Updating old distros?
Posted: Thu May 18, 2017 8:07 pm
by RandomOT
Hello all,
I would like to know if there was a possibility of reviving some old distros to make them support 1G or ram? Because having the Raspberry Pi 3B, I cannot use some 512M based distros as PwnPi or some other, and it is a shame we cannot just update some code to make it support higher ram... Or, can we? Thank you for replying!
Re: Updating old distros?
Posted: Fri May 19, 2017 10:06 am
by RandomOT
Anyone?
Posted: Fri May 19, 2017 10:19 am
by Jednorozec
PwnPi runs just fine on the 3B.
Posted: Fri May 19, 2017 10:21 am
by RandomOT
Have you tried it??? It does not boot on mine... How did you do if it worked with you? You are sure you tested it on a RPi 3 Model B?
Posted: Fri May 19, 2017 10:22 am
by SkyRise
Any Linux-based system will use all the available RAM (i.e. that not given over to the GPU in the case of the Raspberry Pi)
Posted: Fri May 19, 2017 10:25 am
by RandomOT
Again, I looked at it and he said for example that he added support for 512M of ram, he would not have said that randomly would he? Otherwise, has anyone tested PwnPi for Raspberry Pi 3 Model B?
Posted: Fri May 19, 2017 10:28 am
by SkyRise
If it's not been updated since before the 3B was released, then you'd need to update the relevant files in the /boot folder with the newer kernel, and it should boot like magic.
Posted: Fri May 19, 2017 10:30 am
by RandomOT
Where could I find the replacement files? Do you have any tutorial please?
Posted: Fri May 19, 2017 10:32 am
by Jednorozec
RandomOT wrote:Have you tried it??? It does not boot on mine... How did you do if it worked with you? You are sure you tested it on a RPi 3 Model B?
I installed it some years ago on a hard drive and have kept it updated. I don't remember which RPi I used initially but it's running right now on a 3B. You could try booting in an older Pi and doing an update.
Posted: Fri May 19, 2017 11:20 am
by bensimmo
Each Pi needs a slightly different bit of bootcode (or whatever they call it).
You will need to update your detup or the distribution with it.
If it is based around Raspian and uses Raspian files then an apt dist-upgrade may get what you need.
Other than that, get the maintainer to update it or spin a new project of it and fix it with the community.
Posted: Fri May 19, 2017 1:40 pm
by RandomOT
Is it possible you could upload the bootcode you have for your 3B so I could download it and try it out?
Posted: Fri May 19, 2017 4:44 pm
by RandomOT
Could anyone actually use a Pi2 to update and upgrade the distro and upload it on the internet for me as I do not have a Pi2? It would be awesome!
Posted: Fri May 19, 2017 5:53 pm
by B.Goode
RandomOT wrote:Could anyone actually use a Pi2 to update and upgrade the distro and upload it on the internet for me as I do not have a Pi2? It would be awesome!
It must be SO frustrating to want to do penetration testing but be so uninformed that you cannot get your own machine to boot!
You could try asking at the contact page for the distribution for help: http://pwnpi.sourceforge.net/index.html_q=contact.html
Failing that, all the files that a microSD card needs to boot an Operating System on an RPi are freely downloadable from from RPF sites: noone needs to upload anything special for you.
Posted: Fri May 19, 2017 6:15 pm
by RandomOT
I've been trying for a week, the dev team of pwnpi does not reply. I got someone kind enough to boot it on a Pi2 and to send it to me, it's in the process of being done. But there's nothing frustrating, patience is key to almost anything... I'm just interested in testing my system's vulnerabilities to patch them up. I'm not looking to do anything illegal nor was I begging someone to upload some files for me, I was just asking someone to do it kindly if that someone got some spare time to help others. Do not mix up words please, thanks for the advice though!
Posted: Fri May 19, 2017 7:25 pm
by W. H. Heydt
RandomOT wrote:Again, I looked at it and he said for example that he added support for 512M of ram, he would not have said that randomly would he? Otherwise, has anyone tested PwnPi for Raspberry Pi 3 Model B?
You may be misreading what the maintainer has said. The *program* may have been updated to use 512MB, not that it was updated to run on a 512MB Pi. After all, Pis went from 256MB to 512MB quite early and have had 1GB since the launch of the Pi2B.
Posted: Sat May 20, 2017 8:09 am
by mfa298
RandomOT wrote: I've been trying for a week, the dev team of pwnpi does not reply. I got someone kind enough to boot it on a Pi2 and to send it to me, it's in the process of being done. But there's nothing frustrating, patience is key to almost anything... I'm just interested in testing my system's vulnerabilities to patch them up. I'm not looking to do anything illegal nor was I begging someone to upload some files for me, I was just asking someone to do it kindly if that someone got some spare time to help others. Do not mix up words please, thanks for the advice though!
Considering that image was released in 2012 (4 and a half years ago) I can't imagine there's much in there that's particularly useful. It does seem somewhat odd that you want to use such an old distro to test for vulnerabilities (which appear all the time)
Posted: Fri Jul 28, 2017 9:25 pm
by VirHater
Hi all
right now im downloading a pwnpi found on a website the guy say he update the image to run on new Pi
credit go to this artivce if its work
"PwnPi 3.0, FruitWifi 2.1.2 & Raspberry 2 / B+ " : search it on google i dont know if im able to post link Do to my new profile and 1st post here
Posted: Mon Jul 31, 2017 8:12 pm
by hommar
Why my message was deleted again?
First I think my message was deleted becouse forum was updated...
But message about ( I update topic-distr for rPI2&rPI3, and ask test it) was deleted again
Честно, лень подбирать правильные английские выражения... и так сойдёт, всё равно сотрут...
Posted: Tue Aug 01, 2017 1:10 pm
by mahjongg
It was deleted because it pointed to an alternative download location of a probably hacked version of an operating system, and I got warnings and complaints about it.
For the record, I want to warn users that downloading an OS from susceptible sources is a BAD idea!
As for Russian text, note that I can read it....
Be polite please, don't lower yourself..
