kusti8
Re: RPF Chromium Browser "sign into chromium" not working
Tue Oct 04, 2016 10:49 am
aworan wrote:
kusti8 wrote: It's an issue with the API keys that got overloaded and disabled. A new release is coming soon.
Is the source code will be publish by the RPF ?
Thank you
viewtopic.php?p=1046687#p1046687
kusti8
Tue Oct 04, 2016 6:29 pm
Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.
Tue Oct 04, 2016 7:48 pm
kusti8 wrote:Already said in another thread, but the issue has been solved and an update will fix it. This also adds support for widevine if you need it.
Thanks and thankks again the Google Account Synchronization is FIXED :D :D :D :D :D :D
Retired disgracefully.....
2mandude
Tue Oct 04, 2016 10:38 pm
Wait how did you apply this patch already? Has the update already been released, cause I just updated chromium on my raspberry pi 3 model B and it still won't let me sign in and sync?
jakky567
Re: RPF Chromium Browser "sign into chromium" (SOLVED)
Wed Oct 05, 2016 12:55 am
Sync is working for me again as well :).
Malman35
Wed Oct 05, 2016 2:25 am
Did you do
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgade
Thank you so much for all your effort kusti8! It is working fine for me now. Just out of curiosity what is widevine?
cjan
Wed Oct 05, 2016 2:43 am
Malman35 wrote: Thank you so much for all your effort kusti8! It is working fine for me now. Just out of curiosity what is widevine?
widewine libs for drm websites like Netflix.
Malman35
Wed Oct 05, 2016 2:45 am
Ah OK. Thanks. :)
2mandude
Wed Oct 05, 2016 4:02 am
Malman35 wrote:
2mandude wrote:
fruitoftheloom wrote: Thanks and thankks again the Google Account Synchronization is FIXED :D :D :D :D :D :D
Did you do
sudo apt-get update
I just finished running all of those commands, but chromium-browser is still telling me "Service unavailable" :(
Malman35
Wed Oct 05, 2016 4:06 am
2mandude wrote: I just finished running all of those commands, but chromium-browser is still telling me "Service unavailable" :(
Just a suggestion but you could try uninstalling then reinstalling it and see if that helps. Anybody else have a better suggestion?
Wed Oct 05, 2016 4:08 am
What version of Chromium Browser ???
2mandude
Wed Oct 05, 2016 4:23 am
I really appreciate the help, thanks so much guys. Hopefully, I can get it to work soon. I'm gonna try to reinstall right now, and right now im on chromium 51.0.2704.106
Edit: Darn, still no luck..
Wed Oct 05, 2016 6:28 am
2mandude wrote:I really appreciate the help, thanks so much guys. Hopefully, I can get it to work soon. I'm gonna try to reinstall right now, and right now im on chromium 51.0.2704.106
51.0.2704.91-0ubuntu0.14.04.1.7012 is the version listed in Synaptic Package Manager as latest from RPF, I am running Jessie with Pixel fully updated on a RPi ZERO.
SvenVT85
Wed Oct 05, 2016 9:04 am
Thanks a lott for fixing the "Sign in issue"!!!!
Kratos
Wed Oct 05, 2016 8:11 pm
Can confirm it works here as well. I had to uninstall chromium first, and then update. Working great, thanks! :D
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
rmettier
Thu Oct 06, 2016 8:15 pm
Nope, still no joy.
After fully updating/upgrading/dist-upgrade uninstalling/purging and reinstalling chromium-browser, I still getting the "Uh-Oh...service unavailable" message.
Am I missing anything?
Sat Oct 08, 2016 8:59 am
rmettier wrote:Nope, still no joy.
Have you got Chromium Browser version ""51.0.2704.91-0ubuntu0.14.04.1.7012"" ??
2mandude
Sat Oct 08, 2016 7:29 pm
How did you find that version? I checked synaptic package manager as you mentioned earlier, and I'm still getting this chromium version: 51.0.2704.106.
Is there another way to access the older one that you have, because this latest one doesn't let me sign in. Or maybe I didn't install synaptic correctly? idk.. im pretty new to the pi
kusti8
Sat Oct 08, 2016 9:54 pm
2mandude wrote:How did you find that version? I checked synaptic package manager as you mentioned earlier, and I'm still getting this chromium version: 51.0.2704.106.
sudo nano /etc/apt/sources.list
Remove the source relating to Ubuntu (something like launchpad) because those instructions were flawed. Then
sudo apt-get update
sudo apt-get purge chromium-browser
sudo apt-get install chromium-browser
rmettier
Sun Oct 09, 2016 4:21 pm
The bit about removing the Ubuntu related source entry finally did it. Works now with the version you mentioned.
Thanks for your work and the great support.
psm9
Fri Oct 21, 2016 2:19 pm
I'm also new to Raspberry Pi. I followed the directions above and it keeps re-installing Chromium 51.0.2704.91
when I enter this code in:
I get this:
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free r$
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://dl.bintray.com/kusti8/chromium-rpi jessie main
Nothing about Ubuntu sources. What am I doing wrong?
Thanks for the help
kusti8
Fri Oct 21, 2016 6:34 pm
That's correct. That's the version you should be on. No problems there.
psm9
Sat Oct 22, 2016 1:55 am
Thanks for replying.
So, if that's all set. When I run:
sudo apt-get update
sudo apt-get purge chromium-browser -y
It installs the same version of Chromium (51.0.2704.91). Anything else I'm missing?
I actually did this yesterday and got it to work. Then, today I messed up my video settings, so I re-formatted my SD and re-installed NOOBS. Now, I can't seem to get it to install the newer Chromium version
thanks again
kusti8
Sat Oct 22, 2016 3:52 am
That is the newer version of chromium. There is absolutely no problems with that version and it is the latest. Any reason you're working about that?
psm9
Sat Oct 22, 2016 11:36 pm
It works.
I kept getting "service unavailable" yesterday, but I wonder if that was from the internet outages yesterday. Works great now.
Thanks for helping
