Andyroo
Re: Difference in RASPBIAN STRETCH WITH DESKTOP and RASPBIAN STRETCH LITE.
Sat Jun 08, 2019 1:45 am
JetForMe wrote:
Sat Jun 08, 2019 1:19 am
Does Raspbian Lite include Avahi, or some other way to find it to ssh into it? Or must I connect a keyboard and monitor?
Lite is fine to connect to the LAN or WLAN and just
ssh pi@raspberry.local
or use your router to give you the IP address.
I have a set wpa_supplicant.config and a empty ssh file that I drop into the /boot folder after using Etcher, pop the SD card in and power on. After a couple of minutes at most it’s up and running and I SSH in to do the rest of the set-up.
Normally I have a ping raspberry.local running on my Mac to tell me when it’s up.
Edit: Meant to add - it is running Avahi from first boot.
jahboater
Sat Jun 08, 2019 9:07 am
It includes ssh of course, I guess its mostly used headless.
HawaiianPi
Sun Jun 09, 2019 2:01 am
Yes, avahi-daemon should be running by default.
Assuming the OS you are connecting from also supports mDNS/Zeroconf, and you don't have other Pi computers on your network with the same hostname, you should be able SSH into pi@raspberrypi.local (or pi@raspberrypi). I recommend you reserve an I.P. for each of your Pi computers in your router's DHCP settings, so that they will always have the same IP, regardless of what's on the SD card. Also, change the hostnames so that new Pi computers are easy to find.
Up-to-date versions of Windows 10 support mDNS and SSH/SCP from cmd.exe or Windows PowerShell, so you don't have to use PuTTY or install the Windows Subsystem For Linux any longer (but those still work, if you prefer them). There is also an SSH extension for Google's Chrome browser, and an SSH app for Chrome OS. Both work well (worth checking out).
Douglas6
Sun Jun 09, 2019 2:18 am
Raspian lite may skimp on some Bluetooth functionality, like BlueALSA, just so ya know.
LTolledo
Fri Jun 14, 2019 11:53 pm
TL/DR
Maybe an "odd" question related to the topic
If I connect via ssh (ssh only), to any RPi running raspbian, how will I know if the installed raspbian is "Lite" or "Desktop" version.
is there a command to reveal the which version?
Some people be like:
Sat Jun 15, 2019 5:56 am
Not easily. The only difference between the versions is the software that is pre-installed.
I suppose you could check to see if certain desktop software is installed. There are a few commands that will do this.
pi@raspberrypi:~ $ dpkg -l lxde
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version        Architecture   Description
ii  lxde                9+rpi1         all            Metapackage for LXDE
The "ii" means the software is installed. Or...
pi@raspberrypi:~ $ apt policy lxde
lxde:
  Installed: 9+rpi1
  Candidate: 9+rpi1
  Version table:
 *** 9+rpi1 500
        500 http://archive.raspberrypi.org/debian stretch/ui i386 Packages
        500 http://archive.raspberrypi.org/debian stretch/ui amd64 Packages
        100 /var/lib/dpkg/status
     9 500
        500 http://ftp.debian.org/debian stretch/main i386 Packages
        500 http://ftp.debian.org/debian stretch/main amd64 Packages
The "Installed:" line shows that the software is installed. On a "Lite" system (that hasn't had the desktop manually installed), it will show "Installed: (none)".
Actually, probably the best package to check is "raspberrypi-ui-mods", as installing that does most of the work of upgrading "Lite" to the "Desktop" version.
Arikania
Sun Jun 16, 2019 6:21 am
Why does my Raspbian Stretch Lite (i.e. headless) install and require superfluous stuff?
- Gnome
- LightDM
- X11
- Chromium browser
- LibreOffice
- icons
I get errors when I disable those. How to get a pure, clean install without all this extra stuff?
Sun Jun 16, 2019 10:55 am
- Gnome
- LightDM
- X11
- Chromium browser
- LibreOffice
- icons
It doesn't. Either you have installed the full version, or you have installed something that requires/recommends those packages. I always disable the "recommends" option on the package manager.
HawaiianPi
Sun Jun 16, 2019 9:25 pm
Agreed. My headless systems running Raspbian Lite have none of that installed.
hawaiianpi@CreeperPie:~ $ apt policy gnome lightdm xorg chromium-browser libreoffice
gnome:
  Installed: (none)
  Candidate: 1:3.22+3+b2
  Version table:
     1:3.22+3+b2 500
        500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
lightdm:
  Installed: (none)
  Candidate: 1.18.3-1
  Version table:
     1.18.3-1 500
xorg:
  Installed: (none)
  Candidate: 1:7.7+19
  Version table:
     1:7.7+19 500
chromium-browser:
  Installed: (none)
  Candidate: 72.0.3626.121-0+rpt4
  Version table:
     72.0.3626.121-0+rpt4 500
        500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
libreoffice:
  Installed: (none)
  Candidate: 1:5.2.7-1+rpi1+deb9u7
  Version table:
     1:5.2.7-1+rpi1+deb9u7 500
datamgmt
Wed Jun 19, 2019 11:35 pm
Hi - I came looking for a more detailed answer and not finding one decided to do some research myself
I installed the following (in turn):
April 2019; Release date:2019-04-08; Kernel version:4.14
Raspbian Stretch with desktop and recommended software
Then I updated the packages to the latest versions with
apt-get -y update --no-install-recommends # Gets the latest version of the apt catalog
apt-get -y dist-upgrade --no-install-recommends # Updates all the packages to the most recent version (always added no net new packages)
apt-get -y autoremove --no-install-recommends # Removes any obsolete packages (always returned no removals)
As a result there are:
Packages - Version
1465 - Raspbian Stretch with desktop and recommended software
1229 - Raspbian Stretch with desktop
905 - Raspbian Stretch Lite after running 'apt install raspberry-ui-mods'
453 - Raspbian Stretch Lite
Data correct as of 23:40 BST 19-June-2019
Packages in Lite:
Full List: https://pastebin.com/mwXFP4bd
Packages in lite with raspberrypi-ui-mods:
Full List: https://pastebin.com/NFmgs8DZ
Packages in Desktop:
Full List: https://pastebin.com/75YUBpFV
Packages in Full:
https://pastebin.com/nGsPgafB
And this guide gives lots of useful information on config low resource usage guide
viewtopic.php?t=133691
