atux_null
google contacts to mysql sync
Thu Mar 23, 2017 7:20 am
i am running a LAMP server. I would like to sync once a day all my google contacts to mysql so i could retrieve it locally for different functions and operations. The update will be one way only, from google to mysql. Not the other way.I am afraid i cannot find a working solution to my issue. I am not sure if this is the right section of the forum. In such a case please let me know of what actions to take.
321a
Re: google contacts to mysql sync
Thu Mar 23, 2017 12:17 pm
Maybe you could download the contacts from google using some sort of HTML automation, maybe like wget or something more geared to webpage automation & scraping, and then parse the HTML files into a flat file like csv, tab delimited or txt type of file and then create a stored procedure which imports the file into MySQL that way.
Once the individuals steps work ok, call them from a bigger script and create a scheduled entry in Cron to run daily.
Dont forget to delete the old files once completed to clean up.
FlexibleSigmoid
Thu Mar 23, 2017 4:56 pm
Does the ability to use CardDAV make the job a bit easier for you? Some hints here: https://developers.google.com/google-ap ... g_contacts
scotty101
Thu Mar 23, 2017 5:43 pm
There is a google contacts API so you don't have to go though the pain of scraping the HTML.
https://developers.google.com/google-apps/contacts/v3/
It has python examples to retrieve your entire contact list.
