mickey1940
Noobs won't work with Display
Sun Jan 03, 2016 9:48 pm
When using Noobs I can not get the Display to operate.
I'm using a HDMI to VGA adapter on Raspberry Pi 2
If I install Raspbian-Jessie and make the following modification to /boot/config.txt :
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=16
hdmi_drive=2
I can get the Display to work fine
I do not use Noobs to install Raspbian, I install it with dd .
How can I get Noobs to use Display ?
mickey1940
Re: Noobs won't work with Display
Mon Jan 04, 2016 6:54 pm
I also got Ubuntu Mate display working with the above settings.
Mon Jan 04, 2016 7:31 pm
If you're competent enough to get Jessie running by dd'ing it to a card you do not need NOOBS. NOOBS will just frustrate you and steal up to 1.5GB of "wasted" space on your SDCard. Stick with the stuff you've got working.
This is a doctor free zone.
