KeithSloan
running system command from python.
Wed Nov 02, 2016 2:57 pm
I am trying to run a system command from python.
The command I wish to run is echo "Some Text" | festival --tts
Python doc says system calls are all depreciated in favour of subprocess but I don't seem to be able to get subprocess to work, I assume because of the pipe
Paeryn
Re: running system command from python.
Wed Nov 02, 2016 3:52 pm
KeithSloan wrote:I am trying to run a system command from python.
Maybe something like :-
import subprocess
with subprocess.Popen(["festival", "--tts"], stdin=subprocess.PIPE, universal_newlines=True) as festival:
    festival.communicate("Some Text");
Or
import subprocess
subprocess.call('echo "Some Text" | festival --tts', shell=True);
I'd prefer the first way, better than passing the string to a shell.
She who travels light — forgot something.
KeithSloan
Thu Nov 03, 2016 3:32 pm
Tried
                                festival.communicate(l);
But got
  File "LetterBoard.py", line 123, in <module>
AttributeError: __exit__
Paeryn
Thu Nov 03, 2016 4:07 pm
Ahh, you're using python2 then (it works in python3), looks like you can't put it in a with clause in python2. Try
import subprocess
festival = subprocess.Popen(["festival", "--tts"], stdin=subprocess.PIPE, universal_newlines=True)
Or even (if you like long lines)
import subprocess
subprocess.Popen(["festival", "--tts"], stdin=subprocess.PIPE, universal_newlines=True).communicate("Some Text");
The universal_newlines=True bit allows sending normal strings via communicate(), if you omit it then you send and receive byte strings (it also converts any '\n' into the default line separator when sending and vice versa when receiving), e.g.
import subprocess
festival = subprocess.Popen(["festival", "--tts"], stdin=subprocess.PIPE)
festival.communicate(b"Some Text");
KeithSloan
Thu Nov 03, 2016 4:52 pm
Okay now get two error messages
xcb_connection_has_error() returned true
Also what is the correct way to close the spawned process down.
Paeryn
Thu Nov 03, 2016 6:06 pm
KeithSloan wrote:Okay now get two error messages
No idea on the xcb messages, something that uses xcb is issuing that, festival maybe? I've never used festival so I don't know anything about it.
As to closing the process, communicate() waits for the process to finish before returning, as long as festival quits when it's finished then you don't need to do anything.
KeithSloan
Thu Nov 03, 2016 8:06 pm
Googling for the error message xcb_connection error I found that it seemed to be something to do with pulse audio.
On trying to debug took me back to trying festival from the command line and got the same two error messages. A reboot seems to have cleared the problem.
Thanks for all your help.
