Page 28 of 39
Re: Guide: Chromium 50 on Raspbian Jessie
Posted: Fri Jun 17, 2016 11:31 am
by kusti8
lumsdot wrote:Just installed the latest version of jessie on my pi 3 and installed chromium 50. Works great as it always did.
i tried the chrome://flags trick and disabled the media source api,
and at last youtube browsing works at 360p inside the browser with no pauses or excessive dropped frames.
Plus i tried the online theramin page, not expecting it to work, but it works ok as well
http://femurdesign.com/theremin/
Will chromium browser, ever be installed by default into the rasbian images,
i know this is a touchy subject, but they shoukd think about it.
i mean the default browser they give, uses ' duck duck go' by default
It is a touchy subject and I have never asked. I think they want to improve Epiphany a little and I may push to include it when the entire image is ARMv7 and there is no support for the Pi1 and Pi0.
Posted: Fri Jun 17, 2016 11:50 am
by gkreidl
kusti8 wrote: It is a touchy subject and I have never asked. I think they want to improve Epiphany a little and I may push to include it when the entire image is ARMv7 and there is no support for the Pi1 and Pi0.
I'm not sure if anything may happen at all. No software for which the collabora people are responsible (including epiphany, webkit3 engine,parts of gstreamer1.0) has been fixed for many months. I reported a serious bug in gstreamer1.0 in October last year and nothing has happened so far. And many of the bugs and memory leaks in webkit3 and modules used by it are known for a long time now.
In fact, only one bug (in gst-omx) has been fixed but only after I had sent them the fix myself.
Posted: Fri Jun 17, 2016 12:08 pm
by kusti8
Yeah, I've heard that. I wonder what the Foundations stance is on this and if no work is going on then they should be looking for an alternative. But they've started that backwards compatibility is important so I'm not sure if they would even consider Chromium at this time.
Posted: Sat Jun 18, 2016 9:17 pm
by Ben_is_best
kusti8 wrote:
bullen wrote:Chromium works fine when you boot it but then if you leave it on without touching the pi for a couple of hours it becomes unusable, completely unresponsive (just scrolling takes like 1 minute). What can cause this?
It's a memory hog. But it should last a day.
Edit: What does top say?
Yeah, if you want a relatively fast and familiar browser, try Firefox: viewtopic.php?f=63&t=150438
Posted: Sat Jun 18, 2016 9:34 pm
by kusti8
That's a little out of place in a Chromium thread. Please keep it relevant.
Posted: Sun Jun 19, 2016 9:31 pm
by Gadgetguy
A suggestion to anyone bedeviled by the problem referred to by cjan on May 24
by cjan ยป Tue May 24, 2016 2:05 pm
kusti8 wrote:
cjan wrote:
test 50
1. disable "Use hardware acceleration where available" in chrome://settings --> p2 youtube 360p OK.
2. Rpi2 4.4.11-v7+ #888 drm-vc4-next, enable "Use hardware acceleration where available" in chrome://settings --> p2 youtube 360p OK.
Ok, good. I've just done some regular browsing and it's seems to work fine so I'm going to release it today.
btw, youtube can not forward play.
( For reference I have been using Chromium version 50 without problems since it was uploaded). Suddenly today, like cjan, I found myself unable to forward the Youtube slider. Rather than revert to version 49 the easy solution was to clear the Chromium cache. Like so many mysterious computer problems , they are inexplicably resolved by clearing cache or rebooting or in the analogous case of other frustrating inanimate objects that go awry by shaking or kicking.
Posted: Sun Jun 19, 2016 10:52 pm
by bullen
kusti8 wrote:
Ben_is_best wrote:
kusti8 wrote: It's a memory hog. But it should last a day.
Well, have you tried to run your build of chromium for more than 24 hours without problems?
I would say that it's more than relevant to be able to scroll after any amount of time. It's basically as useless as a hung process after some time.
I will leave it on and top it after this night but you can too, any page will do it!
Posted: Sun Jun 19, 2016 10:55 pm
by kusti8
1. My build is clean from Ubuntu. If you have any gripes , take it up with them.
2. Recommending a totally different browser in a Chromium thread is out if place.
I'll look into it though.
Posted: Mon Jun 20, 2016 9:25 am
by bullen
I think this one is my bad... the screen sleep thing energy saving blabla seems to be screwing with the whole rpi3... I turned it off and it seems fine so far 2 hours in... will edit this after another night... Edit: yup.
Posted: Mon Jun 20, 2016 8:00 pm
by Gadgetguy
With reference to cjan's post of May 24 regarding an inability to move the slider on youtube within the browser.. the other day I posted that I too had suddenly (it seems ) developed this problem with many but not all youtube videos and I had resolved it by clearing the chromium cache. While this is true it proved a surefire but temporary solution.After playing one video with the slider working navigating to a second video on the youtube side panel once again the slider would become inoperable although the preview thumbnail feature still functioned. If i reload the video the slider becomes functional again. Thinking it might be a corrupted chromium profile I opened a new profile. Again a temporary fix. I the removed chromium completely and deleted the whole chromium configuration folder and then reinstalled- again a temporary solution. As stated I am using version 50 . I will try going to one of my backup sd cards although I doubt this will prove any different.While for me it is only a minor annoyance because I usually play youtube videos either in omxplayergui or omxplayer or smplayer with mpv, it is nonetheless an annoyance.
Posted: Mon Jun 20, 2016 8:01 pm
by kusti8
Gadgetguy wrote:With reference to cjan's post of May 24 regarding an inability to move the slider on youtube within the browser.. the other day I posted that I too had suddenly (it seems ) developed this problem with many but not all youtube videos and I had resolved it by clearing the chromium cache. While this is true it proved a surefire but temporary solution.After playing one video with the slider working navigating to a second video on the youtube side panel once again the slider would become inoperable although the preview thumbnail feature still functioned. If i reload the video the slider becomes functional again. Thinking it might be a corrupted chromium profile I opened a new profile. Again a temporary fix. I the removed chromium completely and deleted the whole chromium configuration folder and then reinstalled- again a temporary solution. As stated I am using version 50 . I will try going to one of my backup sd cards although I doubt this will prove any different.While for me it is only a minor annoyance because I usually play youtube videos either in omxplayergui or omxplayer or mpv, it is nonetheless an annoyance.
I've never come across this. Interesting.
Posted: Sun Jul 03, 2016 8:21 pm
by demian_2
hello ! i have this error in raspberry pi 2 with jessie: 4.4.13-v7+ #894
[1:1:0703/201506:FATAL:setuid_sandbox_client.cc(126)] Check failed: IsFileSystemAccessDenied().
#0 0x000076d7b3c2 base::debug::StackTrace::StackTrace()
#1 0x000076d8ec5a logging::LogMessage::~LogMessage()
#2 0x0000733f90d4 sandbox::SetuidSandboxClient::ChrootMe()
#3 0x0000752e563a <unknown>
#4 0x000075075ab4 <unknown>
#5 0x000075076002 <unknown>
#6 0x0000750757c2 content::ContentMain()
#7 0x000054d3a85c <unknown>
#8 0x000071d1e294 __libc_start_main
Received signal 6
#1 0x000076d7b6f8 <unknown>
#2 0x000071d351a0 <unknown>
#3 0x000071d33f70 gsignal
[end of stack trace]
any help?
thanks!
Posted: Sun Jul 03, 2016 8:31 pm
by kusti8
It looks like your system is read only. You need to at least make the home directory a RAM disk.
Posted: Fri Jul 08, 2016 10:28 am
by dissu
./chrome --no-sandbox
or
./chrome --disable-setuid-sandbox
or
install and setup chromium sandbox
Posted: Fri Jul 08, 2016 11:12 am
by kusti8
dissu wrote:./chrome --no-sandbox
or
or
Posted: Fri Jul 08, 2016 12:46 pm
by kusti8
A new Chromium version has been released and I am in the process of building it now.
It should be done by tomorrow.
Posted: Sat Jul 09, 2016 2:54 pm
by kusti8
Chromium v51 BETA has been released. The stable will be released in the next few days. Anyone who wants to help test:
Add dev to the end of deb http://dl.bintray.com/kusti8/chromium-rpi jessie main in /etc/apt/sources.list
sudo apt-get update
sudo apt-get dist-upgrade
Posted: Sat Jul 09, 2016 7:55 pm
by Dis93
kusti8,
For some reason the last apt-get update/apt-get dist-upgrade removed chromium 50.
Could you clarify what you mean by add dev to the /etc/apt/sources.list so I can dl the v51 beta?
Posted: Sat Jul 09, 2016 7:56 pm
by kusti8
Dis93 wrote:kusti8,
At the end of the line where it says main, add a space and then dev
Edit: But for v50, can't you just sudo apt-get install chromium-browser?
Posted: Sat Jul 09, 2016 8:01 pm
by Dis93
kusti8,
thanks for the clarification.
I still don't have chromium in my raspberry/internet menu :(
Posted: Sat Jul 09, 2016 8:02 pm
by kusti8
Dis93 wrote:kusti8,
What is the output of:
sudo apt-get update
chromium-browser
Posted: Sat Jul 09, 2016 8:06 pm
by Dis93
Thanks kusti8,
the apt-get install chromium-browser reinstalled chromium, v51 due to the addition of dev to the /etc/apt/sources.list
testing now :D
Posted: Sat Jul 09, 2016 8:07 pm
by Dis93
Probably placebo effect, seems snappy :P (posting from v51)
Hoping the lock up issues I was having have been banished.
Posted: Sat Jul 09, 2016 8:08 pm
by kusti8
Dis93 wrote:Probably placebo effect, seems snappy :P (posting from v51)
Good. It seemed to work for me.
Posted: Sun Jul 10, 2016 12:59 am
by cjan
51b, youtube play 360p snap a bit than 49, and it change user setting some where like enable GPU.
