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.436418] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.444202] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.451710] Exception stack(0xdd32afb0 to 0xdd32aff8)
[  373.456842] afa0:                                     c091f0ac 00000005 dd3b1060 c05d61ec
[  373.465150] afc0: c05d56b8 28050193 ffffffff dd3b1044 dd3b20a8 dd3b0000 00000000 dd3b1fd4
[  373.473457] afe0: dd3b0000 dd32b004 c05d61ec c05d568c 68050193 ffffffff
[  373.480181] [<c05d56d4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  373.487442] Unable to handle kernel paging request at virtual address dd32b004
[  373.494773] pgd = c0004000
[  373.497518] [dd32b004] *pgd=193eb811, *pte=00000000, *ppte=00000000
[  373.503905] Internal error: Oops: 7 [#4] ARM
[  373.508237] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  373.525099] CPU: 0 PID: 0 Comm:  Not tainted 4.9.59+ #1047
[  373.530667] Hardware name: BCM2835
[  373.534122] task: d909b880 task.stack:   (null)
[  373.538733] PC is at unwind_frame+0x40c/0x5b0
[  373.543157] LR is at 0xdd32c000
[  373.546349] pc : [<c0015fa4>]    lr : [<dd32c000>]    psr: 68050193
[  373.546349] sp : dd32a820  ip : 00000000  fp : dd32a8a4
[  373.558002] r10: d909b880  r9 : 00000007  r8 : c05d568c
[  373.563303] r7 : 00000000  r6 : 00000001  r5 : dd32a8a8  r4 : dd32b004
[  373.569927] r3 : dd32a824  r2 : dd32a824  r1 : dd32b004  r0 : 0000000f
[  373.576556] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment user
[  373.583887] Control: 00c5387d  Table: 1861c008  DAC: 00000055
[  373.589720] Process  (pid: 0, stack limit = 0x00000188)
[  373.595023] Stack: (0xdd32a820 to 0x00002000)
[  373.599461] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.607603] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.615037] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.623088] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.632108] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.639890] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.647398] Exception stack(0xdd32aa70 to 0xdd32aab8)
[  373.652528] aa60:                                     0000000f dd32b004 dd32aac4 dd32aac4
[  373.660835] aa80: dd32b004 dd32ab48 00000001 00000000 c05d568c 00000007 d909b880 dd32ab44
[  373.669140] aaa0: 00000000 dd32aac0 dd32c000 c0015fa4 68050193 ffffffff
[  373.675870] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  373.683566] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.691707] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.699143] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.707190] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.716207] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.723990] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.731500] Exception stack(0xdd32ad10 to 0xdd32ad58)
[  373.736629] ad00:                                     0000000f dd32b004 dd32ad64 dd32ad64
[  373.744937] ad20: dd32b004 dd32ade8 00000001 00000000 c05d568c 00000807 d909b880 dd32ade4
[  373.753243] ad40: 00000000 dd32ad60 dd32c000 c0015fa4 68050193 ffffffff
[  373.759970] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  373.767665] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  373.775804] [<c00161d8>] (unwind_backtrace) from [<c0013ea4>] (die+0x210/0x374)
[  373.783235] [<c0013ea4>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  373.791283] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  373.800300] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  373.808084] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  373.815591] Exception stack(0xdd32afb0 to 0xdd32aff8)
[  373.820723] afa0:                                     c091f0ac 00000005 dd3b1060 c05d61ec
[  373.829033] afc0: c05d56b8 28050193 ffffffff dd3b1044 dd3b20a8 dd3b0000 00000000 dd3b1fd4
[  373.837338] afe0: dd3b0000 dd32b004 c05d61ec c05d568c 68050193 ffffffff
[  373.844062] [<c05d56d4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  373.851319] Unable to handle kernel paging request at virtual address dd32b004
[  373.858650] pgd = c0004000
[  373.861394] [dd32b004] *pgd=193eb811, *pte=00000000, *ppte=00000000
[  373.867774] Internal error: Oops: 7 [#5] ARM
[  373.872109] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  373.888967] CPU: 0 PID: 0 Comm:  Not tainted 4.9.59+ #1047
[  373.894537] Hardware name: BCM2835
[  373.897991] task: d909b880 task.stack:   (null)
[  373.902602] PC is at unwind_frame+0x40c/0x5b0
[  373.906092] Unable to handle kernel paging request at virtual address dd1e1000
[  373.906097] pgd = 722e6563
[  373.906109] Unable to handle kernel paging request at virtual address 722e9ca3
[  373.906113] pgd = 722e6563
[  373.906124] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906128] pgd = 722e6563
[  373.906137] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906141] pgd = 722e6563
[  373.906154] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906159] pgd = 722e6563
[  373.906168] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906172] pgd = 722e6563
[  373.906182] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906186] pgd = 722e6563
[  373.906195] Unable to handle kernel paging request at virtual address 722e81eb
[  373.906200] pgd = 722e6563
[  373.906228] Unable to handle kernel paging request at virtual address dd1df004
[  373.998457] Unable to handle kernel paging request at virtual address 65747399
[  374.005796] Unable to handle kernel paging request at virtual address 65747399
[  374.013134] Unable to handle kernel paging request at virtual address 65747399
[  374.020469] Unable to handle kernel paging request at virtual address 65747399
[  374.027807] Unable to handle kernel paging request at virtual address 65747399
[  374.035143] Unable to handle kernel paging request at virtual address 65747399
[  374.042480] Unable to handle kernel paging request at virtual address 65747399
[  374.049832] Unable to handle kernel paging request at virtual address dd1dd000
[  374.057168] Unable to handle kernel paging request at virtual address 65747399
[  374.064505] Unable to handle kernel paging request at virtual address 65747399
[  374.071842] Unable to handle kernel paging request at virtual address 65747399
[  374.079176] Unable to handle kernel paging request at virtual address 65747399
[  374.086515] Unable to handle kernel paging request at virtual address 65747399
[  374.093854] Unable to handle kernel paging request at virtual address 65747399
[  374.101189] Unable to handle kernel paging request at virtual address 65747399
[  374.108539] Unable to handle kernel paging request at virtual address dd1db004
[  374.115876] Unable to handle kernel paging request at virtual address 65747399
[  374.123211] Unable to handle kernel paging request at virtual address 65747399
[  374.130548] Unable to handle kernel paging request at virtual address 65747399
[  374.137884] Unable to handle kernel paging request at virtual address 65747399
[  374.145220] Unable to handle kernel paging request at virtual address 65747399
[  374.152561] Unable to handle kernel paging request at virtual address 65747399
[  374.159898] Unable to handle kernel paging request at virtual address 65747399
[  374.167250] Unable to handle kernel paging request at virtual address dd1d9000
[  374.174581] pgd = c0004000
[  374.177326] [dd1d9000] *pgd=1ae60811, *pte=00000000, *ppte=00000000
[  374.183704] ------------[ cut here ]------------
[  374.188425] WARNING: CPU: 0 PID: 24 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  374.197430] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  374.214285] CPU: 0 PID: 24 Comm: ?? ?? Not tainted 4.9.59+ #1047
[  374.220646] Hardware name: BCM2835
[  374.224141] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  374.232026] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  374.239384] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  374.246467] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  374.254169] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  374.263018] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  374.271682] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  374.279559] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  374.286470] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  374.294526] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  374.303547] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  374.311335] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  374.318843] Exception stack(0xdd1d8f78 to 0xdd1d8fc0)
[  374.323974] 8f60:                                                       c091f0ac dd1da020
[  374.332283] 8f80: dd1d901c c03245f0 c05d568c 68050193 ffffffff dd1d8ffc c08b25bc dd1da020
[  374.340590] 8fa0: c05f947c dd1da054 dd1da008 dd1d8fc8 c03245f0 c05d56ac 68050193 ffffffff
[  374.348901] [<c05d56d4>] (__dabt_svc) from [<c05d56ac>] (__dabt_svc+0x2c/0x80)
[  374.356246] Unable to handle kernel paging request at virtual address dd1d9000
[  374.363577] pgd = c0004000
[  374.366321] [dd1d9000] *pgd=1ae60811, *pte=00000000, *ppte=00000000
[  374.372695] ------------[ cut here ]------------
[  374.377404] WARNING: CPU: 0 PID: 24 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  374.386408] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  374.403263] CPU: 0 PID: 24 Comm: ?? ?? Not tainted 4.9.59+ #1047
[  374.409623] Hardware name: BCM2835
[  374.413104] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  374.420983] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  374.428331] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  374.435413] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  374.443114] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  374.451964] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  374.460628] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  374.468509] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  374.475416] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  374.483469] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  374.492488] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  374.500271] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  374.507779] Exception stack(0xdd1d8c18 to 0xdd1d8c60)
[  374.512910] 8c00:                                                       dd1d901c dd1d9000
[  374.521218] 8c20: dd1d8ca4 00000003 dd1d8fc8 dd1d8cf0 00000001 00000000 dd1da000 c00eb8a8
[  374.529526] 8c40: c05f947c dd1d8cec 00000000 dd1d8c68 00000fff c0015df0 68050193 ffffffff
[  374.537845] [<c05d56d4>] (__dabt_svc) from [<c0015df0>] (unwind_frame+0x258/0x5b0)
[  374.545541] [<c0015df0>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  374.553681] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  374.561555] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  374.568900] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  374.575982] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  374.583682] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  374.592525] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  374.601190] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  374.609067] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  374.615973] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  374.624025] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  374.633043] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  374.640826] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  374.648333] Exception stack(0xdd1d8f78 to 0xdd1d8fc0)
[  374.653462] 8f60:                                                       c091f0ac dd1da020
[  374.661769] 8f80: dd1d901c c03245f0 c05d568c 68050193 ffffffff dd1d8ffc c08b25bc dd1da020
[  374.670077] 8fa0: c05f947c dd1da054 dd1da008 dd1d8fc8 c03245f0 c05d56ac 68050193 ffffffff
[  374.678391] [<c05d56d4>] (__dabt_svc) from [<c05d56ac>] (__dabt_svc+0x2c/0x80)
[  374.685739] Unable to handle kernel paging request at virtual address dd1d9000
[  374.693071] pgd = c0004000
[  374.695816] [dd1d9000] *pgd=1ae60811, *pte=00000000, *ppte=00000000
[  374.702191] ------------[ cut here ]------------
[  374.706899] WARNING: CPU: 0 PID: 24 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  374.715904] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  374.732759] CPU: 0 PID: 24 Comm: ?? ?? Not tainted 4.9.59+ #1047
[  374.739120] Hardware name: BCM2835
[  374.742597] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  374.750478] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  374.757827] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  374.764908] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  374.772611] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  374.781453] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  374.790118] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  374.797993] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  374.804902] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  374.812954] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  374.821975] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  374.829759] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  374.837267] Exception stack(0xdd1d88b8 to 0xdd1d8900)
[  374.842396] 88a0:                                                       dd1d901c dd1d9000
[  374.850703] 88c0: dd1d8944 00000003 dd1d8fc8 dd1d8990 00000001 00000000 dd1da000 c00eb8a8
[  374.859011] 88e0: c05f947c dd1d898c 00000000 dd1d8908 00000fff c0015df0 68050193 ffffffff
[  374.867323] [<c05d56d4>] (__dabt_svc) from [<c0015df0>] (unwind_frame+0x258/0x5b0)
[  374.875018] [<c0015df0>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  374.883157] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  374.891033] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  374.898380] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  374.905460] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  374.913159] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  374.922000] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  374.930666] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  374.938546] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  374.945451] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  374.953501] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  374.962520] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  374.970303] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  374.977810] Exception stack(0xdd1d8c18 to 0xdd1d8c60)
[  374.982942] 8c00:                                                       dd1d901c dd1d9000
[  374.991250] 8c20: dd1d8ca4 00000003 dd1d8fc8 dd1d8cf0 00000001 00000000 dd1da000 c00eb8a8
[  374.999558] 8c40: c05f947c dd1d8cec 00000000 dd1d8c68 00000fff c0015df0 68050193 ffffffff
[  375.007869] [<c05d56d4>] (__dabt_svc) from [<c0015df0>] (unwind_frame+0x258/0x5b0)
[  375.015566] [<c0015df0>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  375.023707] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  375.031583] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  375.038929] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  375.046008] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  375.053712] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  375.062557] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  375.071222] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  375.079098] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  375.086006] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  375.094056] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  375.103077] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  375.110862] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  375.118370] Exception stack(0xdd1d8f78 to 0xdd1d8fc0)
[  375.123500] 8f60:                                                       c091f0ac dd1da020
[  375.131808] 8f80: dd1d901c c03245f0 c05d568c 68050193 ffffffff dd1d8ffc c08b25bc dd1da020
[  375.140118] 8fa0: c05f947c dd1da054 dd1da008 dd1d8fc8 c03245f0 c05d56ac 68050193 ffffffff
[  375.148428] [<c05d56d4>] (__dabt_svc) from [<c05d56ac>] (__dabt_svc+0x2c/0x80)
[  375.155772] Unable to handle kernel paging request at virtual address dd1d9000
[  375.163106] pgd = c0004000
[  375.165851] [dd1d9000] *pgd=1ae60811, *pte=00000000, *ppte=00000000
[  375.172227] ------------[ cut here ]------------
[  375.176955] Unable to handle kernel paging request at virtual address dd1d7000
[  375.184294] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.192512] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.200728] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.208944] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.217160] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.225377] Unable to handle kernel NULL pointer dereference at virtual address 00000026
[  375.233593] Unable to handle kernel NULL pointer dereference at virtual address 00000026
carriba
Contact: ICQ
Mon Feb 26, 2018 1:34 pm
update_config=1
scan_ssid=1
country=GB
network={
	psk="password"
	key_mgmt=WPA-PSK
Just realising that whenever I activate SSID broadcasting on my Wifi AP devices, I cannot connect to the APs when the parameter "scan_ssid=1" is being used in the “wpa_supplicant.conf" text file.
Had to remove this suggested parameter in order to get connected to the device again with Wifi (having its AP broadcasting its SSID).
carriba
Contact: ICQ
Mon Feb 26, 2018 2:09 pm
[  312.257091] Unable to handle kernel paging request at virtual address 00171766
[  312.264470] Unable to handle kernel paging request at virtual address 00002603
[  312.271830] Unable to handle kernel paging request at virtual address 00002603
[  312.279192] Unable to handle kernel paging request at virtual address 00002603
[  312.286550] Unable to handle kernel paging request at virtual address 00002603
[  312.293910] Unable to handle kernel paging request at virtual address 00002603
[  312.301267] Unable to handle kernel paging request at virtual address 00002603
[  312.308627] Unable to handle kernel paging request at virtual address 00002603
[  312.315987] Unable to handle kernel paging request at virtual address 00002603
[  312.323347] Unable to handle kernel paging request at virtual address 00002603
[  312.330705] Unable to handle kernel paging request at virtual address 00002603
[  312.338064] Unable to handle kernel paging request at virtual address 00002603
[  312.345424] Unable to handle kernel paging request at virtual address 00002603
[  312.352784] Unable to handle kernel paging request at virtual address 00002603
[  312.360143] Unable to handle kernel paging request at virtual address 00002603
[  312.367504] Unable to handle kernel paging request at virtual address 00002603
[  312.374862] Unable to handle kernel paging request at virtual address 00002603
[  312.382221] Unable to handle kernel paging request at virtual address 00002603
[  312.389580] Unable to handle kernel paging request at virtual address 00002603
[  312.396938] Unable to handle kernel paging request at virtual address 00002603
[  312.404336] Unable to handle kernel paging request at virtual address 00070d5f
[  312.411695] Unable to handle kernel paging request at virtual address 0a000023
[  312.419056] Unable to handle kernel paging request at virtual address 0a000023
[  312.426416] Unable to handle kernel paging request at virtual address 0a000023
[  312.433776] Unable to handle kernel paging request at virtual address 0a000023
[  312.441136] Unable to handle kernel paging request at virtual address 0a000023
[  312.448497] Unable to handle kernel paging request at virtual address 0a000023
[  312.455856] Unable to handle kernel paging request at virtual address 0a000023
[  312.463214] Unable to handle kernel paging request at virtual address 0a000023
[  312.470572] Unable to handle kernel paging request at virtual address 0a000023
[  312.477933] Unable to handle kernel paging request at virtual address 0a000023
[  312.485290] Unable to handle kernel paging request at virtual address 0a000023
[  312.492651] Unable to handle kernel paging request at virtual address 0a000023
[  312.500009] Unable to handle kernel paging request at virtual address 0a000023
[  312.507368] Unable to handle kernel paging request at virtual address 0a000023
[  312.514727] Unable to handle kernel paging request at virtual address 0a000023
[  312.522088] Unable to handle kernel paging request at virtual address 0a000023
[  312.529448] Unable to handle kernel paging request at virtual address 0a000023
[  312.536806] Unable to handle kernel paging request at virtual address 0a000023
[  312.544160] pgd = 0a000003
[  312.546935] Unable to handle kernel paging request at virtual address 0a000283
[  312.554287] pgd = 6c622044
[  312.557063] Unable to handle kernel paging request at virtual address 6c6222c4
[  312.564415] pgd = 6c622044
[  312.567188] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.574540] pgd = 6c622044
[  312.577316] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.584667] pgd = 6c622044
[  312.587442] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.594794] pgd = 6c622044
[  312.597569] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.604920] pgd = 6c622044
[  312.607695] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.615046] pgd = 6c622044
[  312.617821] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.625173] pgd = 6c622044
[  312.627946] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.635300] pgd = 6c622044
[  312.638077] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.645429] pgd = 6c622044
[  312.648203] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.655555] pgd = 6c622044
[  312.658330] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.665679] pgd = 6c622044
[  312.668455] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.675808] pgd = 6c622044
[  312.678583] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.685935] pgd = 6c622044
[  312.688710] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.696061] pgd = 6c622044
[  312.698839] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.706190] pgd = 6c622044
[  312.708964] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.716317] pgd = 6c622044
[  312.719092] Unable to handle kernel paging request at virtual address 6c623b5c
[  312.726442] pgd = 6c622044
[  312.729220] Unable to handle kernel NULL pointer dereference at virtual address 0000026e
[  312.737462] Unable to handle kernel paging request at virtual address 01e5d730
[  312.744819] Unable to handle kernel paging request at virtual address 01e5d730
[  312.752179] Unable to handle kernel paging request at virtual address 01e5d730
[  312.759539] Unable to handle kernel paging request at virtual address 01e5d730
[  312.766896] Unable to handle kernel paging request at virtual address 01e5d730
[  312.774256] Unable to handle kernel paging request at virtual address 01e5d730
[  312.781615] Unable to handle kernel paging request at virtual address 01e5d730
[  312.788973] Unable to handle kernel paging request at virtual address 01e5d730
[  312.796332] Unable to handle kernel paging request at virtual address 01e5d730
[  312.803692] Unable to handle kernel paging request at virtual address 01e5d730
[  312.811050] Unable to handle kernel paging request at virtual address 01e5d730
[  312.818410] Unable to handle kernel paging request at virtual address 01e5d730
[  312.825768] Unable to handle kernel paging request at virtual address 01e5d730
[  312.833125] Unable to handle kernel paging request at virtual address 01e5d730
[  312.840486] Unable to handle kernel paging request at virtual address 01e5d730
[  312.847844] Unable to handle kernel paging request at virtual address 01e5d730
[  312.855202] Unable to handle kernel paging request at virtual address 01e5d730
[  312.862562] Unable to handle kernel paging request at virtual address 01e5d730
[  312.869922] Unable to handle kernel paging request at virtual address 6e692093
[  312.877282] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.884640] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.891999] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.899358] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.906717] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.914075] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.921432] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.928793] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.936152] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.943511] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.950869] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.958228] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.965587] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.972947] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.980305] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.987663] Unable to handle kernel paging request at virtual address 0000ec1f
[  312.995023] Unable to handle kernel paging request at virtual address 0000ec1f
[  313.002380] Unable to handle kernel paging request at virtual address 0000ec1f
[  313.009739] Unable to handle kernel paging request at virtual address 0000ec1f
[  313.017169] Unable to handle kernel paging request at virtual address 002c2570
[  313.024530] Unable to handle kernel paging request at virtual address 1672c420
[  313.031890] Unable to handle kernel paging request at virtual address 1672c420
[  313.039248] Unable to handle kernel paging request at virtual address 1672c420
[  313.046610] Unable to handle kernel paging request at virtual address 1672c420
[  313.053971] Unable to handle kernel paging request at virtual address 1672c420
[  313.061329] Unable to handle kernel paging request at virtual address 1672c420
[  313.068690] Unable to handle kernel paging request at virtual address 1672c420
[  313.076049] Unable to handle kernel paging request at virtual address 1672c420
[  313.083408] Unable to handle kernel paging request at virtual address 1672c420
[  313.090768] Unable to handle kernel paging request at virtual address 1672c420
[  313.098126] Unable to handle kernel paging request at virtual address 1672c420
[  313.105485] Unable to handle kernel paging request at virtual address 1672c420
[  313.112844] Unable to handle kernel paging request at virtual address 1672c420
[  313.120204] Unable to handle kernel paging request at virtual address 1672c420
[  313.127564] Unable to handle kernel paging request at virtual address 1672c420
[  313.134922] Unable to handle kernel paging request at virtual address 1672c420
[  313.142283] Unable to handle kernel paging request at virtual address 1672c420
[  313.149646] Unable to handle kernel NULL pointer dereference at virtual address 00000260
[  313.157888] Unable to handle kernel paging request at virtual address 00009a20
[  313.165245] Unable to handle kernel paging request at virtual address 00009a20
[  313.172602] Unable to handle kernel paging request at virtual address 00009a20
[  313.179962] Unable to handle kernel paging request at virtual address 00009a20
[  313.187322] Unable to handle kernel paging request at virtual address 00009a20
[  313.194681] Unable to handle kernel paging request at virtual address 00009a20
[  313.202039] Unable to handle kernel paging request at virtual address 00009a20
[  313.209397] Unable to handle kernel paging request at virtual address 00009a20
[  313.216756] Unable to handle kernel paging request at virtual address 00009a20
[  313.224116] Unable to handle kernel paging request at virtual address 00009a20
[  313.231474] Unable to handle kernel paging request at virtual address 00009a20
[  313.238832] Unable to handle kernel paging request at virtual address 00009a20
[  313.246191] Unable to handle kernel paging request at virtual address 00009a20
[  313.253549] Unable to handle kernel paging request at virtual address 00009a20
[  313.260910] Unable to handle kernel paging request at virtual address 00009a20
[  313.268267] Unable to handle kernel paging request at virtual address 00009a20
[  313.275626] Unable to handle kernel paging request at virtual address 00009a20
[  313.282986] Unable to handle kernel paging request at virtual address 00009a20
[  313.290345] Unable to handle kernel paging request at virtual address 00009a20
[  313.297703] Unable to handle kernel paging request at virtual address 00009a20
[  313.305064] Unable to handle kernel paging request at virtual address 65726f8d
[  313.312418] pgd =   (null)
[  313.315192] Unable to handle kernel paging request at virtual address 00001958
[  313.322543] pgd =   (null)
[  313.325319] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.333550] pgd =   (null)
[  313.336323] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.344556] pgd =   (null)
[  313.347330] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.355562] pgd =   (null)
[  313.358337] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.366569] pgd =   (null)
[  313.369345] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.377576] pgd =   (null)
[  313.380351] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.388584] pgd =   (null)
[  313.391359] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.399593] pgd =   (null)
[  313.402367] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.410600] pgd =   (null)
[  313.413375] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.421606] pgd =   (null)
[  313.424381] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.432612] pgd =   (null)
[  313.435387] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.443617] pgd =   (null)
[  313.446392] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.454624] pgd =   (null)
[  313.457398] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.465630] pgd =   (null)
[  313.468403] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.476637] pgd =   (null)
[  313.479412] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.487643] pgd =   (null)
[  313.490418] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.498650] pgd =   (null)
[  313.501424] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.509655] pgd =   (null)
[  313.512431] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  313.520712] Unable to handle kernel paging request at virtual address 002e2873
[  313.528075] Unable to handle kernel paging request at virtual address e58d1020
[  313.535435] Unable to handle kernel paging request at virtual address e59f1048
[  313.542794] Unable to handle kernel paging request at virtual address e59f1048
[  313.550153] Unable to handle kernel paging request at virtual address e59f1048
[  313.557510] Unable to handle kernel paging request at virtual address e59f1048
[  313.564870] Unable to handle kernel paging request at virtual address e59f1048
[  313.572226] Unable to handle kernel paging request at virtual address e59f1048
[  313.579588] Unable to handle kernel paging request at virtual address e59f1048
[  313.586947] Unable to handle kernel paging request at virtual address e59f1048
[  313.594305] Unable to handle kernel paging request at virtual address e59f1048
[  313.601665] Unable to handle kernel paging request at virtual address e59f1048
[  313.609023] Unable to handle kernel paging request at virtual address e59f1048
[  313.616381] Unable to handle kernel paging request at virtual address e59f1048
[  313.623741] Unable to handle kernel paging request at virtual address e59f1048
[  313.631099] Unable to handle kernel paging request at virtual address e59f1048
[  313.638458] Unable to handle kernel paging request at virtual address e59f1048
[  313.645817] Unable to handle kernel paging request at virtual address e59f1048
[  313.653176] Unable to handle kernel paging request at virtual address e59f1048
[  313.660533] Unable to handle kernel paging request at virtual address e59f1048
[  313.667893] Unable to handle kernel paging request at virtual address e59f1048
[  313.675253] Unable to handle kernel paging request at virtual address e59f1048
[  313.682611] Unable to handle kernel paging request at virtual address 95001505
[  313.689973] Unable to handle kernel paging request at virtual address 95c01105
[  313.697330] Unable to handle kernel paging request at virtual address 95c01105
[  313.704692] Unable to handle kernel paging request at virtual address 95c01105
[  313.712053] Unable to handle kernel paging request at virtual address 95c01105
[  313.719414] Unable to handle kernel paging request at virtual address 95c01105
[  313.726774] Unable to handle kernel paging request at virtual address 95c01105
[  313.734134] Unable to handle kernel paging request at virtual address 95c01105
[  313.741492] Unable to handle kernel paging request at virtual address 95c01105
[  313.748852] Unable to handle kernel paging request at virtual address 95c01105
[  313.756212] Unable to handle kernel paging request at virtual address 95c01105
[  313.763574] Unable to handle kernel paging request at virtual address 95c01105
[  313.770934] Unable to handle kernel paging request at virtual address 95c01105
[  313.778293] Unable to handle kernel paging request at virtual address 95c01105
[  313.785653] Unable to handle kernel paging request at virtual address 95c01105
[  313.793013] Unable to handle kernel paging request at virtual address 95c01105
[  313.800372] Unable to handle kernel paging request at virtual address 95c01105
[  313.808574] Unable to handle kernel paging request at virtual address 00edf03d
[  313.817635] Unable to handle kernel paging request at virtual address 00edf03d
[  313.825562] Unable to handle kernel paging request at virtual address 004d9b45
[  313.835948] Unable to handle kernel paging request at virtual address dd56d004
[  313.843290] pgd = c0004000
[  313.846037] [dd56d004] *pgd=1906c811, *pte=00000000, *ppte=00000000
[  313.852428] ------------[ cut here ]------------
[  313.857158] WARNING: CPU: 0 PID: 0 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  313.866078] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  313.882944] CPU: 0 PID: 0 Comm:timidity Not tainted 4.9.59+ #1047
[  313.889396] Hardware name: BCM2835
[  313.892907] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  313.900793] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  313.908148] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  313.915235] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  313.922940] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  313.931788] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  313.940458] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  313.948337] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  313.955242] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  313.963303] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  313.972322] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  313.980106] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  313.987615] Exception stack(0xdd56cf68 to 0xdd56cfb0)
[  313.992751] cf60:                   00000000 bf000000 dd56d00c c05d621c c05d568c 40000193
[  314.001060] cf80: ffffffff dd56cfec dd600110 dd56c000 00000000 dd60003c dd600040 dd56cfb8
[  314.009363] cfa0: c05d621c c05d56c4 40000193 ffffffff
[  314.014501] [<c05d56d4>] (__dabt_svc) from [<c05d56c4>] (__dabt_svc+0x44/0x80)
[  314.021843] [<c05d56c4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  314.029110] Unable to handle kernel paging request at virtual address dd56d00c
[  314.036442] pgd = c0004000
[  314.039187] [dd56d00c] *pgd=1906c811, *pte=00000000, *ppte=00000000
[  314.045569] ------------[ cut here ]------------
[  314.050278] WARNING: CPU: 0 PID: 0 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  314.059193] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio fixed i2c_dev ip_tables x_tables ipv6
[  314.076056] CPU: 0 PID: 0 Comm:timidity Not tainted 4.9.59+ #1047
[  314.082505] Hardware name: BCM2835
[  314.085992] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  314.093874] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  314.101223] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  314.108306] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  314.116010] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  314.124855] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  314.133521] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  314.141398] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  314.148306] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  314.156359] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  314.165380] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  314.173163] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  314.180670] Exception stack(0xdd56cc08 to 0xdd56cc50)
[  314.185807] cc00:                   0000000f dd56d00c dd56cc5c dd56cc5c dd56d00c dd56cce0
[  314.194115] cc20: 00000001 00000000 c05d568c c00eb8a8 00000000 dd56ccdc 00000000 dd56cc58
[  314.202423] cc40: dd56e000 c0015fa4 60000193 ffffffff
[  314.207563] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  314.215259] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  314.223401] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  314.231278] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  314.238623] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  314.245704] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  314.253414] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  314.262258] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  314.270922] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  314.278800] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  314.285706] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  314.293759] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  314.302782] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  314.310565] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  314.318073] Exception stack(0xdd56cf68 to 0xdd56cfb0)
[  314.323208] cf60:                   00000000 bf000000 dd56d00c c05d621c c05d568c 40000193
[  314.331517] cf80: ffffffff dd56cfec dd600110 dd56c000 00000000 dd60003c dd600040 dd56cfb8
[  314.339821] cfa0: c05d621c c05d56c4 40000193 ffffffff
[  314.344961] [<c05d56d4>] (__dabt_svc) from [<c05d56c4>] (__dabt_svc+0x44/0x80)
[  314.352305] [<c05d56c4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  314.359563] Unable to handle kernel paging request at virtual address dd56d00c
[  314.366895] pgd = c0004000
[  314.369640] [dd56d00c] *pgd=1906c811, *pte=00000000, *ppte=00000000
[  314.376017] ------------[ cut here ]------------
[  314.380723] WARNING: CPU: 0 PID: 0 at ./include/linux/uaccess.h:15 __probe_kernel_read+0x90/0xa4
[  314.389640] Modules linked in: fuse rfcomm cmac bnep hci_uart btbcm bluetooth brcmfmac brcmutil cfg80211 rfkill bcm2835_gpiomem uio_pdrv_genirq uio
[  314.406501] CPU: 0 PID: 0 Comm:timidity Not tainted 4.9.59+ #1047
[  314.412949] Hardware name: BCM2835
[  314.416428] [<c0016148>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  314.424311] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  314.431663] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  314.438743] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  314.446443] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  314.455287] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  314.463953] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  314.471831] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  314.478737] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  314.486791] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  314.495810] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  314.503593] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  314.511100] Exception stack(0xdd56c8a8 to 0xdd56c8f0)
[  314.516236] c8a0:                   0000000f dd56d00c dd56c8fc dd56c8fc dd56d00c dd56c980
[  314.524542] c8c0: 00000001 00000000 c05d568c c00eb8a8 00000000 dd56c97c 00000000 dd56c8f8
[  314.532845] c8e0: dd56e000 c0015fa4 60000193 ffffffff
[  314.537986] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  314.545686] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  314.553827] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  314.561705] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  314.569050] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  314.576131] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  314.583833] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  314.592677] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  314.601342] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  314.609220] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  314.616127] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  314.624180] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  314.633198] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  314.640981] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  314.648488] Exception stack(0xdd56cc08 to 0xdd56cc50)
[  314.653621] cc00:                   0000000f dd56d00c dd56cc5c dd56cc5c dd56d00c dd56cce0
[  314.661929] cc20: 00000001 00000000 c05d568c c00eb8a8 00000000 dd56ccdc 00000000 dd56cc58
[  314.670232] cc40: dd56e000 c0015fa4 60000193 ffffffff
[  314.675373] [<c05d56d4>] (__dabt_svc) from [<c0015fa4>] (unwind_frame+0x40c/0x5b0)
[  314.683069] [<c0015fa4>] (unwind_frame) from [<c00161d8>] (unwind_backtrace+0x90/0x104)
[  314.691208] [<c00161d8>] (unwind_backtrace) from [<c0013c90>] (show_stack+0x20/0x24)
[  314.699084] [<c0013c90>] (show_stack) from [<c031a618>] (dump_stack+0x20/0x28)
[  314.706431] [<c031a618>] (dump_stack) from [<c0021d1c>] (__warn+0xe4/0x10c)
[  314.713511] [<c0021d1c>] (__warn) from [<c0021e10>] (warn_slowpath_null+0x30/0x38)
[  314.721211] [<c0021e10>] (warn_slowpath_null) from [<c00eb8a8>] (__probe_kernel_read+0x90/0xa4)
[  314.730061] [<c00eb8a8>] (__probe_kernel_read) from [<c0014140>] (is_valid_bugaddr+0x28/0x50)
[  314.738726] [<c0014140>] (is_valid_bugaddr) from [<c031a154>] (report_bug+0x1c/0xcc)
[  314.746603] [<c031a154>] (report_bug) from [<c0013e00>] (die+0x16c/0x374)
[  314.753511] [<c0013e00>] (die) from [<c001db84>] (__do_kernel_fault.part.0+0x64/0x1f4)
[  314.761562] [<c001db84>] (__do_kernel_fault.part.0) from [<c05d5fe0>] (do_page_fault+0x23c/0x3cc)
[  314.770579] [<c05d5fe0>] (do_page_fault) from [<c0009204>] (do_DataAbort+0x44/0xc4)
[  314.778362] [<c0009204>] (do_DataAbort) from [<c05d56d4>] (__dabt_svc+0x54/0x80)
[  314.785870] Exception stack(0xdd56cf68 to 0xdd56cfb0)
[  314.791003] cf60:                   00000000 bf000000 dd56d00c c05d621c c05d568c 40000193
[  314.799314] cf80: ffffffff dd56cfec dd600110 dd56c000 00000000 dd60003c dd600040 dd56cfb8
[  314.807617] cfa0: c05d621c c05d56c4 40000193 ffffffff
[  314.812756] [<c05d56d4>] (__dabt_svc) from [<c05d56c4>] (__dabt_svc+0x44/0x80)
[  314.820097] [<c05d56c4>] (__dabt_svc) from [<c05d568c>] (__dabt_svc+0xc/0x80)
[  314.827353] Unable to handle kernel paging request at virtual address dd56d00c
[  314.834687] pgd = c0004000
[  314.837432] [dd56d00c] *pgd=1906c811, *pte=00000000, *ppte=00000000
[  314.843810] ------------[ cut here ]------------
[  314.848540] Unable to handle kernel paging request at virtual address dd56b004
[  314.855876] pgd =   (null)
[  314.858630] Unable to handle kernel paging request at virtual address 00003750
[  314.865961] pgd =   (null)
[  314.868712] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.876923] pgd =   (null)
[  314.879675] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.887886] pgd =   (null)
[  314.890637] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.898848] pgd =   (null)
[  314.901599] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.909809] pgd =   (null)
[  314.912559] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.920770] pgd =   (null)
[  314.923522] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[  314.931733] pgd =   (null)
ShiftPlusOne wrote:
Sat Feb 24, 2018 10:38 pm
RobertLoblaw89213783 wrote:
Sat Feb 24, 2018 10:24 pm
Is there a way to go back to the previous version of the firmware with apt-get?
Try this:
wget http://archive.raspberrypi.org/debian/pool/main/f/firmware-nonfree/firmware-brcm80211_20161130-3+rpi2_all.deb
sudo dpkg -i firmware-brcm80211_20161130-3+rpi2_all.deb
I went ahead and downgraded the firmware, and fired the command
echo "firmware-brcm80211 hold" | sudo dpkg --set-selections
to inihibit any future upgrade of the firmware causing the Raspbian OS to crash when accessing APs with a setup of not broadcasting their SSIDs (hidden WLANs).
Hope the provided elaborations, in particular, the debug log files, offer sufficient exhaustive information to pinpoint the root cause of the encountered firmware issue.
gnulove
Sun Mar 04, 2018 12:02 pm
Hi all (-:
i just registered to give you the following information:
i found a workaround/fix for this Problem in another German speaking forum: https://forum-raspberrypi.de/forum/thre ... /?pageNo=4. It is assumed there, that the problem occures when the SSID is hidden, not send.
If this entry is missing in the /etc/wpa_supplicant.conf:
scan_ssid=1
the old firmware isn't affected, but the new FW crashes the system!
So, to be able to update your Raspbian, just make sure that you add given line into your /etc/wpa_supplicant.conf before you update, and you should have no more problems with this. It worked flawlessly in my case. Best regards and happy hacking (-:
