Selling The Raspberry Pi
Posted: Thu Dec 22, 2016 4:27 pm
by TheLoadedRogue
I am thinking about using the Raspberry Pi in a project that I'm intending to sell upon completion.
Is this allowed?
If so are there any restrictions or requirements?
Thanks in advance
Re: Selling The Raspberry Pi
Posted: Thu Dec 22, 2016 5:17 pm
by fruitoftheloom
TheLoadedRogue wrote:I am thinking about using the Raspberry Pi in a project that I'm intending to sell upon completion.
Is this allowed?
Thanks in advance
https://www.raspberrypi.org/trademark-rules
If you selling in a Case it may need to be tested for EMC:
viewtopic.php?t=168315&p=1082552
Posted: Thu Dec 22, 2016 5:23 pm
by Heater
If you are providing Raspian with your product be sure to be familiar and compliant with the licensing terms of every software package in there.
Posted: Thu Dec 22, 2016 5:30 pm
by DougieLawson
That's precisely the reason the Compute Module (CM) and soon to be released CM3 exist.
Posted: Thu Dec 22, 2016 6:43 pm
by W. H. Heydt
Heater wrote:If you providing Raspian with your product be sure to be familiar and compliant with the licensing terms of every software package in there.
Or, most likely, any other software that might be used on a Pi, unless the OEM writes *everything* that goes with it, right down to the OS.
Posted: Thu Dec 29, 2016 4:33 pm
by TheLoadedRogue
Hi all,
Thanks for the replies.
OK so I can sell it but i need to get Raspberry Pi sign off essentially with regards to logo and title.
Posted: Thu Dec 29, 2016 4:47 pm
by DougieLawson
TheLoadedRogue wrote: OK so I can sell it but i need to get Raspberry Pi sign off essentially with regards to logo and title.
You won't get that, other folks have tried and the RPF/RPT response is always negative.
Posted: Thu Dec 29, 2016 5:37 pm
by GordonTGopher
TheLoadedRogue wrote:Hi all,
You may find this useful, https://www.raspberrypi.org/trademark-rules/ depending on what you are doing and how you describe it, you MIGHT be ok.
Gordon
Posted: Thu Dec 29, 2016 6:08 pm
by fruitoftheloom
Gordon
Yes, posted that link a week ago, must not be visible ?????
Posted: Thu Dec 29, 2016 6:09 pm
by stderr
Of course you can seem to get away with <insert fruit name that isn't raspberry> pi and even <insert fruit name that isn't raspberry> pi zero even when the product has nothing whatever to do with a raspberry pi.
Posted: Thu Dec 29, 2016 6:28 pm
by B.Goode
Gordon
Perhaps we could be charitable, given the season, and assume that @Gordon is having some fun at the expense of @Loaded who has been referred to that definitive resource but persists in pursuing the issue here?
Posted: Thu Jan 12, 2017 11:38 am
by TheLoadedRogue
Hey,
Sorry, i'm not trying to be dense, just a little confused.
The link provided talks about using the logo and title but I don't want to have that information anywhere on the device (other than on the Pi board itself).
Posted: Thu Jan 12, 2017 11:53 am
by B.Goode
If there is still any uncertainty perhaps you or your legal representative should contact the Raspberry Pi Foundation directly using the Contact Us details on their website.
These forums are largely run by volunteer helpers who are not qualified to make definitive statements on behalf of the Raspberry Pi Foundation.
Posted: Thu Jan 12, 2017 12:02 pm
by RaTTuS
yes you can sell it
you will not be able to put a RPi logo on it
if you case it you will have to get it though the EMC testing
you will have to comply with all software package rules.
you will need to employ a lawyer to be certain [ha] of what you need to do
if you are only going to be selling a few then you may get away with anything - though when they* come knocking you have to be ready
they* - someone , somebody , some people - probably not the foundation
Posted: Thu Jan 12, 2017 12:15 pm
by scotty101
You can of course get away with many things if you provide the unit in Kit form.
Posted: Thu Jan 12, 2017 12:31 pm
by rurwin
I am only aware of three things that are installed by default on the Raspberry Pi and that, IIUC, you cannot sell on:
  • The desktop photographs
  • TinyVNC
  • Mathematica
It is trivial to easy to remove those from the image that you supply.
However, this question is asking for an opinion of your legal position. The only person that can give you an answer that you can depend on is a lawyer who you have employed to give you that opinion. Any answers that we can give you are only suggestions. Even if we were lawyers, and I'm definitely not, we wouldn't have a contractual relationship with you and therefore our opinion would be worthless.
Posted: Thu Jan 12, 2017 1:06 pm
by gsh
Lots of companies buy Raspberry Pis and sell them on in this way. As has been suggested before you can't use the logo / word mark unless you get approval from Raspberry Pi. But this really means you can't call it a "Raspberry Pi-O-Tron" or use the logo on your packaging.
For EMC, it kind of depends, for selling in the EU you can get away with quite a lot but the regulations are harder on products containing radios (WiFi/BT). If you are going to put it inside a box then you can't just use the Raspberry Pi test results because what you've done will change the results of the test. For systems that don't need WiFi/BT you can instead use the Pi 2 revision 1.2 (or what some call the PI 2 plus). This has the BCM2837 device but does not have the WiFi / BT so you can get away with self-certifying the product (i.e. you can just write a letter to your customer saying that all the relevant testing has been done and refer to the certification from RS / Farnell.
Gordon
Posted: Thu Jan 12, 2017 2:45 pm
by W. H. Heydt
rurwin wrote:I am only aware of three things that are installed by default on the Raspberry Pi and that, IIUC, you cannot sell on:
  • TinyVNC
  • Mathematica
MinecraftPi?
Posted: Sat Jan 28, 2017 10:17 am
by TheLoadedRogue
Thanks for all the help folks!
I have a clearer idea of where i'm going with it now :)
