SlowBro
Re: Raspbian with Read-only Root
Tue Nov 20, 2018 1:56 pm
I have my doubts that ejolson's workarounds will work for me as I will be doing 100% of updates remotely. When I do apt-get dist-upgrade and there is a new kernel I cannot yet create the initrd until the system reboots to the new kernel, whereupon the new kernel will lack critical modules and cannot connect to the internet, I2C, etc. I possibly could hack together a post-update script to rebuild the initrd and reboot but I don't have confidence in that.
I did find these notes suggesting the use of the followkernel flag which sounds like it would automagically maintain the initrd file with upgrades. But it comes with the same feared caveat, the possibility of a failed upgrade causing a loss of drivers. So I think next I will try a script that does not use initrd or initramfs such as this one.
Initramfs for custom loading of modules at boot does work, but you must update it everytime you use rpi-update, this way:
mkinitramfs -o /boot/initrd
In the Raspberry Pi 2 you must also include this in /boot/config.txt:
initramfs initrd followkernel
ramfsfile=initrd
ramfsaddr=-1
And this is /boot/cdmline.txt:
root=/dev/mmcblk0p2 initrd=-1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 elevator=deadline rootwait
Because rpi-update is not the official way that Debian updates the Initramfs, you may find weird things happening when you update rpi, so if your system becomes unbootable because there is a needed module in the initrd that you need (like encryption), you must boot with another up to date sdcard, chroot into the new environment, mounting first /boot and /dev, and then update the initrd manually. This just happens because of the privative special way of booting of the Raspberry Pi, out of any reasonable standard.
https://wiki.debian.org/RaspberryPi
ejolson
Tue Nov 20, 2018 5:57 pm
Unfortunately the followkernel option does not keep the initial RAM filesystem synchronised with the current kernel. Instead it affects the location where the image is placed in memory by the bootloader. As far as I can tell, followkernel is no longer needed as the defaults are reasonable.
The script you mention is nice because it sets up an overlayfs before running the system init process, while at the same time does not use an initial RAM filesystem. In this case the trouble of updating the same is avoided. I'm not sure mounting the overlays under the /mnt directory is such a good idea and I haven't tried that other script. Still, it looks straightforward enough to work well.
I would caution against any sort of updates in situations where recovering from failure to boot is difficult. In particular, there is no remote management engine available on the Raspberry Pi, so fixing a failure to boot in remotely deployed systems usually involves swapping SD cards. Depending on how remote the system is, this could be a significant difficulty. As a precaution, I would recommend keeping an identically configured system on your bench to verify each update before it is deployed to the remote system.
SlowBro
Tue Nov 20, 2018 6:56 pm
That and only roll it out to 10% of users at a time. Have you not encountered any issue updating the kernel ejolson -- or anyone?
ejolson
Tue Nov 20, 2018 7:30 pm
When using the method described in this thread, updating the kernel requires creating a new initial RAM filesystem. I've definitely made the mistake of forgetting to do this (or not having space on the /boot partition to do this) and ended up with a non-booting system.
Figuring out a reliable update mechanism for IOT devices in the field is a difficult problem. Many large companies don't do it correctly if at all. A Pi has the advantage that if something goes wrong with the flash update you can always swap the SD card. That generally can't be done with the flash memory in a Blu-ray player, WiFi router, mobile phone or lightbulb. Still, it is important that updates work for the Pi.
While updated Raspbian packages are tested before release to ensure apt-get upgrade doesn't break things, there are still reports on this forum of things breaking on default installs. The more an installation has been customised, the more likely updates will break things. Fortunately, the overlay filesystem approach to a read-only root does not involve many modifications; therefore, updates are usually still okay.
SlowBro
Wed Nov 21, 2018 12:07 am
So I'm guessing you always update the initrd with your Pi attached to your PC via serial or monitor via HDMI, and only after first rebooting to the new kernel?
ejolson
Wed Nov 21, 2018 1:32 am
I'm generally running my Pi computers no monitor no keyboard and connect through ssh. Luckily it is possible to generate the initial RAM filesystem before booting into the kernel, otherwise one would have to solve the problem about the chicken or the egg and which came first. Simply specify the new kernel using
# update-initramfs -c -k ZZZZZZ
where ZZZZZZ is the suffix of the new kernel even if the old kernel is still running.
TimG
Wed Nov 21, 2018 5:15 am
This may be relevant -- it's the script I use to create a read-only root, based on the recipe by ejolson. It detects the correct kernel version even after an apt-get upgrade.
There are a few other alterations: It automatically deals with ARM-v6/v7; it puts the overlay scripts in /etc rather than /usr/share/; and it disables auto-mount of /boot (don't forget to re-mount it before doing a kernel upgrade).
  # configure initramfs
  echo overlay >>/etc/initramfs-tools/modules
  cp -rp /usr/share/initramfs-tools/scripts/local* /etc/initramfs-tools/scripts/
  rename s/local/overlay/ /etc/initramfs-tools/scripts/local*
  patch -d/ -p0 <overlay.patch
  # create initramfs
  # hack for use after apt-get upgrade: get currently installed kernel, even if upgraded but not rebooted
  kver=$(dpkg -L raspberrypi-kernel |perl -ne 'if (/(\d+\.\d+\.\d+)(-v7)?\+$/) { print "$1"; exit; }')
  kver=$kver$(uname -r |perl -pe 's/\d+\.\d+\.\d+//')
  update-initramfs -c -k $kver
  mv /boot/initrd.img{-$kver,}
  # command line parameter
  perl -i -pe '$_="boot=overlay $_" unless /\bboot=overlay\b/' /boot/cmdline.txt
  # don't mount /boot
  perl -i -pe 's"^(.+\s/boot\s+vfat\s+defaults)(.+)"#$_$1,noauto$2"' /etc/fstab
The patch used by the script above:
--- /etc/initramfs-tools/scripts/overlay	2017-12-04 01:04:03.327799400 +0100
+++ /etc/initramfs-tools/scripts/overlay	2017-12-04 01:17:25.099966600 +0100
@@ -167,11 +167,11 @@
 	local_premount
-	if [ "${readonly}" = "y" ]; then
+#	if [ "${readonly}" = "y" ]; then
 		roflag=-r
-	else
-		roflag=-w
-	fi
+#	else
+#		roflag=-w
+#	fi
 	# FIXME This has no error checking
 	modprobe ${FSTYPE}
@@ -180,11 +180,18 @@
 	# Mount root
+	mkdir /upper /lower
 	if [ "${FSTYPE}" != "unknown" ]; then
-		mount ${roflag} -t ${FSTYPE} ${ROOTFLAGS} ${ROOT} ${rootmnt}
+		mount ${roflag} -t ${FSTYPE} ${ROOTFLAGS} ${ROOT} /lower
 	else
-		mount ${roflag} ${ROOTFLAGS} ${ROOT} ${rootmnt}
+		mount ${roflag} ${ROOTFLAGS} ${ROOT} /lower
 	fi
+	modprobe overlay
+	mount -t tmpfs tmpfs /upper
+	mkdir /upper/data /upper/work
+	mount -t overlay \
+		-olowerdir=/lower,upperdir=/upper/data,workdir=/upper/work \
+		overlay ${rootmnt}
 local_mount_fs()
Scripts to enable or disable the read-only root:
#!/bin/bash
# enable RO config
[ $(id -u) = 0 ] || { echo "$0 needs to run as root"; exit; }
mount /boot
# enable initramfs
perl -i -pe 'next if $ok; if (s/^#?(initramfs.+)/$1/) {$ok=1;} elsif (eof) {$_.="# --- read only ---\ninitramfs initrd.img\n";}' /boot/config.txt
# truncate logs to reduce overlay ram usage
:|tee /var/log/{daemon.log,syslog,lastlog,kern.log,messages,auth.log}
# reboot
echo -e "\nNB. READ-ONLY ROOT !!!\n" >/etc/motd
shutdown -r now
#!/bin/bash
# restore RW config
mount /boot
# disable initramfs
perl -i -pe 's/^(initramfs.+)/#$1/;' /boot/config.txt
# reboot
echo -e "\nNB. READ-WRITE ROOT !!!\n" >/etc/motd
shutdown -r now
SlowBro
Wed Nov 21, 2018 10:39 am
Good stuff.
Another way to handle this may be to have a bootup script check if certain modules are loaded. If not, reboot to read/write mode, rebuild the initrd, reboot again to read only.
Yet another way may be to wrap apt update commands in a script (that checks if the file system is read only) and if after updating a new kernel is installed and detected, build the initrd for the new one before rebooting.
I think I like the bootup script option best. Should be the most robust but would be the harder of the two to implement.
wksu
Sun Dec 30, 2018 2:25 am
> perl -i -pe 's"^(.+\s/boot\s+vfat\s+defaults)(.+)"#$_$1,noauto$2"' /etc/stab
This should have been for /etc/fstab.
Also the procedure is missing the part about adding "overlay" to "hook-functions".
There may still be other differences. Even accounting for these I could not get
it to work for my Raspberry Pi Zero W. I am doing headless setup with no visibilty
so I can't debug. I would leave it here for now.
TimG
Wed Jan 02, 2019 1:20 pm
Good catch. That seems to be a copy-paste error. I've corrected the code in the post above. (In any case that should not prevent the root partition being made read-only.)
This is taken care of on the second line, echo overlay >>/etc/initramfs-tools/modules, and saves editing hook-functions.
I'm using this script as part of my standard Pi setup procedure, so it definitely ought to work. Are you running the script in an ssh terminal? What output does it give?
bouwew
Tue Jan 22, 2019 1:54 pm
@TimG:
I am using you scripts in my read-only Pi-system.
Today, I performed an update: switch to RW-mode, mount /boot and run the upgrade.
During the update I see these messages:
Processing triggers for mime-support (3.60) ...
Processing triggers for libc-bin (2.24-11+deb9u3) ...
Setting up udev (232-25+deb9u8) ...
addgroup: The group `input' already exists as a system group. Exiting.
update-initramfs: deferring update (trigger activated)
Setting up systemd (232-25+deb9u8) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
Processing triggers for man-db (2.7.6.1-2) ...
Processing triggers for shared-mime-info (1.8-1+deb9u1) ...
Processing triggers for dbus (1.10.26-0+deb9u1) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
Setting up systemd-sysv (232-25+deb9u8) ...
Setting up oracle-java8-set-default (8u201-1~webupd8~1) ...
Setting up libpam-systemd:armhf (232-25+deb9u8) ...
Processing triggers for initramfs-tools (0.130) ...
/boot/initrd.img-4.14.79-v7+ does not exist. Cannot update.
Are the errors related to initramfs real errors, or can I ignore these messages?
bouwew
Wed Jan 23, 2019 7:47 am
@TimG:
As a follow-up on my email below, I looked in detail at your scripts to understand what they do.
I think I have an idea to improve these:
1) in the first script, instead of
use
cp /boot/initrd.img{-$kver,}
This leave the original in place, which is then present when the regular upgrade-process requires it.
2) in the enable ro script add:
By adding this a fresh initrd.img file is created when turning to the RO-state. Good to do after the original img-file has been updated by the upgrade-process.
Maybe the 3rd line is not needed, as the regular upgrade-process already does that?
Does this make some sense? Or do I misunderstand the original code?
TimG
Wed Jan 23, 2019 12:24 pm
Hi bouwew,
I think the "/boot/initrd.img-4.14.79-v7+ does not exist. Cannot update." message is a hang-over from Debian which expects a different kernel file naming scheme. Use it as a reminder that initrd.img needs to be updated by hand.
Probably if you had a copy of initrd.img named with the appropriate version the .deb scripts would update it automatically, but I haven't tested this. You'd still need to rename it by hand, or update /boot/config.txt. In any case my /boot partition does not have enough free space for that (not sure why it's made so small by default).
My suggestion would be wrap up "apt-get upgrade" and "update-initramfs -c -k $kver" in a script which can be run separately from the RO/RW scripts (don't forget to mount /boot and check for free space).
Aside: the line "echo -e "\nNB. READ-WRITE ROOT !!!\n" >/etc/motd" in the RW script fails because the filesystem is still RO at that point. It would be better to add something to /etc/profile to produce these messages.
bouwew
Fri Jan 25, 2019 2:46 pm
Hi TimG,
Thanks for answering!
Ok, I understand what you mean.
I will try your suggestion, see if that works.
But, maybe better to update (-u) instead if creating a new one (-c): "update-initramfs -u -k $kver"?
kytkija
Fri Feb 15, 2019 10:37 pm
Has anyone got the overlayfs working with 3B+?
I am total beginner, but it would be crucial for my project. I cant find exact/fresh information anywhere. Is it possible with newest stretch, anyone got tips where to find script? It should be ready script or well documented, because i dont have much understanding on linux (yet).
I would appreciate any help :) I will test atleast the adafruit script.
amirfh
Wed Mar 20, 2019 10:38 pm
check this for rpi3b+ :
https://github.com/JasperE84/root-ro
duren
Wed Jul 31, 2019 5:09 am
I'm currently testing out the following instance of the overlay solution on an RPI1B with Raspbian Buster Lite and it's looking quite promising.
Had to install initramfs-tools, also installed busybox and bindfs but not sure if they are required.
Even though tmp and log are now in ram by default, to ensure they don't eat all the ram used by the overlay, I have explicit tmpfs settings in /etc/fstab
tmpfs /tmp tmpfs size=8m,defaults,relatime,mode=0755 0 0
tmpfs /var/log tmpfs size=16m,defaults,relatime,mode=0755 0 0
I think this is a good idea because it also keeps tmp and log in ram when / is temporarily or semi-permanently mounted as rw.
One good addition would be partitioning a part of the card as permanently rw that can be written to on a cron schedule to archive logs. In the meantime, one could set up remote logging or rsync to push or pull logs.
ivtenev
Mon Dec 30, 2019 8:12 am
Hi guys,
Here you are my 5 cents regarding readonly root. Tested on on raspbery pi 3, survaiving kernel updates:
1) instruct initramfs scripts to include overlay module into boot image:
add the word
overlay
to a new line in the /etc/initramfs-tools/modules[/b]
2) instruct init to remount root to readonly overlayfs during boot
add the following lines to a new file: /etc/initramfs-tools/scripts/local-bottom/overlay
#!/bin/sh        PREREQ=""        prereqs()        {        echo "$PREREQ"        }        case $1 in        prereqs)        prereqs        exit 0        ;;        esac        . /scripts/functions        # Begin real processing below this line        if [ "${overlay}" = "y" ] ; then        modprobe overlay        mkdir /upper /lower        mount -n -o move ${rootmnt} /lower        mount -t tmpfs tmpfs /upper        mkdir /upper/data /upper/work        mount -t overlay -olowerdir=/lower,upperdir=/upper/data,workdir=/upper/work overlay ${rootmnt}        mount -n -o move /upper ${rootmnt}/upper        mount -n -o move /lower ${rootmnt}/lower        fi        exit 0
3) recreate initramfs image
update-initramfs -c -k $(uname -r)
mv /boot/initrd7.img /boot/initrd7.img.bac
mv /boot/initrd.img-$(uname -r) /boot/initrd7.img
Inspired by: ejolson and https://manpages.debian.org/buster/init ... .7.en.html
pagenotfound
Mon Dec 30, 2019 2:06 pm
Has anyone tried the method that comes out of the box with Raspbian?
Preferences -> Raspberry Pi Configuration -> Performance -> Overlay File System -> Configure
ejolson
Mon Dec 30, 2019 4:00 pm
I believe it works and is essentially the same idea. The present thread includes details about how to configure an initial RAM filesystems that are also useful for other purposes. Since the Raspbian developers have tighter control over the init process, I think they get by without need for an initial RAM filesystem.
In either case, once the system is up and running, all changes to the filesystem are stored as an overlay in RAM. This means that the 1GB limit RAM limit of earlier Pi models can quickly be exhausted and as a result the 4GB Pi 4B is likely to work better and longer in this mode.
barsznica
Mon Jan 06, 2020 2:09 am
I am trying this out on Buster.
Editing the overlay file, I'm not sure what to do with the new (to me) lines in local_mount_root,
        # Mount root
        # shellcheck disable=SC2086
        if ! mount ${roflag} ${FSTYPE:+-t "${FSTYPE}"} ${ROOTFLAGS} "${ROOT}" "${rootmnt?}"; then
                panic "Failed to mount ${ROOT} as root file system."
        fi
The Pi boots with the overlay whether the lines above are commented out or not.
Should these lines be commented out or not?
