procount
Re: STICKY: PINN - An enhanced version of NOOBS.
Thu Sep 20, 2018 9:52 am
As far as I can tell, a compatible 3B+ version of Ubuntu-mate is not available.
Please see https://ubuntu-mate.community/t/raspber ... port/17791
You may be able to roll your own if you find the appropriate threads on that forum.
Or you could try the Raspex version in PINN which is Ubuntu 18.04 with LXDE.
Thu Sep 20, 2018 10:02 am
feelslikeautumn has been able to get RPi 3B+ supported Ubuntu, there are several posts:
https://www.raspberrypi.org/forums/sear ... 1&sr=posts
Retired disgracefully.....
procount
Thu Sep 20, 2018 10:36 am
Yes, I am aware of his work. Can't remember if his image includes the Mate desktop.
But in any case, it is not included in PINN.
DarkPlatinum
Contact: Website YouTube
Thu Sep 20, 2018 1:47 pm
procount wrote:
Wed Sep 19, 2018 9:06 pm
ProjectSpaces are for common linux OS layouts with 2 partitions. Android normally has 3 partitions.
You would have to do some manual repartitioning to get it to fit. Better to backup and start again unless you know what you're doing.
I could re partition it. For emteria what are the sizes i should make for each partition? What filesystem ?
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
procount
Thu Sep 20, 2018 2:03 pm
Have a look at partitions.json for Emteria. It might be best to download it to a USB stick first.
DarkPlatinum
Thu Sep 20, 2018 2:09 pm
It might be best for me to download PINN on an sd card and get emteria.
procount
Thu Sep 20, 2018 2:19 pm
:D
DarkPlatinum
Thu Sep 20, 2018 5:20 pm
:D
Ok havin errors when tryn t install emteria on fresh pinn sd card. unsupported file type, xz.
Haris1977
Mon Sep 24, 2018 7:59 am
I really thing the "Sticky Default OS" should be somehow altered.
I know how it works now, but i do not like the idea of bypassing the 10 sec bootmenutimeout option. I think it is better to have the possibility (if we want) to use both options together (like berryboot does). Sticky default OS + the 10 second boot time menu option. In that way PINN will always boot to the OS that we prefer AND give us the 10 sec time to alter to a different OS when we want. And - the most crucial - ...in next reboot sticky default OS will be booted again !
P.S1 E.g 95% of my time i want to boot into LibreELEC. But, if i change that and boot into let's say Raspbian, PINN will remember this last OS choice and boot into Raspbian by default each time from now on, unless a different option is selected. So i need to boot again into LE to correct this..This is just wrong :)
PS2 I know i can use the shift button to temporarily boot into another OS but..it is a little cumbersome for some ppl like me (i do not use a keyboard, only my remote)
So @procount can you add that option for the ppl who want both sticky default and bootmenutimeout?
procount
Mon Sep 24, 2018 12:53 pm
@Haris1977 - /testing/pinn-2854a.zip, but you must explicitly set a `bootmenutimeout=XX` in recovery.cmdline, otherwise it will work as now.
Haris1977
Mon Sep 24, 2018 1:18 pm
@procount i will install it and report back :D Thanks!
Haris1977
Mon Sep 24, 2018 1:49 pm
Well. It doesnt work.
I ve downloaded LE+Raspbian (as test files), added the bootmenutimeout=5 in cmdline and ticked LE as "sticky default".
When i started raspbian - rebooted it - let it see what happens after 5 second and..raspbian again :arrow: (it seems as sticky default is overrided by the boot time menu option)
procount
Mon Sep 24, 2018 2:02 pm
Funny, it worked fine for me. Can you open a github issue so we can discuss it over there?
Haris1977
Mon Sep 24, 2018 2:10 pm
Ok i have opened a complete github issue with the whole conversation here. Thanks!
Haris1977
Tue Sep 25, 2018 11:51 am
@procount thanks for your github help. I will play with my cec settings a little bit.
What about the os renaming option? Are you working on it?
Btw in your new 2854a.zip version recalboxOS-rpi3 has no thumbnail image in the initial install screen ..
procount
Tue Sep 25, 2018 12:23 pm
I'm working on a lot of things. :)
There is no image icon of recalbox in any version. Probably just a temporary network problem.
Haris1977
Tue Sep 25, 2018 12:40 pm
That's cool :D
Oh ok:) Thought it was a rpi3 issue
DarkPlatinum
Tue Sep 25, 2018 5:51 pm
Emteria removed?
procount
Tue Sep 25, 2018 7:44 pm
Yes,
https://www.raspberrypi.org/forums/view ... 0#p1367512
I had a problem with installing Emteria from the internet, so I will have to repackage it for PINN.
Haris1977
Wed Sep 26, 2018 1:33 pm
I upload my custom wallpaper file just in case anyone wants to have a look:
https://imgur.com/a/FuBhga3
procount
Wed Sep 26, 2018 1:47 pm
I posted 3 wallpapers that I like on PINN's sourceforge website:
https://sourceforge.net/projects/pinn/files/wallpapers/
Rename one to `wallpaper.png` and place it in PINN's Recovery partition (usually /dev/mmcblk0p1) for it to be used.
Haris1977
Wed Sep 26, 2018 1:52 pm
Thanks 4 sharing :D
Haris1977
Thu Sep 27, 2018 1:01 pm
If a new update is installed, do we loose any PINN options that have been added to the recovery.cmdline?
procount
Thu Sep 27, 2018 1:23 pm
Not if you accept the self-update, or go to the maintenance page to reinstall PINN to check for a new update.
Haris1977
Thu Sep 27, 2018 1:30 pm
So there is no need to remove the no_update option in the recovery.cmdline? I just go to maintenance page select PINN and hit re-install? And that will do the job?
