Aphire
USB Dongle for speed.
Wed May 27, 2015 3:50 pm
Good day,
I am looking to use my pi2 for a speech recognition project, however I am finding using the wifi adapter I have now (150/Mbps 802.11N from the pi hut) can be a bit slow when uploading recorded speech for recognition (I need free form dictation so offline speech recognition will not be viable)
I am recording at the lowest possible sample rate for the microphone using PyAudio so now I am just looking for pure up/download speed.
Can anyone recommend a good alternative?
Thanks in advance!
Alexon
elatllat
Re: USB Dongle for speed.
Thu May 28, 2015 1:09 am
What's your speed test result:
http://www.dslreports.com/speedtest
Most people are limited by there ISP speed not the local hardware.
Try reducing the bit depth and compressing it with flac.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Aphire
Thu May 28, 2015 7:38 am
Result from speed test is : Speed Test » 25.5/21.68 megabit/second
I am actually already using flac, it was working quite nicely on my desk, I have noticed the results decreasing ever since mounting it on the wall across the room, I wonder if it may have something to do with the range of the adapter? (it is still in the same room as the router though)
