flightisfun2001
Sound on Raspberry Pi
Thu Jan 07, 2016 5:43 pm
I am having problems with getting my Raspberry Pi B+ to get sound. I use a DVI-HDMI cable for my Dell DVI monitor. I hear it is impossible to get audio through DVI, but the audio output (headphone jack) doesn't work either. Does anyone know how to fix this problem?
Thanks.
Re: Sound on Raspberry Pi
Thu Jan 07, 2016 6:14 pm
flightisfun2001 wrote:Hello,
Thanks.
https://www.raspberrypi.org/documentati ... -config.md
Retired disgracefully.....
......to an uncomplicated life !
Douglas6
Thu Jan 07, 2016 8:13 pm
You'll probably need to
amixer cset numid=3 1
It used to default 0 (auto) but lately it defaults to 2 (HDMI).
If that works, you can make it permanent with raspi-config, advanced options.
NormanDunbar
Fri Jan 08, 2016 12:39 pm
Please excuse the self-plug, but ....
if you can't be bothered remembering all those amixer commands etc, then may I respectfully recommend PiSound at https://github.com/NormanDunbar/PiSound which lets you do stuff like:
sound headphones
or
sound hdmi
and other useful things like setting the volume:
sound 60%
And reading the current volume:
sound volume
60%
And so on. It's a simple python script, one of my first ever, and it works fine - so far!
HTH
Cheers,
Norm.
Why do they put lightning conductors on churches?
Why did Tarzan never have a beard?
312capri
Sat Jan 09, 2016 11:30 pm
After using the nano editor to eliminate the comment # on #hdmi_drive=2 in my config.txt file saving and then rebooting the sound finally plays thought the HDMI monitor speakers. I had to manually change directories to the Boot directory before I could modify the config.txt file. Using the Sonic Pi example files as the test. Attempting to modify the "RASPI-CONFIG and Advanced Options, Audio did not work.
Thanks for everyone's assistance.
flightisfun2001
Thu Jan 14, 2016 6:20 pm
The sudo amixer cset numid=3 1 did work. Thanks!
