rkanton
raspberrypi-sys-mods install failure
Tue Oct 18, 2016 6:03 pm
I just did a apt-get upgrade today (20161018) and it looks like there is a issue with the raspberrypi-sys-mods post install script. I think there is a missing "fi" before line 45 in the raspberrypi-sys-mods.postinst script.
Here's the console output:
Setting up raspberrypi-sys-mods (20161018+1) ...
/var/lib/dpkg/info/raspberrypi-sys-mods.postinst: 49: /var/lib/dpkg/info/raspberrypi-sys-mods.postinst: Syntax error: ";;" unexpected (expecting "fi")
dpkg: error processing package raspberrypi-sys-mods (--configure):
subprocess installed post-installation script returned error exit status 2
- Bob Anton
ShiftPlusOne
Re: raspberrypi-sys-mods install failure
Tue Oct 18, 2016 6:10 pm
ShiftPlusOne
Tue Oct 18, 2016 6:22 pm
Should be fixed now.
sudo apt-get update && sudo apt-get dist-upgrade
