liudr
Copy made with RPI SD card copier couldn't finish boot
Fri Aug 18, 2017 10:29 pm
I am setting up 3 RPI stations. I made 3 16GB clone cards from my original. Two booted fine and the third didn't finish boot. I swapped SD cards and the third RPI booted fine and worked alright. I wonder what caused the stuck boot sequence, SD card? RPI? The copying? Here is my screen shot:
2017-08-17 16.39.13.jpg (128.5 KiB) Viewed 584 times
Arduino data loggers, user interface, printed circuit board designer since 2009, RPI 3B 2B 2B Zero Jessie, assembly/C/C++/java/python programmer since the 80's
hommar
Re: Copy made with RPI SD card copier couldn't finish boot
Fri Aug 18, 2017 10:38 pm
I think You plug out SD then all data does not write from cache
liudr
Fri Aug 18, 2017 10:45 pm
I will try again. Thanks.
