DCDi
Watchdog for Pi2
Tue Feb 17, 2015 1:34 pm
Are these steps still the same for watchdog on Pi2? Must be wrong....
sudo apt-get install watchdog
sudo modprobe bcm2708_wdog
sudo vi /etc/modules
bcm2708_wdog
sudo update-rc.d watchdog defaults
sudo vi /etc/watchdog.conf
#uncomment the following:
max-load-1
watchdog-device
sudo service watchdog start
I am looking to do a reboot if it locks up... is there a better / easier way?
Thanks in advance.
pluggy
Re: Watchdog for Pi2
Tue Feb 17, 2015 2:10 pm
I often wondered how a software daemon would respond if the Pi actually crashed, because surely the daemon would die with it ?
mimi123
Tue Feb 17, 2015 2:18 pm
DCDi wrote:Hi,
bcm2708_wdog
max-load-1
watchdog-device
Thanks in advance.
It is exactly the same watchdog block.(identical HW-side)
DCDi
Tue Feb 17, 2015 2:36 pm
@ mimi - so that works for you on pi2?
mimi123
Tue Feb 17, 2015 2:51 pm
DCDi wrote:@ mimi - so that works for you on pi2?
I did not run Linux yet.(it works the same bare-metal side)
3corey2
Tue Feb 17, 2015 3:20 pm
it should, it looks right to me.
ras pi 2, gotta love it.
Tue Feb 17, 2015 8:28 pm
pluggy wrote:I often wondered how a software daemon would respond if the Pi actually crashed, because surely the daemon would die with it ?
The software sets up the hardware watchdog, then kicks it every now and then to say it is still alive. If it misses a kick the hardware doggie barks ;)
JayTay79
Tue Feb 17, 2015 8:38 pm
I have watchdog working fine on my Pi 2.
mimi123
Tue Feb 17, 2015 8:51 pm
Curiously, the Pi resets after the Xenon Death Flash if you enabled the watchdog.
electronicsguy
Tue Feb 17, 2015 8:55 pm
Is there a way to test it, by forcing a stall execution on the RPi?
blog: https://electronicsguy.wordpress.com
github: https://github.com/electronicsguy
mimi123
Tue Feb 17, 2015 8:58 pm
Xenon Death Flash is a reliable way.
DISCLAIMER: I'm not responsible if your Pi won't boot anymore
electronicsguy
Thu Feb 19, 2015 7:07 am
haha sure. but a more scientific way for RPi's of the future that may have a better designed chip? any specific command that we can use?
Aydan
Thu Feb 19, 2015 3:46 pm
electronicsguy wrote:haha sure. but a more scientific way for RPi's of the future that may have a better designed chip? any specific command that we can use?
Kill the watchdog daemon and it will stop kicking the watchdog and thus reset the Pi.
Regards
Aydan
rao
Sun Apr 10, 2016 5:52 pm
Hello
I am running a shell script on startup. My program hangs after sometime. Sometimes it hangs after 6-12 hours or sometimes after 2-3 days. But my PI works fine but only the program freezes when I hard reboot the PI the program works fine but as mentioned above only for 6-12 hours or sometimes for 2-3 days. Now kindly me how to setup watchdog for the shell script running on startup.
Regards
Rao Ali
