linusmiranda
Home Automation
Sat Aug 01, 2015 5:33 pm
I am working on my home automation project.
I have brought a RPi model A+, 8 channel relay board and a DS1302 Real Time Clock Module. I want to use the RPi and RTC as an timer to control the relay module. ''ON''-''OFF'' each relay at different set time. Similar to the house timer with a single switch but in this case I want to control multiple relays or switches.
1 - How do I connect my RPi to the home network, PC and internet. since I have just 1 usb port to connect.
2 - How do I connect the RTC to my RPi
3 - How do I program the RPi using python.
texy
Re: Home Automation
Sat Aug 01, 2015 6:01 pm
Hi and welcome to the forum.
Some answers here, other may have other options :
By using a USB WIFI dongle
Use the instructions that came with it. You did some research before you purchased, right? If not there are plenty of instructions in this forum, or google.
A good start would be the python sub-forum here :
viewforum.php?f=32
Texy
linusmiranda
Re: Home Automation
Sat Aug 01, 2015 6:14 pm
1 - I am using D-Link model DWA-123. I tried to connect but it shows me not connected. Can you guide me what command should type.
2 - When I received the RTC I didn't get any manual. I brought the model because there were many example on you-tube showing how to set it with Arduino not with RPi. I just want to know what command should I type to set the time and Date.
MattHawkinsUK
Re: Home Automation
Sat Aug 01, 2015 7:27 pm
Did you use the Wifi configuration utility within Raspbian to set the Wifi password? If not try this WiFi configuration tutorial.
I had real trouble with my RTC module (a DS1307). In the end I went for a DS3231 and that was much easier. You are best looking for a Raspberry Pi specific tutorial where someone is using a module that looks the same as yours.
My Raspberry Pi blog and home of the BerryClip Add-on board : http://www.raspberrypi-spy.co.uk/
Follow me on Google+, Facebook, Pinterest and Twitter (@RPiSpy)
TGD
Re: Home Automation
Thu Aug 06, 2015 11:34 am
