th3cak3
looking for a simple and lightweight music player for PI ZERO
Tue Jan 16, 2018 5:48 pm
I have a Raspberry pi ZERO W that I would like to turn into a small music player. A simple device, no streaming, no web interface etc. just to play local files.
I need you to find a music player that is:
- Light (as much as possible)
- Without graphical interface
- Basic functions (read / stop / pause / shuffle / prev / next / volume ...) can be manipulated by command lines
- Able to read mp3, flac and ogg
So I could control it from a python script.
thank you
gkreidl
Re: looking for a simple and lightweight music player for PI ZERO
Tue Jan 16, 2018 5:54 pm
You could use omxplayer.
Minimal Kiosk Browser (kweb)
scotty101
Tue Jan 16, 2018 7:20 pm
MPD and MPC would be a good choice. There is a python binding to control it.
achrn
Tue Jan 16, 2018 7:29 pm
omxplayer wants to add 220 MB of disk space on a Raspbian lite - it's not my first thought, when looking for a lightweight sound player, to install more than 200MB of videoplayer.
When I was wanting similar (for a similar reason) I used mpg123. It adds 7MB to a Raspbian lite.
I didn't, however, compare processor load - mpg123 is not processor hungry, but maybe omxplayer beats it by using videocore?
Beware, however, that I found a zero didn't work too well when outputting i2s - I've seen it suggested that it doesn't have quite enough oomph to bring up the audio stack fast enough to get the data fed into the DAC to avoid a click / pop at start. Something to do with starting a clock and not having teh data ready for it immediately? Whatever teh cause, I found exactly the same sound hardware (actually an adafruit speaker bonnet with avariety of speakers / transducers) on the same version of Raspbian worked fine on a RPI3, but gave me a pop at the start of tracks on a zero.
tpylkko
Tue Jan 16, 2018 8:29 pm
In addition to the things already mentioned, I believe that mopidy would also fit your requirements. It is a mpd-like headless music server written in python. It is highly extensible, can be controlled from commandline, from python (I wrote my own python RFID controller so that I could have my daughter play music by showing the player RFID cards, it was one of the most well documented thigns I have ever worked with), from ready made web interfaces, from anything. It is available in Debian and therefor in Raspbian. I have run it on RPi A+ with 256 MB RAM without issue. Plays any kind of audio file you can find, ogg/flac/mp3/ac3/alac (apple lossless codec) and what more.
https://www.mopidy.com/
Then there is also the Volumio project, which distributes their own custom mpd player and surrounding Operating system. I know that most users use it over a web interface on their LAN, headlessly, but am not sure how easy it is to control it with other means.
https://volumio.org/
W. H. Heydt
Tue Jan 16, 2018 11:13 pm
I use mplayer. I *think* it fits your criteria.
scotty101
Wed Jan 17, 2018 8:00 am
Volumio just uses MPD so the standard python binding for MPD will give you the ability to control it.
Have used this in a prototype of an internet radio and I used python to 'tune' in to different stations.
sparkie777
Wed Jan 17, 2018 8:07 am
just
apt install cplay
and you enjoy the lightest music player ever:-)
your requirements are all satisfied.
the backend is freely configurable. ogg123(1), mpg123(1), mpg321(1), splay(1), madplay(1), mikmod(1), xmp(1), play(1), speexdec(1) and even mplayer are all supported.
th3cak3
Wed Jan 17, 2018 9:52 am
mocp : I get this
Running the server...
Trying JACK...
Trying ALSA...
Trying OSS...
FATAL_ERROR: No valid sound driver!
FATAL_ERROR: Server exited!
mpd : i get this
config_file: unrecognized parameter in config file at line 1: ID3
omxplayer : i get this... again
Audio codec mp3 channels 2 samplerate 44100 bitspersample 16
Subtitle count: 0, state: off, index: 1, delay: 0
Error: Unable to open font
so i've install the following package ttf-freefont then with the command line omxplayer ma_musique.mp3 -o alsa It works !
Problem, no way to change the volume while it plays. Plus, no sound if omxplayer is in the background.
cplay : it works, but how to change the volume on the command line?
sparkie777
Wed Jan 17, 2018 1:10 pm
volume could be set
either with
'cplay' directly: press the 'h' key to get some 'help' => to control volume use the 1..9, +, - keys.
or with the help of
'amixer' utility (if you have the 'alsa-utils' package installed)
k-pi
Wed Jan 17, 2018 1:27 pm
Mp3blaster, moc, cmus, or even mpg123?
I often just use mpg123 & mc, (to select the music files), even if I have GUI music players. ;)
Ronaldlees
Wed Jan 17, 2018 6:28 pm
May I suggest the free and open ogg123? It's very lightweight, and can be run easily against plain old ALSA with no extra layers, and best of all - it's built to use the free ogg vorbis format.
apt-get install vorbis-tools
Example run:
nice -n4 ogg123 -d alsa -o dev:"hw:0" --audio-buffer 10000 somelovelyvorbis.ogg
Adjust nice to the Pi zero, as well as buffers (see man page for all of them) for best play and no jitter.
I am the Umbrella man
tpylkko
Wed Jan 24, 2018 9:39 pm
I believe I read on their page that they claim that they use a tweaked version of mpd, that is somehow "better" or "more audiophile". But yes, essentially mpd anyway and no differece w.r.t controlling with Python
anotherknight
Tue May 08, 2018 3:43 pm
Although this is a late reply, the program you are looking for is cmus. There is a slight learning curve, but cmus isn't resource hungry in any way.
scruss
Tue May 08, 2018 4:29 pm
Fails badly on the OP's “able to read mp3” requirement, tho'.
