On the subject of power supplies and making the raspberry pi portable. I found this nifty little fellow online.
http://www.duracelldirect.co.uk/pno/pps5h.html
Its a rechargeable Duracell battery with two 5v USB power outputs 1800mah capacity and you can pull a maximum of one amp out. When plugged in the wall it works just like a normal PSU now all I need is a touch screen that runs on 5 volts.
[/img]
I know its £40.00 but its pretty cool and it will work out of the box.
Has anyone else seen some intresting power supplies?
