partis
Re: SD Card Access
Mon Nov 14, 2011 11:09 pm
Hi all
I asked yesterday about GPU access documentation - if only simple read/write to a framebuffer after 'something' sets up said framebuffer.
Further to this, is the SD card accessed via the GPU or the CPU? The reason for asking is the implication of the GPU having control over the SD card due to the booting mechanism (or have both devices have some form of shared access?).
Is the method SD card access going to be made public (even if it requires bit banged IO)?
Cheers
Gary Partis
Gary Partis
asb
Re: SD Card Access
Mon Nov 14, 2011 11:16 pm
My understanding is SD access is all through GPLed kernel code.
Arreladd
Re: SD Card Access
Mon Nov 14, 2011 11:25 pm
Another good question I have been wondering is, What is the max SD card size that the system can support? plus I have used an SD card adapter which takes to micro SD cards and turns them into 1 Standard SD Card. The adapter is pretty inexpensive and getting that and a couple of micro SD cards (best results are with 2 of the same kind/size) this usually is cheaper than buying the larger size standard SD card.
partis
Re: SD Card Access
Mon Nov 14, 2011 11:44 pm
Hi asb
Quote from asb on November 14, 2011, 23:16
Sorry, I didnt ask the question correctly...
Can the ARM CPU access the SD Card IO directly (ie. not thru the GPU) and will it be documented? This is external to Linux kernel, being that Linux would not be running on the platform.
Cheers
Gary
Gary Partis
Montekuri
Re: SD Card Access
Mon Nov 14, 2011 11:51 pm
Quote from Arreladd on November 14, 2011, 23:25
Another good question I have been wondering is, What is the max SD card size that the system can support? ...
There are some topics about this question:
http://www.raspberrypi.org/for.....#038;t=167
http://www.raspberrypi.org/for.....#038;t=483
It seems to be 8Gb the maximum size, but I'm not sure.
liz
Raspberry Pi Foundation Employee & Forum Moderator
Re: SD Card Access
Mon Nov 14, 2011 11:53 pm
Quote from partis on November 14, 2011, 23:44
Hi asb
It does, and it will be documented. It's just an SDHCI peripheral. ;)
Director of Communications, Raspberry Pi
MmmPi
Re: SD Card Access
Tue Nov 15, 2011 1:01 am
Two MicroSD to Standard SD adapter? I have never seen that. Do you have a link? I have only seen a Two MicroSD to Memory Stick adapter.
