jondallimore
Alter cron jobs with bash script
Sat Jan 06, 2018 11:31 am
Is it possible to delete an old cron job and insert a new cron job using a bash script?
thanks
Jon
sparkie777
Re: Alter cron jobs with bash script
Sat Jan 06, 2018 11:48 am
how is 'the old cronjob' identified (in terms of a machine)?
normally you alter the crontab by the 'crontab' command (if you cease from editing the crontab directly by means of any text editor)
jondallimore
Sat Jan 06, 2018 12:20 pm
Found it:
To Add:
crontab -u pi -l ; echo "30 4 * * * /home/pi/Desktop/randomtestfile.txt"
To remove:
crontab -u pi -l | grep -v "30 4 * * * /home/pi/Desktop/randomtestfile.txt"
NotRequired
Sat Jan 06, 2018 12:32 pm
Try this:
#!/bin/bash
#The new cron job
CRON_ADD="1 * * * * /path/to/cron/command"
#Get crontab and remove lines containing "something" with sed
CRON=$(crontab -l | sed -n "/something/!p")
#Append the new job
CRON="$CRON\n$CRON_ADD\n"
#Modify the crontab
printf "$CRON" | crontab -
Please do not ask questions in private messages, they will not help others.
jondallimore
Sat Jan 06, 2018 12:46 pm
tried both possibilities now - neither working. will bash my head against this brick wall a bit more later, hungry now.
NotRequired
Sat Jan 06, 2018 12:47 pm
Please post the script that does not work, the script I posted works for me..
jondallimore
Sat Jan 06, 2018 12:52 pm
Ive copied and pasted your script word for word. When I go into crontab through the terminal after running it theres nothing there.
NotRequired
Sat Jan 06, 2018 12:59 pm
If you are running the script as root, you must add "-u pi" after each "crontab" command or else you will modify the crontab for "root".
#!/bin/bash
#The new cron job
CRON=$(crontab -u pi -l | sed -n "/something/!p")
#Make sure crontab ends with newline
if [ $(printf "$CRON" | tail -c 1 | wc -l) -eq 0 ]; then
  CRON="$CRON\n"
fi
#Modify the crontab
printf "$CRON$CRON_ADD\n" | crontab -u pi -
jondallimore
Sat Jan 06, 2018 1:12 pm
first time round, I checked the pi and the root crontabs - nothing in either.
the new one works for the pi crontab, and if I want to modify the root crontab, just change the username to root.
thanks
NotRequired
Sat Jan 06, 2018 1:25 pm
Great! Please note that I edited the last post to use "printf" rather that "echo" in the if..then..fi block
jondallimore
Sat Jan 06, 2018 7:32 pm
Ended up using the code below so that I could delete cron jobs containing specific text, and add in multiple jobs:
#!/bin/bash
crontab -l -u pi | grep -v "Monday 2" | crontab -u pi -
crontab -l -u pi | grep -v "Tuesday 2" | crontab -u pi -
crontab -l -u pi | grep -v "Wednesday 2" | crontab -u pi -
crontab -l -u pi | grep -v "Thursday 2" | crontab -u pi -
crontab -l -u pi | grep -v "Friday 2" | crontab -u pi -
crontab -l -u pi
cat <<'EOF'
#ADD CRON JOBS HERE#
1 1 * * * test
2 2 * * * test
3 3 * * * test
EOF
) | crontab -u pi -
NotRequired
Sat Jan 06, 2018 7:57 pm
#!/bin/bash
crontab -l -u pi
cat <<'EOF'
1 1 * * * test
2 2 * * * test
3 3 * * * test
EOF
) | crontab -u pi -
You will modify the crontab 6 times using this method but if you are fine with that, go for it! :)
jondallimore
Sat Jan 06, 2018 8:04 pm
yep - I have a couple of jobs I dont want removing every time. removing them by finding specific jobs is neater, even if it takes a few more lines
NotRequired
Sat Jan 06, 2018 8:11 pm
What I meant was that you will actually save and use a new crontab 6 times during that script. You could load the crontab once, modify it and save it again one time which would be the nicest approach.
#!/bin/bash
#The new cron job
#Get crontab
CRON=$(crontab -u pi -l)
#Remove lines with "monday" and "tuesday"
CRON=$(printf "$CRON" | sed -n "/monday/!p")
CRON=$(printf "$CRON" | sed -n "/tuesday/!p")
  CRON="$CRON\n"
fi
#Store the new crontab
jondallimore
Sat Jan 06, 2018 8:12 pm
it works. Im going to leave it as is now.
NotRequired
Sat Jan 06, 2018 8:48 pm
Nice! But the lines:
should really be modified to:
CRON=$(crontab -l -u pi)
CRON=$(printf "$CRON" | grep -v "Monday 2")
CRON=$(printf "$CRON" | grep -v "Tuesday 2")
CRON=$(printf "$CRON" | grep -v "Wednesday 2")
CRON=$(printf "$CRON" | grep -v "Thursday 2")
CRON=$(printf "$CRON" | grep -v "Friday 2")
printf "$CRON" | crontab -u pi -
Since this would only save and effect a new crontab once instead of 5 times.
