Eranath
Is it possible to connect rasperry pi display to zero
Mon Oct 31, 2016 7:11 pm
Greetings,
I have this thing i´m wondering about.
Is it possible to connect 7" Rasperry pi Display v.1.1 to Rasperry pi Zero.
Been trying to find if there´s adapter to that flat cable that would make it possible.
texy
Re: Is it possible to connect rasperry pi display to zero
Tue Nov 01, 2016 8:25 am
no you cannot connect the display to the zero as there is no display port on the zero.
Texy
tweak42
Tue Nov 01, 2016 9:10 am
Eranath wrote:Greetings,
If you are talking about the Official Screen then no, it requires a DSI port that the Zero lacks. The Zero only has mini hdmi for video out, so you would need a screen that connects using hdmi.
Pi compatibility is list here:
https://www.element14.com/community/doc ... en-display
HawaiianPi
Tue Nov 01, 2016 10:47 am
tweak42 wrote:If you are talking about the Official Screen then no, it requires a DSI port that the Zero lacks. The Zero only has mini hdmi for video out, so you would need a screen that connects using hdmi...
You should be able to use a screen that connects to the GPIO header as well (which would require adding the header pins to the Zero). Oh, and while we're on the subject of soldering on header pins, there is a composite video connection as well. So, HDMI, composite, or one of those mini touchscreens that connects to the GPIO header.
W. H. Heydt
Tue Nov 01, 2016 1:42 pm
I have a couple of Pi Zeros set up using the GPIO headers to connect, so--yes--that works.
If the OPs issue is size or power requirements, the Model A+ has a DSI connector and would work with the RPF 7" touchscreen.
tinylcd
Wed Nov 02, 2016 4:59 am
hello
on below link you can find various options for display for pizero
http://www.neosecsolutions.com/
regards
tinylcd
