TheElectronicsGuy
Buying RPi 3 Kit
Mon May 08, 2017 11:31 pm
Can anyone please post the best link where I can buy a RPi 3 kit ?
allfox
Re: Buying RPi 3 Kit
Tue May 09, 2017 1:14 am
It would be better if you could tell us where you are.
Is the RS or element 14 available?
Essentially, the kit need a power source, a Micro SD card, and a Pi.
Wire to connect to TV is optional.
tweak42
Tue May 09, 2017 2:09 am
TheElectronicsGuy wrote:Can anyone please post the best link where I can buy a RPi 3 kit ?
What country are you in, and what kind of projects do you envision using it for? Besides the basics, you may consider picking a few extras depending on what you plan to do.
Tue May 09, 2017 6:34 am
Retired disgracefully.....
MuppetMikey
Tue May 09, 2017 7:18 am
check out amazon.. they have the 32gb pi3 canakit with everything needed for 69 bucks(cheaper then the same kit on canakits own website.. by about 15 bucks). you get a case for it , the pi hdmi cable power supply heat sinks sd card with adapter.. while there order yourself a an wired or wireless kb and mouse and your all set .. this will be the 3rd pi I have gotten from canakit, and its a great little set up.. I have a retro pie gamming machine, and a media center..
