TRLLC
2 Displays through RPI?
Sat Dec 03, 2016 6:42 am
Is it possible to mirror 2 LCD displays connect to an RPI. So that both screens display the same image, if so what model is needed, and how would I go about connecting them.
Thanks for any help you can give-
Mandrewpi
Re: 2 Displays through RPI?
Sat Dec 03, 2016 4:13 pm
You can connect two displays but the pi doesn't support putting different programs on separate displays. The displays will have the same thing on them.
edit: I forgot to add you need a hdmi splitter as well to get the dual monitor, but the displays will still show the same thing.
A computer is only as smart as its programmer. ;)
I own:
Pi B rev.2, Pi 2 B, Two Pi 3 B, Two Pi 3 b+, Pi 4 2Gb, Pi Zero 1.2, Pi Zero 1.3, Two Pi Zero Ws.
I'm known elsewhere as mandrew1444
tinylcd
Mon Dec 05, 2016 4:59 am
hello
below is the ready to use product for dual display with mirror image for raspberry pi
http://www.neosecsolutions.com//product ... 9&cPath=20
regards
tinylcd
HermannSW
Mon Dec 05, 2016 5:29 pm
Just use two identical displays, and connect both.
If not enough power, one display may be darker than the other:
Hermann.
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/github_repo_i420toh264
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
