Connecting a floppy drive to my machine.
Posted: Fri Mar 04, 2016 10:57 pm
by EroEdellabrina
Hello, i'm working on making an NES emulator that reads games from floppy disks. I am okay with the OS, but i can't figure out how to connect a 34 pin floppy drive to the raspberry pi. If someone can help me i'll be glad, thank you.
Re: Connecting a floppy drive to my machine.
Posted: Sat Mar 05, 2016 12:40 am
by klricks
There is no feasible way to get a floppy drive working on a RPi by direct connection. Even if you could make the electrical connection nothing would happen without extensive programming of drivers etc.
Your only option would be to get a USB floppy drive but I have no idea if there is one that will work on the RPi?
Also many years ago I tried loading some old floppies and none of them would work. The magnetic recording on the disk weakens over time making the disks unusable.
Posted: Sat Mar 05, 2016 1:04 am
by asandford
EroEdellabrina wrote:Hello, i'm working on making an NES emulator that reads games from floppy disks. I am okay with the OS, but i can't figure out how to connect a 34 pin floppy drive to the raspberry pi. If someone can help me i'll be glad, thank you.
Only the even pins carry a signal, the odd pins are ground. Someone has done an Arduino floppy controller.
Posted: Sat Mar 05, 2016 1:09 am
by stubright
As klricks said a USB floppy would probably be your best bet. I just tested a Dell one and I could mount it using gnome-disk-utility under Raspbian.
How easy it would be to mount in an emulator is anyone's guess, how reliable, again anyone's guess.
The floppy drive I used was a Dell fddm-101. I'm sure they'll be on fleabay.
It's an old laptop one, interchangeable with a cdrom (with a usb connector on the side).
https://ixquick-proxy.com/do/show_pictu ... 70c6d30662
Stu
Posted: Sat Mar 05, 2016 7:57 am
by hansotten
USB floppy drives work fine on a Raspberry, I have got a Freecom type, that just works with standard FAT formatted floppies.
What you will not get to work with USB is low level access, dumping tracks etc to overcome non-standard formatting. For those tools you will need a standard PC floppy interface, 765 IC based for example. Not available afaik for a Raspberry.
Or you could look at virtual floppy drives like the Catweasel (See a blog article on Adafruit).
