av4625
Stopping script gracefully and turning off led's
Thu Dec 07, 2017 6:33 pm
Hi, I have code very similar to the code for the pi xmas tree.
https://thepihut.com/products/3d-xmas-t ... spberry-pi
I want to start the script remotely from python doing `python3 script.py &` in subprocess
Then I want to somehow stop the script.
What is the best way to either get the pid of the running script (baring in mind more than one python3 process is running) and killing it from python.
When it gets 'killed' I want to catch this and turn the led's off.
I wasn't sure where to put this question, any help will be greatly appreciated!
Aaron
HankB
Re: Stopping script gracefully and turning off led's
Thu Dec 07, 2017 6:43 pm
(Probably belongs in a programming section.)
How do you plan to initiate stopping the script? I have a project that I want to interact with and which runs stand alone. I use a pushbutton on a GPIO pin to signal what I want. The Python script can monitor that and take action when the button is pressed. You can see the code at https://github.com/HankB/pi-video-player.
HTH
NotRequired
Thu Dec 07, 2017 6:48 pm
You could try an exit handler: https://docs.python.org/3/library/atexit.html
Please do not ask questions in private messages, they will not help others.
Thu Dec 07, 2017 6:54 pm
from gpiozero import LEDBoard
from gpiozero.tools import random_values
from signal import pause
tree = LEDBoard(*range(2,28),pwm=True)
for led in tree:
 led.source_delay = 0.1
 led.source = random_values()
pause()
If we wrap that for led loop in a try: except: finally; block we can control what happens when you shoot the program dead with a [CTRL]+[C] or a kill -term $(pidof mytree.py) command.
try:
  for led in tree:
  pause()
except:
  for led in tree:
    led.off()
finally:
  print ("Done and dusted")
This is a doctor free zone.
av4625
Sun Dec 10, 2017 9:11 pm
Thanks for the ideas. Ill give them ago!
