_LLJY
Overclocking
Fri Oct 30, 2015 2:45 pm
I have managed to get my raspberry pi 2 stable on these overclock settings
gpu_freq=1100
arm_freq=1220
sdram_freq=500
core_freq=600
force_turbo=1
over_voltage=8
Is there anything I can edit to get more performance? Or is this good enough.
dom
Re: Overclocking
Fri Oct 30, 2015 2:51 pm
You should always run
vcgencmd measure_clock <clock>
where clock is arm, core, v3d, h264, isp.
Most clocks have an upper limit. the "gpu" freq's won't go above 600, so your gpu_freq=1100 is bogus.
But otherwise these settings are about as high as I have ever achieved. You are not going to get much higher.
davenull
Re: Overclocking
Fri Oct 30, 2015 3:40 pm
I would be curious about how quick this overclocked Raspi would perform in a speed / benchmark test, even compared to a not-overclocked one.
these are my results for a B+ at 800 MHz
compiled via Geany IDE,
Geany settings for compile:
g++ -Wall -I/opt/vc/include -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/vcos/pthreads -c "%f" -lshapes -lshapes_plus -L/opt/vc/lib -lOpenVG -lEGL -lpthread -lrt -lwiringPi
Geany settings for build:
g++ -Wall -I/opt/vc/include -I/opt/vc/include/interface/vmcs_host/linux -I/opt/vc/include/interface/vcos/pthreads -o "%e" "%f" -lshapes -lshapes_plus -L/opt/vc/lib -lOpenVG -lEGL -lpthread -lrt -lwiringPi
Graphic libs:
https://github.com/ajstarks/openvg
plus
https://www.dropbox.com/s/h37po1q305eab ... ar.gz?dl=0
(this test once was designed for slow cpus, for the Raspi 2 perhaps all the tests should be performed twice as much and then divide results by 2, using floats or microseconds instead of milliseconds long ints)
Brickbench Test for Raspberry Pi B+ (gpp C++)
// HaWe Brickbench
// benchmark test for NXT/EV3 and similar Micro Controllers
// PL: GCC, Raspi, Raspbian  Linux
// Autor: (C) Helmut Wunder 2013,2014
// ported to Raspi  by "HaWe"
// freie Verwendung für private Zwecke
// für kommerzielle Zwecke nur nach schriftlicher Genehmigung durch den Autor.
// protected under the friendly Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License
// http://creativecommons.org/licenses/by-nc-sa/3.0/
// version 1.09.006  25.10.2015
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <sys/ioctl.h>
#include <stdint.h>
#include <time.h>
#include <sys/time.h>
#include "VG/openvg.h"
#include "VG/vgu.h"
#include "fontinfo.h"
#include "shapes.h"
#include "shapes_plus.h"
unsigned long runtime[8];
int a[500], b[500], c[500], t[500];
uint32_t timer()
   struct timeval now;
   uint32_t ticks;
   gettimeofday(&now, NULL);
   ticks=now.tv_sec*1000+now.tv_usec/1000;
   return(ticks);
// Mersenne Twister
unsigned long randM(void) {
   const int M = 7;
   const unsigned long A[2] = { 0, 0x8ebfd028 };
   static unsigned long y[25];
   static int index = 25+1;
   if (index >= 25) {
     int k;
     if (index > 25) {
        unsigned long r = 9, s = 3402;
        for (k=0 ; k<25 ; ++k) {
          r = 509845221 * r + 3;
          s *= s + 1;
          y[k] = s + (r >> 10);
     for (k=0 ; k<25-M ; ++k)
        y[k] = y[k+M] ^ (y[k] >> 1) ^ A[y[k] & 1];
     for (; k<25 ; ++k)
        y[k] = y[k+(M-25)] ^ (y[k] >> 1) ^ A[y[k] & 1];
     index = 0;
   unsigned long e = y[index++];
   e ^= (e << 7) & 0x2b5b2500;
   e ^= (e << 15) & 0xdb8b0000;
   e ^= (e >> 16);
   return e;
// Matrix Algebra
// matrix * matrix multiplication (matrix product)
 void MatrixMatrixMult(int N, int M, int K, double *A, double *B, double *C) {
   int i, j, s;
   for (i = 0; i < N; ++i) {
      for (j = 0; j < K; ++j) {
         C[i*K+j] = 0;
         for (s = 0; s < M; ++s) {
            C[i*K+j] = C[i*K+j] + A[i*N+s] * B[s*M+j];
// matrix determinant
double MatrixDet(int N, double A[]) {
   int i, j, i_count, j_count, count = 0;
   double Asub[N - 1][N - 1], det = 0;
   if (N == 1)
      return *A;
   if (N == 2)
      return ((*A) * (*(A+1+1*N)) - (*(A+1*N)) * (*(A+1)));
   for (count = 0; count < N; count++) {
      i_count = 0;
      for (i = 1; i < N; i++) {
         j_count = 0;
         for (j = 0; j < N; j++) {
            if (j == count)
               continue;
            Asub[i_count][j_count] = *(A+i+j*N);
            j_count++;
         i_count++;
      det += pow(-1, count) * A[0+count*N] * MatrixDet(N - 1, &Asub[0][0]);
   return det;
// shell sort
void shellsort(int size, int* A)
  int i, j, increment;
  int temp;
  increment = size / 2;
  while (increment > 0) {
    for (i = increment; i < size; i++) {
      j = i;
      temp = A[i];
      while ((j >= increment) && (A[j-increment] > temp)) {
        A[j] = A[j - increment];
        j = j - increment;
      A[j] = temp;
    if (increment == 2)
       increment = 1;
    else
       increment = (unsigned int) (increment / 2.2);
// gnu quick sort
// (0ptional)
int compare_int (const int *a, const int *b)
  int  temp = *a - *b;
  if (temp > 0)          return  1;
  else if (temp < 0)     return -1;
  else                   return  0;
// gnu qsort:
// void qsort (void *a , size_a count, size_a size, compare_function)
// gnu qsort call for a[500] array of int:
// qsort (a , 500, sizeof(a), compare_int)
// benchmark test procedures
int test_Int_Add() {
   int i=1, j=11, k=112, l=1111, m=11111, n=-1, o=-11, p=-111, q=-1112, r=-11111;
   int x;
   volatile long s=0;
   for(x=0;x<10000;++x) {
     s+=i; s+=j; s+=k; s+=l; s+=m; s+=n; s+=o; s+=p; s+=q; s+=r;
   return s;
long test_Int_Mult() {
  int x,y;
  volatile long s;
  for(y=0;y<2000;++y) {
    s=1;
    for(x=1;x<=13;++x) { s*=x;}
    for(x=13;x>0;--x) { s/=x;}
  return s;
#define PI  M_PI
double test_float_math() {
  volatile double s=PI;
  int y;
  for(y=0;y<1000;++y) {
     s*=sqrt(s);
     s=sin(s);
     s=exp(s);
     s*=s;
  return s;
long test_rand_MT(){
  volatile unsigned long s;
  int y;
  for(y=0;y<5000;++y) {
     s=randM()%10001;
  return s;
double test_matrix_math() {
  int x;
  double A[2][2], B[2][2], C[2][2];
  double S[3][3], T[3][3];
  unsigned long s;
  for(x=0;x<250;++x) {
    A[0][0]=1;   A[0][1]=3;
    A[1][0]=2;   A[1][1]=4;
    B[0][0]=10;  B[0][1]=30;
    B[1][0]=20;  B[1][1]=40;
    MatrixMatrixMult(2, 2, 2, A[0], B[0], C[0]); // <<<<<<<<<<<<<<<<<<<
    MatrixDet(2, A[0]);                          // <<<<<<<<<<<<<<<<<<<
    S[0][0]=1;   S[0][1]=4;  S[0][2]=7;
    S[1][0]=2;   S[1][1]=5;  S[1][2]=8;
    S[2][0]=3;   S[2][1]=6;  S[2][2]=9;
    MatrixDet(3, S[0]);                          // <<<<<<<<<<<<<<<<<<<
  s=(S[0][0]*S[1][1]*S[2][2]);
  return s;
// for array copy using void *memcpy(void *dest, const void *src, size_t n);
long test_Sort(){
  unsigned long s;
  int y;
  int t[500];
  for(y=0;y<30;++y) {
    memcpy(t, a, sizeof(a));
    shellsort(500, t);
    memcpy(t, a, sizeof(b));
    shellsort(500, t);
    memcpy(t, a, sizeof(c));
    shellsort(500, t);
  return y;
long test_TextOut(){
  int  y=77;
  char buf[120];
  for(y=0;y<20;++y) {
    Background(0, 0, 0);                    // Black background
    //Text(x, y, buf, SerifTypeface, 20);
    Fill(255, 255, 255, 1);                 // White text
    sprintf (buf, "%3d %4d  int_Add",    0, 1000); Text( 20, 200- 20, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  int_Mult",   1, 1010); Text( 20, 200- 40, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  float_op",   2, 1020); Text( 20, 200- 60, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  randomize",  3, 1030); Text( 20, 200- 80, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  matrx_algb", 4, 1040); Text( 20, 200-100, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  arr_sort",   5, 1050); Text( 20, 200-120, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  displ_txt",  6, 1060); Text( 20, 200-140, buf, SerifTypeface, 20); End();
    sprintf (buf, "%3d %4d  testing...", 7, 1070); Text( 20, 200-160, buf, SerifTypeface, 20); End();
  return y;
long test_graphics(){
    int y=0;
    for(y=0;y<100;++y) {
        ClearWindow();      // Colour and size are remembered from the
                            // ClearWindowRGBA() call at the start of the program
        Stroke(255, 255, 255, 1);  // Set these at the start, no need to
        Fill(255,255,255, 1);      // keep calling them if colour hasn't changed
        End();
        CircleOutline(50, 40, 10);       // circles
        End();
        Circle(30, 24, 10);
        End();
        Line(10, 10, 60, 60);            // just 2 intersecting lines
        End();
        Line(50, 20, 90, 70);
        End();
        RectOutline(20, 20, 40, 40);     // rectangles
        End();
        Rect(65, 25, 20, 30);
        End();
        EllipseOutline(70, 30, 15, 20);  // ellipse
        End();
    return y;
inline void displayValues() {
  char buf[120];
    sprintf (buf, "%3d %7ld  int_Add",    0, runtime[0]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  int_Mult",   1, runtime[1]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  float_op",   2, runtime[2]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  randomize",  3, runtime[3]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  matrx_algb", 4, runtime[4]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  arr_sort",   5, runtime[5]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  displ_txt",  6, runtime[6]); printf(buf); printf("\n");
    sprintf (buf, "%3d %7ld  graphics",   7, runtime[7]); printf(buf); printf("\n");
int main(){
  unsigned long time0, x, y;
  float s;
  char  buf[120];
  int width, height;
  char str[3];
  init(&width, &height);                  // Graphics initialization
  Start(width, height);                   // Start the picture
  ClearWindowRGB(width, height, 0, 0, 0);
  HideWindow();       // Hide  the picture
  printf("hw brickbench"); printf("\n");
  printf("initializing..."); printf("\n");
  for(y=0;y<500;++y) {
    a[y]=randM()%30000; b[y]=randM()%30000; c[y]=randM()%30000;
  time0= timer();
  s=test_Int_Add();
  runtime[0]=timer()-time0;
  time0=timer();
  s=test_Int_Mult();
  runtime[1]=timer()-time0;
  sprintf (buf, "%3d %7ld  int_Mult",   0, runtime[1]);  printf(buf); printf("\n");
  time0=timer();
  s=test_float_math();
  runtime[2]=timer()-time0;
  sprintf (buf, "%3d %7ld  float_op",   0, runtime[2]);  printf(buf); printf("\n");
  time0=timer();
  s=test_rand_MT();
  runtime[3]=timer()-time0;
  sprintf (buf, "%3d %7ld  randomize",  0, runtime[3]);  printf(buf); printf("\n");
  time0=timer();
  s=test_matrix_math();
  runtime[4]=timer()-time0;
  sprintf (buf, "%3d %7ld  matrx_algb", 0, runtime[4]);  printf(buf); printf("\n");
  time0=timer();
  s=test_Sort();
  runtime[5]=timer()-time0;
  sprintf (buf, "%3d %7ld  arr_sort",   0, runtime[5]);  printf(buf); printf("\n");
  time0=timer();
  s=test_TextOut();
  runtime[6]=timer()-time0;
  time0=timer();
  time0=timer();
  s=test_graphics();
  runtime[7]=timer()-time0;
  y=0;
  for(x=0;x<8;++x) {y+= runtime[x];}
  printf("\n");
  printf("\n");
  displayValues();
  sprintf (buf, "gesamt ms: %ld ", y);           printf(buf); printf("\n");
  sprintf (buf, "benchmark: %ld ", 50000000/y ); printf(buf); printf("\n");
  fgets(str, 2, stdin);                   // look at the pic, end with [RETURN]
  finish();                               // Graphics cleanup
  exit(0);
Raspberry Pi B+ (800 MHz)
results :
 bench test ms
int_add     1
int_mult    3
float_op   13
mersenne    2
matrix      1
arr_sort   88
text     2630
graph   13333
gesamt ms:   16072
Benchmark:    3980
Benchmark-chart: http://www.mindstormsforum.de/viewtopic ... 095#p64772
#define S sqrt(t+2*i*i)<2
#define F(a,b) for(a=0;a<b;++a)
float x,y,r,i,s,j,t,n;int main(){F(y,64){F(x,99){r=i=t=0;s=x/33-2;j=y/32-1;F(n,50&S){t=r*r-i*i;i=2*r*i+j;r=t+s;}if(S){PointOut(x,y);}}}for(;;);}
_LLJY
Re: Overclocking
Fri Oct 30, 2015 3:44 pm
davenull wrote:I would be curious about how quick this overclocked Raspi would perform in a speed / benchmark test.
Graphic libs:
plus
// HaWe Brickbench
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <math.h>
#include <fcntl.h>
#include <string.h>
#include <stdint.h>
#include <time.h>
#include "VG/vgu.h"
#include "shapes.h"
uint32_t timer()
   struct timeval now;
   uint32_t ticks;
   return(ticks);
// Mersenne Twister
   const int M = 7;
   if (index >= 25) {
     int k;
     if (index > 25) {
          s *= s + 1;
     for (; k<25 ; ++k)
     index = 0;
   e ^= (e >> 16);
   return e;
// Matrix Algebra
   int i, j, s;
         C[i*K+j] = 0;
   if (N == 1)
      return *A;
   if (N == 2)
      i_count = 0;
         j_count = 0;
            if (j == count)
               continue;
            j_count++;
         i_count++;
   return det;
// shell sort
  int temp;
      j = i;
      temp = A[i];
        j = j - increment;
      A[j] = temp;
    if (increment == 2)
       increment = 1;
    else
// gnu quick sort
// (0ptional)
  int  temp = *a - *b;
  else                   return  0;
// gnu qsort:
   int x;
   volatile long s=0;
   return s;
  int x,y;
  volatile long s;
    s=1;
  return s;
#define PI  M_PI
  int y;
     s*=sqrt(s);
     s=sin(s);
     s=exp(s);
     s*=s;
  return s;
  int y;
     s=randM()%10001;
  return s;
  int x;
  unsigned long s;
  return s;
long test_Sort(){
  unsigned long s;
  int y;
  int t[500];
  for(y=0;y<30;++y) {
    shellsort(500, t);
    shellsort(500, t);
    shellsort(500, t);
  return y;
  int  y=77;
  char buf[120];
  for(y=0;y<20;++y) {
  return y;
    int y=0;
        End();
        End();
        Circle(30, 24, 10);
        End();
        End();
        End();
        End();
        End();
        End();
    return y;
  char buf[120];
int main(){
  float s;
  char  buf[120];
  int width, height;
  char str[3];
  time0= timer();
  s=test_Int_Add();
  time0=timer();
  s=test_Int_Mult();
  time0=timer();
  time0=timer();
  s=test_rand_MT();
  time0=timer();
  time0=timer();
  s=test_Sort();
  time0=timer();
  s=test_TextOut();
  time0=timer();
  time0=timer();
  s=test_graphics();
  y=0;
  printf("\n");
  printf("\n");
  displayValues();
  exit(0);
results :
 bench test ms
int_add     1
int_mult    3
float_op   13
mersenne    2
matrix      1
arr_sort   88
text     2630
graph   13333
gesamt ms:   16072
Benchmark:    3980
Ok sure I will test it and report back the results when I have the time
davenull
Re: Overclocking
Fri Oct 30, 2015 3:51 pm
(+1)
(y)
