Best way to Power a Pi3 without USB?
Posted: Tue May 17, 2016 10:59 am
by ThomasDr
Hallo,
Where is the best place to supplied a Rpi 3 with power, when i not use the micro USB?
Over the GPIO or solder parallel to D5?
regards
Thomas
Re: Best way to Power a Pi3 without USB?
Posted: Tue May 17, 2016 12:10 pm
by darkbibble
you can power the pi via GPIO by connecting to the +5v and the grnd pins, BUT this can be risky as it bypasses the pi safety fuse.
Posted: Tue May 17, 2016 1:00 pm
by klricks
ThomasDr wrote:Hallo,
regards
Thomas
Solder +5V to test pad PP1 or PP2 or to fuse pad closest to the edge of the board. Any of these 3 points are before the fuse ....same as using micro USB. (D5 or GPIO is after the fuse).
For Ground I would use any of the port shield hold down tabs on the bottom of the board. RJ45..HDMI etc.
Posted: Tue May 17, 2016 2:42 pm
by davenull
hello,
just out of interest:
what and where is PP1 or PP2 ?
Posted: Tue May 17, 2016 2:50 pm
by Mandrewpi
davenull wrote:hello,
They are labeled on the back side of the board under the micro usb input.
Posted: Tue May 17, 2016 2:55 pm
by davenull
aha, thank you!
