komarek
python script at startup
Fri Jun 30, 2017 10:00 am
hi folks
in my Rpi 3 i have a few python script running in background that are loaded a startup... basically these script handle my hous sensor system with IOT api's and things like that.
i load the scripts with /etc/rc.local
which is ending something like this:
python3 /home/pi/Documents/PY/citofono.py &
python3 /home/pi/Documents/PY/fanspeed.py &
python3 /home/pi/Documents/PY/allarmecasa.py &
python3 /home/pi/Documents/PY/analitico.py &
exit 0
well they all wrok good except the last one (analitico.py) which is actually running as process but is not working at all.
so my solution (at every reboot) is not very comfortable... i have to kill the process and run it again from the terminal:
and then it's working properly.
the problem is that if i close the terminal window the script stop working in background.
what do you think is the problem?
where can i find some useful logs?
B.Goode
Re: python script at startup
Fri Jun 30, 2017 10:09 am
I think, although it is only a guess in the absence of any real information on which to base a reply, that there is probably something in
that makes the script dependent on interaction via a terminal.
Posting the script here might allow someone with appropriate knowledge to comment.
Running dmesg from a shell (command-line) prompt will show you recent system console output.
komarek
Fri Jun 30, 2017 10:24 am
this is the script
but i dont think the problem is here. otherwise it won't work when i run it manually
#!/usr/bin/python
from __future__ import print_function
import re
import argparse
import sys
import time
import paho.mqtt.publish as publish
import paho.mqtt.client as mqtt
from googleapiclient.errors import HttpError
from googleapiclient import sample_tools
from oauth2client.client import AccessTokenRefreshError
def get_first_profile_id(service):
	accounts = service.management().accounts().list().execute()
	if accounts.get('items'):
		firstAccountId = accounts.get('items')[0].get('id')
		webproperties = service.management().webproperties().list(accountId=firstAccountId).execute()
	if webproperties.get('items'):
		firstWebpropertyId = webproperties.get('items')[0].get('id')
		profiles = service.management().profiles().list(accountId=firstAccountId, webPropertyId=firstWebpropertyId).execute()
	if profiles.get('items'):
		return profiles.get('items')[0].get('id')
	return None
def hg_attivi(service, profile_id):
	return service.data().realtime().get(
	ids='ga:xxxxxx',
	metrics='rt:activeUsers').execute()
def tobado_attivi(service, profile_id):
	ids='ga:xxxxxx',
def hg_oggi(service, profile_id):
        return service.data().ga().get(
        ids='ga:xxxxxx',
	start_date='today',
	end_date='today',
	metrics='ga:visits').execute()
def tobado_oggi(service, profile_id):
        ids='ga:xxxxxx',
        start_date='today',
        end_date='today',
def print_results(results):
	# Print data table.
	if results.get('rows', []):
		for row in results.get('rows'):
			output = []
			for cell in row:
        			output.append('%30s' % cell)
			print(''.join(output))
	else:
		print('0')
def invia_analitici():
	try:
		service, flags = sample_tools.init(sys.argv, 'analytics', 'v3', __doc__, __file__, scope='https://www.googleapis.com/auth/analytics.readonly')
	except Exception as ecc:
		print(ecc)
	# Try to make a request to the API. Print the results or handle errors.
	try:
		first_profile_id = get_first_profile_id(service)
		if not first_profile_id:
			print('Could not find a valid profile for this user.')
		else:
			# HORROR GALORE
			results = hg_attivi(service, first_profile_id)
			risultati = results.get("totalsForAllResults")
			risultati_pronti = str(risultati.get("rt:activeUsers"))
			publish.single("Analytics/HG/attivi", payload=risultati_pronti, qos=1, retain=False, hostname="localhost", port=1883, client_id="PI-Zero")
			# HORROR GALORE OGGI
			results = hg_oggi(service, first_profile_id)
			risultati_pronti = str(risultati.get("ga:visits"))
			publish.single("Analytics/HG/oggi", payload=risultati_pronti, qos=1, retain=False, hostname="localhost", port=1883, client_id="PI-Zero")
			# TOBADO
			results = tobado_attivi(service, first_profile_id)
			publish.single("Analytics/TOBADO/attivi", payload=risultati_pronti, qos=1, retain=False, hostname="localhost", port=1883, client_id="PI-Zero")
			# TOBADO OGGI
			results = tobado_oggi(service, first_profile_id)
			publish.single("Analytics/TOBADO/oggi", payload=risultati_pronti, qos=1, retain=False, hostname="localhost", port=1883, client_id="PI-Zero")
	except TypeError as error:
		# Handle errors in constructing a query.
		print(('There was an error in constructing your query : %s' % error))
	except HttpError as error:
		# Handle API errors.
		print(('Arg, there was an API error : %s : %s' % (error.resp.status, error._get_reason())))
	except AccessTokenRefreshError:
		# Handle Auth errors.
		print ('The credentials have been revoked or expired, please re-run ' 'the application to re-authorize')
while True:
	def on_connect(client, userdata, flags, rc):
		#print("Connected with result code "+str(rc))
		client.subscribe("Analitico")
	def on_message(client, userdata, msg):
		messaggio = str(msg.payload)
		if "richiediANALISI" in messaggio:
			try:
				#print("raccolgo i dati e te li invio")
				invia_analitici()
				#time.sleep(10)
				print(ecc)
	try:
		client = mqtt.Client()
		client.on_connect = on_connect
		client.on_message = on_message
		client.connect("127.0.0.1",1883,60)
	except Exception as eccloop:
		print(ecc)
	else:
		client.loop_forever()
NotRequired
Fri Jun 30, 2017 10:31 am
If "analitico.py" depends on "something" (eg. a sensor, network or alike) which is not available when rc.local is loaded or if the script fills up a std[out|err] pipe buffer, this would cause the script to enter a deadlock and this might be hard to debug. The first thing you should do is to modify the command in rc.local in order to redirect the output, like this:
python3 /home/pi/Documents/PY/analitico.py &> /dev/shm/analitico.log &
This will redirect any output from the script to a file named /dev/shm/analitico.log where you can review if anything sinister is going on. Please note that /dev/shm is volatile and stored in memory, therefore the log will vanish on reboot / shutdown.
Another tip: Do not use rc.local to start long running background services with dependencies. Use systemd and specify the dependencies instead - this will ensure that the script is invoked after the dependencies are ready to use :)
Please do not ask questions in private messages, they will not help others.
B.Goode
Fri Jun 30, 2017 10:42 am
I think your knowledge of Python probably exceeds mine, because I would not define functions within a while loop. But that is probably not directly related to this issue.
Is there anything in the script that might behave differently if run as root/superuser during boot, rather than as a 'normal' user via the shell prompt.
There are some print statements in the script, so try piping the standard output from the script to a log file which you can subsequently examine to see what happened.
Edit : I see the idea of looking at a log file was suggested independently while I was typing. Left to indicate that it is A Good Idea.
komarek
Fri Jun 30, 2017 10:46 am
NotRequired wrote:If "analitico.py" depends on "something" (eg. a sensor, network or alike) which is not available when rc.local is loaded or if the script fills up a std[out|err] pipe buffer, this would cause the script to enter a deadlock and this might be hard to debug. The first thing you should do is to modify the command in rc.local in order to redirect the output, like this:
ok thanks
but it's pretty strange because the other scripts loaded before that are quite similar and they give me no trouble at all...
about systemd you're absolutely right... my problem was that i'm lazy :)
B.Goode
Fri Jun 30, 2017 10:52 am
Does the behaviour change if you change the startup order? Is it just that the latest script is 'Too much?'
komarek
Fri Jun 30, 2017 11:15 am
well i m not sure... but i think you're right
i tried once to change the order once and maybe the last one it was not working.
i need to test it again.
anyway now i m trying the "systemd" way
sounds better solution
komarek
Fri Jun 30, 2017 11:21 am
NotRequired wrote: Another tip: Do not use rc.local to start long running background services with dependencies. Use systemd and specify the dependencies instead - this will ensure that the script is invoked after the dependencies are ready to use :)
well i tried with systemd now
this is my analitico.service file:
[Unit]
Description=Servizio Gestione Google Analytics su MQTT
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/python3 /home/pi/Documents/PY/analitico.py
[Install]
WantedBy=multi-user.target
the status says the service is active and running... but the script doesn't actually working.
if i call the MQTT command the script doesn't answer as it supposed to do.
and...
it's strange that if i set the line "ExecStart=/usr/bin/python3 /home/pi/Documents/PY/analitico.py" with the log file .... like this: ExecStart=/usr/bin/python3 /home/pi/Documents/PY/analitico.py > /dev/shm/analitico.log
it gives me error.
any ideas?
NotRequired
Fri Jun 30, 2017 12:54 pm
komarek wrote:it's strange that if i set the line "ExecStart=/usr/bin/python3 /home/pi/Documents/PY/analitico.py" with the log file .... like this: ExecStart=/usr/bin/python3 /home/pi/Documents/PY/analitico.py > /dev/shm/analitico.log
it gives me error.
any ideas?
This is not strange, systemd commands does not run in a shell and the redirect operator ">" is handled by the shell (BASH). If you want to use ">" you should put the command line in a shell script and execute that instead. Also, since your py uses network you might want to change your service to include:
Wants=network.target
After=multi-user.target network.target
komarek
Fri Jun 30, 2017 1:08 pm
NotRequired wrote: This is not strange, systemd commands does not run in a shell and the redirect operator ">" is handled by the shell (BASH). If you want to use ">" you should put the command line in a shell script and execute that instead. Also, since your py uses network you might want to change your service to include:
ok i did it
but still doesnt work
NotRequired
Fri Jun 30, 2017 1:22 pm
Does the output from the py script give you any clue?
komarek
Fri Jun 30, 2017 1:27 pm
NotRequired wrote:Does the output from the py script give you any clue?
no clue
the only thing i can say... that if i run the script manually: python3 /home/pi/Documents/analitico.py
it works like charm
NotRequired
Fri Jun 30, 2017 2:04 pm
The only thing that would be different is the environment variables (accessed with os.environ[..]) which are different when run as root or outside shell. Have you tried to create a shell script (/home/pi/analitico.sh) with the content:
#!/bin/bash
Remember to set executable bit: chmod u+x /home/pi/analitico.sh
Then create a systemd service for it (/etc/systemd/system/analitico.service):
[Unit]
Wants=network.target network-online.target
[Service]
Type=idle
User=pi
ExecStart=/home/pi/analitico.sh
[Install]
And then enable the service with "sudo systemctl enable analitico" and reboot? This should be exactely the same as launching from a command line as user pi..
komarek
Fri Jun 30, 2017 2:32 pm
no way
Loaded: loaded (/lib/systemd/system/analitico.service; enabled)
Active: failed (Result: exit-code) since ven 2017-06-30 16:26:43 CEST; 5min ago
Process: 2018 ExecStart=/home/pi/Documents/SH/analitico.sh (code=exited, status=203/EXEC)
Main PID: 2018 (code=exited, status=203/EXEC)
NotRequired
Fri Jun 30, 2017 2:40 pm
Did you remember to set executable bit for the *.sh?
komarek
Fri Jun 30, 2017 2:48 pm
NotRequired wrote:Did you remember to set executable bit for the *.sh?
yes
and then i tried to chmod 644 also
same error
komarek
Fri Jun 30, 2017 2:56 pm
now i've set the chmode to 777
and gave me denied permission for: /dev/shm/analitico.log
then i got rid of "/dev/shm/analitico.log"
and when i do sudo service analitico status i have this:
   Active: inactive (dead) since ven 2017-06-30 16:53:58 CEST; 3s ago
  Process: 15397 ExecStart=/home/pi/Documents/SH/analitico.sh (code=exited, status=0/SUCCESS)
 Main PID: 15397 (code=exited, status=0/SUCCESS)
what a mess :)
komarek
Fri Jun 30, 2017 3:00 pm
obviously if i run /home/pi/Documents/SH/analitico.sh manually
it works well
komarek
Fri Jun 30, 2017 3:02 pm
looks like something wrong in this file:
[Unit]
[Service]
Type=idle
User=pi
[Install]
komarek
Fri Jun 30, 2017 5:03 pm
i will never find a solution for this crap
NotRequired
Fri Jun 30, 2017 5:20 pm
Please try to change your "analitico.sh" to contain:
#!/bin/bash
LOG_FILE="/home/pi/analitico.log"
echo "Hello from shell" >> $LOG_FILE
python3 /home/pi/Documents/PY/analitico.py &>> $LOG_FILE
Do not change "&>>" to ">": "&" will redirect both stderr and stdout, ">>" will append.
Then try to modify "analitico.py" to:
print "Hello from python"
And reboot with the analitico service enabled. When booted try to execute command "cat /home/pi/analitico.log" - what is the output?
Martin Frezman
Fri Jun 30, 2017 5:25 pm
#!/bin/bash
Note that a simpler way to do this is:
#!/bin/bash
exec > /home/pi/analitico.log 2>&1
# Rest of script here - no more redirection needed.
If this post appears in the wrong forums category, my apologies.
komarek
Fri Jun 30, 2017 5:30 pm
NotRequired wrote:Please try to change your "analitico.sh" to contain:
the log file just says:
hello from shell
and
the service status is:
   Active: active (running) since ven 2017-06-30 19:28:20 CEST; 9s ago
 Main PID: 1647 (analitico.sh)
   CGroup: /system.slice/analitico.service
           ├─1647 /bin/bash /home/pi/Documents/SH/analitico.sh
           └─1649 python3 /home/pi/Documents/PY/analitico.py
giu 30 19:28:20 pitre systemd[1]: Started Servizio Gestione Google Analytics su MQTT.
and
the script doesnt work
komarek
Fri Jun 30, 2017 5:36 pm
everything works... the shell is been loaded but
when it cast the script something goes wrong... and there's no signs of where the issue is
