Re: Could I use duck billed tweezers to fix my bent micro USB pins?
Posted: Tue Aug 08, 2017 10:21 am
by pcmanbob
Hi.
You can use what ever you like you are doing the repair, from the poor quality picture I cant actually make out what the problem with the socket is.
Posted: Wed Aug 09, 2017 9:48 pm
by Adrian Bao
It seems like the pins at the bottom are bent outward. The case seems to have a gap between the bottom to the plastic. I will consider getting a flirc case.
Posted: Wed Aug 09, 2017 10:09 pm
by pcmanbob
As I said picture is so poor I cant see any pins , if you are saying you have bend the socket metal work which is what your finger is pointing to then that's been caused by bending the USB plug while is plugged in, which is some thing you have done. you should ba able to bend the metal socket back in to shape if you are careful and don't bend it to far.
As the USB socket is mount flush to the circuit board I don't think a different case will provide any better support.
I currently have 4 pi's sitting on my desk which either have no case or a case with a big hole for the micro usb socket and non of them are displaying any signs of socket damage like yours and they are connected and disconnected for each use. so may be you just need to take a bit more care.
Posted: Mon Feb 19, 2018 10:04 pm
by neilakos
You might as well try! If the tweezers are small enough, i don't see why it wouldn't work.
Posted: Mon Feb 19, 2018 11:58 pm
by MaxK1
Or use the GPIO header pin 2 or pin 4 for +5V and pin 6 for Gnd. It does bypass the protection circuitry, though. At least you will be able to power your Pi.
Posted: Tue Feb 20, 2018 3:15 am
by PhatFil
you may as well have a go, and fall back on the gpio method to supply power if it proves fruitless.
micro usb power cables with a toggle switch come in handy for the pi..
Posted: Tue Feb 20, 2018 10:55 am
by mahjongg
First (Adrian Bao's) post deleted at users request (thread cannot be deleted as I need everybody's approval).
