Raspberry wino
Search function failure?
Mon Jul 23, 2012 11:15 pm
A day or two ago I had a query about raspi-config so I typed it into the search box to find relevant threads but it said no matches and so I started a thread to ask my question.
Today I found a thread with raspi-config in the title and body. I tried a search and it still doesn't find either thread. Is the hyphen a problem or something else?
rembrandt
Re: Search function failure?
Tue Jul 24, 2012 6:42 am
In the advanced search, it states:
Place + in front of a word which must be found and - in front of a word which must not be found
I did a search on config* and then on *raspi within those results and it returned 21 matches.
Hope that helps :)
AndrewS
Tue Jul 24, 2012 10:01 am
Or you could use google site search, as suggested in this thread http://www.raspberrypi.org/phpBB3/viewt ... =25&t=7727
(which is actually what the Search box on the blog front page does)
Raspberry wino
Tue Jul 24, 2012 10:25 am
Thanks both.
I (a human) see 'raspi-config' as a single character string containing a hyphen because there are no spaces.
The search function sees two strings because there is an embedded hyphen, which seems perverse.
At least the mystery is solved.
AndrewS
Tue Jul 24, 2012 10:31 am
Raspberry wino wrote:I (a human) see 'raspi-config' as a single character string containing a hyphen because there are no spaces.
As a (pedantic) programmer I see it as a 12-character string ;) (13 if null-terminated) :geek:
phoenix
Thu Aug 09, 2012 4:18 pm
I have had the same problem.
It is really annoying - surely something can be done about it quickly?
It is a simple enough programming task to recognize a word with a hyphen (no blanks).
