tech-mech
Contact: Yahoo Messenger
Windows Wordpad replacement
Thu Feb 25, 2016 11:54 pm
I have a file I want to still use with Wordpad but edit it on my Pi. I do not want to use a full word processor because of load time. Also I do not want to reformat the file.
Any suggestions?
W. H. Heydt
Re: Windows Wordpad replacement
Thu Feb 25, 2016 11:55 pm
vi
asandford
Fri Feb 26, 2016 12:30 am
If you want to edit on windows, use notepad++ as it won't add extra control characters that linux will object to (as well as many other nice features).
W. H. Heydt wrote:vi
Although I use it umpteen times a day, I wouldn't inflict it on my worst enemy.
DirkS
Fri Feb 26, 2016 12:49 am
asandford wrote:If you want to edit on windows,
Op wants to edit the doc on the Pi...
DirkS
Fri Feb 26, 2016 12:50 am
tech-mech wrote:I have a file I want to still use with Wordpad but edit it on my Pi. I do not want to use a full word processor because of load time. Also I do not want to reformat the file.
Is it a text or an RTF document?
W. H. Heydt
Fri Feb 26, 2016 1:00 am
asandford wrote:If you want to edit on windows, use notepad++ as it won't add extra control characters that linux will object to (as well as many other nice features).
It's not like it's all that hard to learn enough vi commands to do most editing. The more advanced commands are of more use with files formatted with the ms (and related) macro set for *roff programs. You can get by pretty well with less than a dozen commands.
asandford
Fri Feb 26, 2016 1:03 am
Yes, I did read that bit, but they still want to edit with wordpad (a windows editor), so I suggested they use notepad++ instead.
asandford
Fri Feb 26, 2016 1:10 am
W. H. Heydt wrote: It's not like it's all that hard to learn enough vi commands to do most editing. The more advanced commands are of more use with files formatted with the ms (and related) macro set for *roff programs. You can get by pretty well with less than a dozen commands.
No, it's not hard, just very hostile. The OP should stick to leafpad. If IBM ever ported XEDIT and REXX, I'd be very happy (I know there are forks, but I want the whole 3270 experience).
W. H. Heydt
Fri Feb 26, 2016 2:10 am
Having done command level CICS programming, I can quite happily live without further "3270 experience".
ghodan
Fri Feb 26, 2016 7:50 am
gedit or nano ?
gedit = Text editor in your desktop environment (pre-installed on rasbian)
nano = Text editor in command line interface
morphy_richards
Fri Feb 26, 2016 7:56 am
joe
sudo apt-get install joe (it's fairly tiny, size wise)
Only commands you need to remember are
Ctrl-c : quit without saving
Ctrl-k-x : quit and save
Ctrl-k-h : helpfully list of all the other commands you might ever need in letter box at the top of the terminal.
ghans
Fri Feb 26, 2016 8:13 am
I think people forget that Wordpad works as WYSIWYG word processor for RTF and MSWord documents - and the only tools which
are comparable are therefore Abiword , the Open/LibreOffice Writer and TED (RTF only ?) :
wget http://ftp.nluug.nl/pub/editors/ted/ted-2.23.src.tar.gz
tar -zxvf ted-2.23.src.tar.gz
cd Ted-2.23
sudo ./apt-get-prerequisites.sh
ln -s freetype2 /usr/include/freetype
make
sudo make install
ghans
Forrrge
Fri Feb 26, 2016 8:19 am
Searching around Geany was mentioned as a good replacement for notepad ++
Another option for a minimalist word processor is FocusWriter.
mattmiller
Fri Feb 26, 2016 8:21 am
I recommend setting up Samba on your Pi and then using Notepad++,as others have suggested, to edit the file on the Pi over your network
pUnK
Fri Feb 26, 2016 5:51 pm
You can use ExaGear Desktop + wine to run original windows Wordpad.
But ExaGear Desktop is not free.
ExaGear Desktop - run x86 apps on Raspberry Pi
pUnK from Eltechs
