Pi124
Transmission doesn't start at boot
Mon Jul 17, 2017 11:20 am
I installed transmission-daemon on raspbian.
I rebooted and am unble to access it via webui.
I need a link for installing transmission and mKing it auto start at boot.
Also, Can someone tell me how to restart from scratch as I may have tinkered with some transmission config files in an undesirable manner.
allfox
Re: Transmission doesn't start at boot
Mon Jul 17, 2017 3:32 pm
Greetings.
I added @reboot pi /bin/sleep 60;/usr/local/bin/transmission-daemon to /etc/crontab to make it start at boot.
The sleep 60 would wait 60 seconds, so the network system would have some time to boot.
Pi124
Mon Jul 17, 2017 4:15 pm
allfox wrote:Greetings.
Can you tell me how to reinstall transmission and reset changes made to transmission config files?
allfox
Mon Jul 17, 2017 4:43 pm
Pi124 wrote:Can you tell me how to reinstall transmission and reset changes made to transmission config files?
I installed mine from source code, so I'm not sure if the APT repo version also works this way:
Transmission-daemon save its config at /home/pi/.config/transmission-daemon/settings.json
Document about this file could be found at https://github.com/transmission/transmi ... tion-Files
If you want to reinstall the whole thing, maybe https://github.com/transmission/transmi ... ansmission would help.
I don't want to write a step by step cook recipe now, I'm lazy.
Pi124
Thu Jul 20, 2017 8:13 am
I've messed up the transmission configuration. I messed around with a few config files and now I get 403 error even when I've disable ip address in settings.json file.
Can someone help me how to reset to default and install transmission from scratch?
