I ran this command to do a very simple benchmark.
(from a console, not within X)With the over-voltage overclock (over_voltage=6, arm_freq=1000, core_freq=500, sdram_freq=500, the "real" time was:Code: Select all
time echo "scale=2000;4*a(1) | bc -l
15.774 secs.
With the "safe" overclock, (arm - 850, sdram - 500, gpu - 250), I got:
22.339s
With no overclocking:
22.464s
As a quick comparison, I ran the test on my Arch installation (this is using the same "safe" overclock) and got:
20.489s
glxgears test
Puppy
"Safe" overclock: best reading was 19.170 fps
No overclock: 19.077 fps
Over-voltage: 26.994 fps
Over-voltage with swapon - 29.103
Arch result (This was in the "safe" overclock settings, with swapon):
31.844 fps
TEST : Iterations/sec. : Old Index : New Index
: : Pentium 90* : AMD K6/233*
NUMERIC SORT : 200.4 : 5.14 : 1.69
STRING SORT : 31.472 : 14.06 : 2.18
BITFIELD : 8.8785e+07 : 15.23 : 3.18
FP EMULATION : 45.509 : 21.84 : 5.04
FOURIER : 2056.4 : 2.34 : 1.31
ASSIGNMENT : 2.3939 : 9.11 : 2.36
IDEA : 669.29 : 10.24 : 3.04
HUFFMAN : 414.53 : 11.49 : 3.67
NEURAL NET : 3.1213 : 5.01 : 2.11
LU DECOMPOSITION : 72.68 : 3.77 : 2.72
==========================ORIGINAL BYTEMARK RESULTS==========================
INTEGER INDEX : 11.448
FLOATING-POINT INDEX: 3.534
Baseline (MSDOS*) : Pentium* 90, 256 KB L2-cache, Watcom* compiler 10.0
==============================LINUX DATA BELOW===============================
CPU :
L2 Cache :
OS : Linux 3.1.9+
C compiler : gcc-4.7.real
libc : libc-2.13.so
MEMORY INDEX : 2.539
INTEGER INDEX : 3.121
FLOATING-POINT INDEX: 1.960
Baseline (LINUX) : AMD K6/233*, 512 KB L2-cache, gcc 2.7.2.3, libc-5.4.38
BYTEmark* Native Mode Benchmark ver. 2 (10/95)
Index-split by Andrew D. Balsa (11/97)
Linux/Unix* port by Uwe F. Mayer (12/96,11/97)
NUMERIC SORT : 122.36 : 3.14 : 1.03
STRING SORT : 13.466 : 6.02 : 0.93
BITFIELD : 4.4703e+07 : 7.67 : 1.60
FP EMULATION : 21.81 : 10.47 : 2.41
FOURIER : 422.14 : 0.48 : 0.27
ASSIGNMENT : 2.5424 : 9.67 : 2.51
IDEA :
** WARNING: The current test result is NOT 95 % statistically certain.
** WARNING: The variation among the individual results is too large.
: 192.04 : 2.94 : 0.87
HUFFMAN :
: 230.33 : 6.39 : 2.04
NEURAL NET :
: 0.45295 : 0.73 : 0.31
LU DECOMPOSITION :
: 15.395 : 0.80 : 0.58
INTEGER INDEX : 5.985
FLOATING-POINT INDEX: 0.653
CPU :
L2 Cache :
OS : Linux 3.1.9+
C compiler : gcc version 4.6.3 (Debian 4.6.3-8+rpi1)
libc : libc-2.13.so
MEMORY INDEX : 1.553
INTEGER INDEX : 1.451
FLOATING-POINT INDEX: 0.362
* Trademarks are property of their respective holder.
Okay, I just ran with the gcc that came with my downloaded raspbian (4.6.3).eben wrote:Can you share the compiler flags you used to get these results, and maybe the resulting binaries? Some initial thoughts:
- gcc 4.7 seems to make a significant difference versus 4.6
- We do well versus Cortex A8 on floating point, less well on memory and integer
The aim is to bring some data to bear on some of the claims being made by vendors of other low-cost computing devices (particularly the various ~$70 Android stick computers). There's a lazy assumption that a Cortex-class processor will automatically wipe the floor with an ARM11, which isn't really borne out either by benchmarks or real-world performance measurements.gritz wrote:Surely posting benchmarks on steroids might be counterproductive, especially regarding the "I never bother to RTFM" crowd. By all means benchmark it in a series of real-world situations, but I feel that wringing the snot out of it (and possibly invalidating the warranty) is totally missing the point.
But it's fun ...gritz wrote: ... I feel that wringing the snot out of it (and possibly invalidating the warranty) is totally missing the point.
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
CFLAGS = -s -static -Wall -Ofast -funroll-loops -fomit-frame-pointer -march=armv6 -mfpu=vfp -mfloat-abi=hard
NUMERIC SORT : 312.96 : 5.14 : 1.69
STRING SORT : 44.147 : 14.06 : 2.18
BITFIELD : 9.8046e+07 : 15.23 : 3.18
FP EMULATION : 61.606 : 21.84 : 5.04
FOURIER : 3250.4 : 2.34 : 1.31
ASSIGNMENT : 4.1339 : 9.11 : 2.36
IDEA : 924.83 : 10.24 : 3.04
HUFFMAN : 569.97 : 11.49 : 3.67
NEURAL NET : 4.5010 : 5.01 : 2.11
LU DECOMPOSITION : 123.28 : 3.77 : 2.72
INTEGER INDEX : 16.073
FLOATING-POINT INDEX: 9.552
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 3.524
INTEGER INDEX : 4.420
FLOATING-POINT INDEX: 3.079
CFLAGS = -s -static -Wall -O3 -fomit-frame-pointer -funroll-loops -Wno-write-strings -Wno-sign-compare -mfloat-abi=hard -mfpu=vfp -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -march=armv6zk
arm_freq=950
sdram_freq=500
core_freq=500
pi@welham ~/nbench-byte-2.2.3 $ ./nbench
NUMERIC SORT : 219.84 : 5.64 : 1.85
STRING SORT : 32.083 : 14.34 : 2.22
BITFIELD : 7.3163e+07 : 12.55 : 2.62
FP EMULATION : 44.582 : 21.39 : 4.94
FOURIER : 2299.2 : 2.61 : 1.47
ASSIGNMENT : 2.6495 : 10.08 : 2.61
IDEA : 686.54 : 10.50 : 3.12
HUFFMAN : 417.5 : 11.58 : 3.70
NEURAL NET : 3.202 : 5.14 : 2.16
LU DECOMPOSITION : 80.64 : 4.18 : 3.02
INTEGER INDEX : 11.500
FLOATING-POINT INDEX: 3.830
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.478
INTEGER INDEX : 3.204
FLOATING-POINT INDEX: 2.124
NUMERIC SORT : 221.2 : 5.67 : 1.86
STRING SORT : 32.002 : 14.30 : 2.21
BITFIELD : 7.2979e+07 : 12.52 : 2.61
FP EMULATION : 44.427 : 21.32 : 4.92
FOURIER : 2292.8 : 2.61 : 1.46
ASSIGNMENT : 2.6616 : 10.13 : 2.63
IDEA : 686.55 : 10.50 : 3.12
HUFFMAN : 417.33 : 11.57 : 3.70
NEURAL NET : 3.2018 : 5.14 : 2.16
LU DECOMPOSITION : 81.04 : 4.20 : 3.03
INTEGER INDEX : 11.503
FLOATING-POINT INDEX: 3.833
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.477
INTEGER INDEX : 3.206
FLOATING-POINT INDEX: 2.126
NUMERIC SORT : 221.8 : 5.69 : 1.87
STRING SORT : 32.03 : 14.31 : 2.22
BITFIELD : 7.3253e+07 : 12.57 : 2.62
FP EMULATION : 44.476 : 21.34 : 4.92
FOURIER : 2301 : 2.62 : 1.47
ASSIGNMENT : 2.6596 : 10.12 : 2.62
HUFFMAN : 417.66 : 11.58 : 3.70
NEURAL NET : 3.2015 : 5.14 : 2.16
LU DECOMPOSITION : 80.296 : 4.16 : 3.00
INTEGER INDEX : 11.516
FLOATING-POINT INDEX: 3.825
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.480
INTEGER INDEX : 3.209
FLOATING-POINT INDEX: 2.122
Impressive.portets wrote:My test results(without booting into X):compiled with gcc-4.7 and:Code: Select all
MEMORY INDEX : 3.524 INTEGER INDEX : 4.420 FLOATING-POINT INDEX: 3.079
clocks were:Code: Select all
with no overvolt.Code: Select all
arm_freq=950 sdram_freq=500 core_freq=500
fbset -g 704 400 704 400 16
echo on |sudo tee /proc/dwc_sof/SOF_reduction
make CC="gcc-4.7" CFLAGS="-s -static -O3 -funroll-loops" clean nbench
./nbench
NUMERIC SORT : 226.2 : 5.80 : 1.91
STRING SORT : 33.28 : 14.87 : 2.30
BITFIELD : 9.3479e+07 : 16.03 : 3.35
FP EMULATION : 48.222 : 23.14 : 5.34
FOURIER : 2373.8 : 2.70 : 1.52
ASSIGNMENT : 2.9115 : 11.08 : 2.87
IDEA : 701.95 : 10.74 : 3.19
HUFFMAN : 437.9 : 12.14 : 3.88
NEURAL NET : 3.7924 : 6.09 : 2.56
LU DECOMPOSITION : 82.12 : 4.25 : 3.07
INTEGER INDEX : 12.445
FLOATING-POINT INDEX: 4.121
CPU :
L2 Cache :
OS : Linux 3.1.9+
libc : libc-2.13.so
MEMORY INDEX : 2.809
INTEGER INDEX : 3.349
FLOATING-POINT INDEX: 2.285
NUMERIC SORT : 114.87 : 2.95 : 0.97
STRING SORT : 9.5392 : 4.26 : 0.66
BITFIELD : 5.0838e+07 : 8.72 : 1.82
FP EMULATION : 17.152 : 8.23 : 1.90
FOURIER : 3209.7 : 3.65 : 2.05
ASSIGNMENT : 2.9528 : 11.24 : 2.91
IDEA : 508.01 : 7.77 : 2.31
HUFFMAN : 239.62 : 6.64 : 2.12
NEURAL NET : 3.7654 : 6.05 : 2.54
LU DECOMPOSITION : 111.84 : 5.79 : 4.18
INTEGER INDEX : 6.560
FLOATING-POINT INDEX: 5.039
CPU : GenuineIntel Pentium II (Klamath) 300MHz
L2 Cache : 512 KB
OS : Linux 3.1.0-7.fc16.i686
C compiler : gcc version 4.6.3 20120306 (Red Hat 4.6.3-2) (GCC)
libc : libc-2.14.90.so
MEMORY INDEX : 1.519
INTEGER INDEX : 1.732
FLOATING-POINT INDEX: 2.795
Sacrilege! I'd assumed you'd have one surgically implanted by now...eben wrote:In case you hadn't guessed, I'm travelling without a Raspberry Pi
CFLAGS = -s -static -Wall -O3 -fomit-frame-pointer -funroll-loops -mcpu=arm1176jzf-s -mtune=arm1176jzf-s -mfpu=vfp -mfloat-abi=hard
NUMERIC SORT : 354.16 : 9.08 : 2.98
STRING SORT : 47.983 : 21.44 : 3.32
BITFIELD : 1.0657e+08 : 18.28 : 3.82
FP EMULATION : 67.199 : 32.25 : 7.44
FOURIER : 3649.9 : 4.15 : 2.33
ASSIGNMENT : 4.6711 : 17.77 : 4.61
IDEA : 1003.1 : 15.34 : 4.56
HUFFMAN : 621.12 : 17.22 : 5.50
NEURAL NET : 5.104 : 8.20 : 3.45
LU DECOMPOSITION : 138.28 : 7.16 : 5.17
INTEGER INDEX : 17.676
FLOATING-POINT INDEX: 6.247
CPU :
L2 Cache :
OS : Linux 3.1.9-cutdown+
libc : libc-2.13.so
MEMORY INDEX : 3.880
INTEGER INDEX : 4.856
FLOATING-POINT INDEX: 3.465
