Adelie.HTF
Re: Guide: Chromium 45 on Raspbian Jessie
Fri Nov 20, 2015 3:52 pm
FANTASTIC ! it worked ! You are a hero. :P
dick.heijkoop
Sat Nov 21, 2015 3:38 pm
Works great!. Thanks for sharing this. Cheers, Dick
McC42
Tue Dec 01, 2015 11:53 am
Everything seemed to install fine for - "Just that it doesn't work" :-
"Chromium Web Browser" appears under "Internet" on the pull down - and then the cursor changes to a rotating circle for about 15 seconds before returning to it's normal arrow shape.
As you can see everything loaded seemlessly - I was using the Latest version - "2015-11-21-raspbian-jesse.img" and installing it on a Raspberry Pi Model B+
pi@raspberrypi:~ $ wget
https://dl.dropboxusercontent.com/u/87113035/chromium-browser-l10n_45.0.2454.85-0ubuntu0.15.04.1.1181_all.deb
--2015-12-01 11:25:07--
Resolving dl.dropboxusercontent.com (dl.dropboxusercontent.com)...
45.58.74.37, 45.58.74.5
Connecting to dl.dropboxusercontent.com
(dl.dropboxusercontent.com)|45.58.74.37|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 3511196 (3.3M) [application/x-debian-package]
Saving to: ‘chromium-browser-l10n_45.0.2454.85-0ubuntu0.15.04.1.1181_all.deb’
chromium-browser-l1 100%[=====================>]   3.35M   332KB/s   in 12s
2015-12-01 11:25:22 (277 KB/s) -
saved [3511196/3511196]
https://dl.dropboxusercontent.com/u/87113035/chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb
--2015-12-01 11:25:33--
108.160.173.5, 108.160.173.69
(dl.dropboxusercontent.com)|108.160.173.5|:443... connected.
Length: 47088682 (45M) [application/x-debian-package]
Saving to: ‘chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb’
chromium-browser_45 100%[=====================>]  44.91M   572KB/s   in 1m 53s s
2015-12-01 11:27:28 (406 KB/s) -
‘chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb’ saved
[47088682/47088682]
https://dl.dropboxusercontent.com/u/87113035/chromium-codecs-ffmpeg-extra_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb
--2015-12-01 11:28:07--
Length: 766750 (749K) [application/x-debian-package]
Saving to: ‘chromium-codecs-ffmpeg-extra_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb’
chromium-codecs-ffm 100%[=====================>] 748.78K   280KB/s   in 2.7s
2015-12-01 11:28:12 (280 KB/s) -
saved [766750/766750]
pi@raspberrypi:~ $ sudo dpkg -i
Selecting previously unselected package chromium-codecs-ffmpeg-extra.
(Reading database ... 123536 files and directories currently installed.)
Preparing to unpack
Unpacking chromium-codecs-ffmpeg-extra (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Setting up chromium-codecs-ffmpeg-extra (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Selecting previously unselected package chromium-browser-l10n.
(Reading database ... 123543 files and directories currently installed.)
Preparing to unpack
chromium-browser-l10n_45.0.2454.85-0ubuntu0.15.04.1.1181_all.deb ...
Unpacking chromium-browser-l10n (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Selecting previously unselected package chromium-browser.
Preparing to unpack
chromium-browser_45.0.2454.85-0ubuntu0.15.04.1.1181_armhf.deb ...
Unpacking chromium-browser (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Setting up chromium-browser (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for hicolor-icon-theme (0.13-1) ...
Setting up chromium-browser-l10n (45.0.2454.85-0ubuntu0.15.04.1.1181) ...
Processing triggers for gnome-menus (3.13.3-6) ...
Processing triggers for mime-support (3.58) ...
Processing triggers for man-db (2.7.0.2-5) ...
The little screenshot ( enclosed ) shows that the directories are listed using "ls"
Any help would be most grateful - Thanks
Greg McCormack
o-----------------------------------------------o
Liverpool, UK
Tue Dec 01, 2015 12:02 pm
McC42 wrote:Everything seemed to install fine for - "Just that it doesn't work" :-
[47088682/47088682]
Preparing to unpack
Preparing to unpack
Preparing to unpack
Greg McCormack
Liverpool, UK
Of course it will not function the version of Chromium, as stated on first page, is for RPi 2B which has the ARMv7 CPU
THIS IS THE ONLY WAY TO GET CHROMIUM ON JESSIE!
THIS WILL ONLY WORK ON A Pi2!
You have a RPi 1B+ which has the ARMv6 CPU
Retired disgracefully.....
McC42
Tue Dec 01, 2015 1:17 pm
Thanks FruitOfTheLoom ,
Tried a RaspberryPi 2 B and IT WORKED
Greg
etype
Thu Dec 03, 2015 8:01 pm
how can i run chrominm from my php filei am trying this but its not working
<?php
echo exec('sudo chromium --kiosk --enable-kiosk-mode --enabled --touch-events --touch-events-ui --disable-ipv6 --allow-file-access-from-files --disable-restore-session-state --disable-sync --disable-translate --disk-cache-size=1 --media-cache-size=1 --display :0.0 scrolltext.php');
why is it not running chromium is installed i can run it of the desktop but when i try to run from terminal it says not found
etype
Thu Dec 03, 2015 8:02 pm
<?php
0xFF
Thu Dec 03, 2015 8:07 pm
I think you should use 'chromium-browser' as executable name.
etype
Thu Dec 03, 2015 8:29 pm
thank is tried it and now i get this error
[1:1:1203/202708:FATAL:setuid_sandbox_client.cc(126)] Check failed: IsFileSystemAccessDenied().
with sudo
and with no sudo
just goes back to prompt
etype
Thu Dec 03, 2015 8:43 pm
can someone please give me the best and latest way to install chromium on raspberry pi 2
pi is running latest
RASPBIAN JESSIE
Full desktop image based on Debian Jessie
Version:November 2015
Release date:2015-11-21
kernel 4.1
leandro.freitas
Sat Dec 05, 2015 6:54 am
wget http://ports.ubuntu.com/pool/universe/c ... 83_all.deb
wget http://ports.ubuntu.com/pool/universe/c ... _armhf.deb
sudo dpkg -i chromium-codecs-ffmpeg-extra_45.0.2454.101-0ubuntu0.15.04.1.1183_armhf.deb
sudo dpkg -i chromium-browser-l10n_45.0.2454.101-0ubuntu0.15.04.1.1183_all.deb
sudo dpkg -i chromium-browser_45.0.2454.101-0ubuntu0.15.04.1.1183_armhf.deb
#run
chromium-browser
Work fine for me.
Thanks.
mattmiller
Sat Dec 05, 2015 4:09 pm
Tried above on a PiZero
gave
illegal instruction
when I ran chromium-browser
expandables
Sat Dec 05, 2015 4:16 pm
mattmiller wrote:Tried above on a PiZero
gave
illegal instruction
That's because the PI-Zero aka the Hero has an Armv6 processor and the PI ultimate 2 has an Armv7 processor so the architecture is different, so that's why you are getting "illegal instruction"
:twisted:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
mattmiller
Sat Dec 05, 2015 8:20 pm
Thanks for info
dheld
Sun Dec 13, 2015 10:06 pm
Thanks for this great post! I see that Chromium is now at version 47. Are there any updated instructions for upgrading?
David
edgework
Sun Dec 13, 2015 10:47 pm
On my Pi2, Rasbian Jessie, Chromium does very poorly when playing HTML5 video. Epiphany plays HTML5 video very well. I'm guessing Chromium isn't using the Pi's video chip?
Kratos
Sun Dec 13, 2015 10:54 pm
Great guide!
If you are really, really desperate for the latest chromium, here's a different way to do it. (Sorry if I'm nitpicking)
1. Paste this into your /etc/apt/sources.list file with
sudo nano /etc/apt/sources.list
deb http://ports.ubuntu.com/ wily main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-security main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-security main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
#deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
#deb-src http://archive.raspbian.org/raspbian/ jessie main contrib non-free rpi
2. Reload package lists:
sudo apt-get update
3. Install chromium:
sudo apt-get install chromium-browser
4. Fix the package lists:
Paste this into it:
#deb http://ports.ubuntu.com/ wily main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ wily main restricted universe multiverse
#deb http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
#deb http://ports.ubuntu.com/ wily-security main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ wily-security main restricted universe multiverse
#deb http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
#deb-src http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
5. Reload the package lists:
sudo apt-get update
6. Done! Enjoy!
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
Mon Dec 14, 2015 12:21 am
In the past I have had a Debian system totally hosed by doing such installation from Ubuntu repos.
Ubuntu packages are not the same, their dependencies are not the same, it can lead to chaos and a system that is no longer up updatable.
Beware.
kusti8
Tue Dec 15, 2015 9:09 pm
Heater wrote:In the past I have had a Debian system totally hosed by doing such installation from Ubuntu repos.
Beware.
+1
The chromium package and its dependencies look fine, but adding the entire Ubuntu repo is way overkill and not necessary. I'll update the links in the guide for the new version sometime.
Tue Dec 15, 2015 10:20 pm
I've always had a suspicion that there is a way to install "foreign" packages into Debian without risking messing up the dependencies. Never took the time to figure out how.
If you can pull it off for Chromium, kusti8, they would be awesome. The technique may well be useful for many other applications.
kusti8
Tue Dec 15, 2015 10:53 pm
Heater wrote:I've always had a suspicion that there is a way to install "foreign" packages into Debian without risking messing up the dependencies. Never took the time to figure out how.
As far as I can tell, this does not mess up dependencies. All the dependencies usually needed are gotten from Debian, only the minimal Chromium packages are gotten from Ubuntu. They are the same name, and are not requesting impossible packages etc. I sort of got lucky with Chromium.
kusti8
Tue Dec 15, 2015 11:06 pm
dheld wrote:Thanks for this great post! I see that Chromium is now at version 47. Are there any updated instructions for upgrading?
David
Updated! :D
Sorry Kratos, but please don't follow those instructions. It may work fine, but its a little crude and more things could go wrong. The OP has now been updated for v47!
Kratos
Re: Guide: Chromium 47 on Raspbian Jessie
Wed Dec 16, 2015 12:40 am
OK, Thanks!
Kratos
cjan
Wed Dec 16, 2015 1:31 am
v47, youtube video blur, anyone has this issue?
expandables
Wed Dec 16, 2015 5:36 am
It doesn't make sense to upgrade until we get hardware acceleration, basically you will get the same performance from all "blink" versions of chromium.
:twisted:
