goldie.mctraveller
Motioneyeos not working on Pi 3
Thu Mar 24, 2016 4:08 am
Just got my sparkly new Raspi 3. Moved the working Motioeyeos SD card from my Raspi 2 to the 3, and all I get is a colourful square on the screen. Moved the card back to the 2 and all worked fine. Back to the 3 - pretty square again.
Any ideas?
I've downloaded Raspbian (Wheezy or Jessie - I forget ) and that works fine on the 3, but oh the drama to stream video, hence the desire to use Motioeyeos.
texy
Re: Motioneyeos not working on Pi 3
Thu Mar 24, 2016 7:46 am
Hi and welcome to the forum.
Yeah that is pretty much expected as firmware updates are required when running a Pi3 over a pi2 image. I've no idea what 'Motioeyeos' is, but I suggest you contact them and ask if there is a pi3 compatible updated image.
Texy
ghodan
Thu Mar 24, 2016 9:49 am
In the old post (for example not being able to boot pwnpi image on pi2 , as pwnpi was made for Pi-B) that you could manually download latest Pi firmware files and put it in the correct folders on your SD card.
Is that not a option?
Pi firmware:
https://github.com/raspberrypi/firmware
They do this trick here:
viewtopic.php?f=28&t=22215&sid=f061e9ee ... 5&start=25
@ Texy:
https://github.com/ccrisan/motioneyeos
Security cam OS for Pi
MattHawkinsUK
Tue Aug 23, 2016 9:46 am
This is an old thread but for the benefit of Google visitors I'll add this ..
MotionEyeOS supports all the Pi models but you my need a specific image for that model. Here is a list of supported boards with a link to the image file you need :
MotionEyeOS Supported Hardware Boards
It's so easy to setup if you change Pi model you are probably best just using a fresh SD card and re-configuring it.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
PcMac
Sat Apr 21, 2018 8:28 am
Motioneye setup, working, ftp uploads, email notifications
Motioneye: https://www.youtube.com/playlist?list=P ... IBPedS4zK7
