weberjn
iptables port forwarding in Raspbian stretch
Sat Jan 13, 2018 10:04 pm
I'd like to make Tomcat's port 8080 reachable on port 80.
I tried
 sudo iptables -t nat -A PREROUTING -p tcp --dport 80 -j REDIRECT --to-port 8080
but
weberjn@pi:~ $ curl localhost:80
curl: (7) Failed to connect to localhost port 80: Connection refused
weberjn@pi:~ $ curl pi:80
curl: (7) Failed to connect to pi port 80: Connection refused
This used to work in Jessie.
How can I get iptables get to forward the port?
Thx,
Juergen
https://community.atlassian.com/t5/Conf ... q-p/218498
allfox
Re: iptables port forwarding in Raspbian stretch
Sun Jan 14, 2018 5:09 am
At the first glimpse, I thought this is an easy one. It's not. :)
DuckDuckGo taught me: https://serverfault.com/a/211544
Your command would work for connection coming from outside your Pi. But if you want to develop on the Pi itself, you would also need:
sudo iptables --wait --table nat --append OUTPUT --protocol tcp --dport 80 --jump REDIRECT --to-port 8080
This is because when packets are generated from local, they would travel the iptables differently than those from outside.
They won't pass through the PREROUTING chain: http://www.iptables.info/en/structure-of-iptables.html
weberjn
Sun Jan 14, 2018 8:08 pm
Thanks, that did the trick.
Actually, looks like you need both rules for outside access, too.
Greetings,
Jürgen
allfox
Mon Jan 15, 2018 6:09 am
I think you only need PREROUTING for outside access.
The nat table works differently than the default filter table.
It only work on the very first packet of a connection. After that, there is an "NAT engine" would take care of the rest of the packets for the same connection: http://www.iptables.info/en/structure-o ... l#NATTABLE
So you don't need to manually write NAT rule for download and upload.
What we need is a trigger, which would make the "NAT engine" to do its job. The engine knows that a connection would have reply.
We do need rules for both directions in the filter table. They work in a different way.
"sudo iptables -nv --table nat --list" would show the packet counter hitting each rule, so we could see the nat table only work on one packet per connection.
