morphy_richards
Re: Lol- The joking thread
Thu Jun 02, 2016 6:10 pm
I say, I say, I say.
My dog has no nose.
croston
Thu Jun 02, 2016 6:14 pm
morphy_richards wrote:I say, I say, I say.
My dog has no nose.
How does is smell?
Wall-e
Thu Jun 02, 2016 6:26 pm
Knock Knock!
Who's there?
.........java.
Who the heck is Kernel panic and why is he killing my computer!
Thu Jun 02, 2016 6:35 pm
Java who?
ECMAScript 2015.
Thu Jun 02, 2016 6:38 pm
Guy goes to visit his doctor.
Doctor says, "Hello, I haven't seen you for a long time"
Guy says, "No, I've been ill"
Thu Jun 02, 2016 6:42 pm
After a Spitfire flown by a Polish pilot crashed during the Second World War, the crash investigation report concluded:
"The accident was caused by a failure of the control system, a simple pole in the complex plane".
morphy_richards
Thu Jun 02, 2016 7:08 pm
My dog has no nose.
How does it smell?
Terrible!
hippy
Thu Jun 02, 2016 7:51 pm
rurwin wrote:FWIW, I can't see any problem with the last example, but 'fooNaN'? that's crazy. ;)
I guess that's also just operator precedence ... foo' + + foo ... 'foo' + ( + 'foo' ) ... so makes sense as a string concatenated with a number( which isn't really a number ) converted to a string. Entirely logical, consistent and predictable from language definition even if it may seem odd if expecting something else.
Having written a few small compilers; I tend to favour no automatic type promotion, but integer to float usually ends up as an exception to the rule. I would throw an error on anything which created a not-a-number but can see why some find it useful to have that as a unique value.
blaablaaguy
Thu Jun 02, 2016 8:07 pm
rurwin wrote:No comment
I didnt fully believe that untill i tried it in the JS console. O_o
This signature intentionally left blank.
Fri Jun 03, 2016 9:55 pm
bertwert,
World War Eleven?
Yes. We turned it up as far as we could.
https://www.youtube.com/watch?v=KOO5S4vxi0o
Fri Jun 03, 2016 10:07 pm
blaablaaguy,
This is C:
printf("%d\n", 2500000000 + 2500000000);
Produces: 705032704
This is Javascript:
console.log(2500000000 + 2500000000)
Produces: 5000000000
Who is laughing now?
All languages have their weirdness. Especially your spelling above :)
Fri Jun 03, 2016 10:15 pm
Heater wrote:This is C:
Produces: 705032704
and when compiling you will quite rightly get a warning that you have done something stupid
"warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘long int’"
so when you put the correct code in
printf("%ld\n", 2500000000 + 2500000000);
you get the correct result: 5000000000
Yes, you can break most languages if you try hard enough :lol:
blaablaaguy
Fri Jun 03, 2016 10:27 pm
Produces: 705032704
This is too much for my brain to handle. I suppose all that matters is that you can actually use the language.
Fri Jun 03, 2016 10:30 pm
rpdom,
That is true is you if are talking about constants. But:
$ cat junk.c
#include <stdio.h>
int main (int argc, char* argv[])
    int x = 2500000000;
    int y = 2500000000;
    int z  = x + y;
    printf("%d\n", z);
    return (0);
$ gcc -Wall junk.c
$ ./a.out
705032704
FAIL.
I find it amazing that in 2016 programming languages still silently produce totally the wrong result when doing simple arithmetic. It's not just C of course.
Burngate
Sat Jun 04, 2016 9:17 am
Heater wrote:I find it amazing that in 2016 programming languages still silently produce totally the wrong result when doing simple arithmetic. It's not just C of course.
Did it produce the wrong answer, or was it that what you told it to do and what you thought you told it to do were different?
So it's not the computer or the compiler or the language that's at fault, it's you?
@Bertwert: I was going to make some snarky comment about Roman numerals, but then I went to Wikipedia and discovered there's a lot more to the subject than I'd realised!
So thanks for that!
Sat Jun 04, 2016 10:13 am
Burngate wrote: @Bertwert: I was going to make some snarky comment about Roman numerals, but then I went to Wikipedia and discovered there's a lot more to the subject than I'd realised!
So thanks for that!
Sixteen years ago a friend of mine gave me a REXX program to convert Arabic numbers to Roman numerals and Roman numerals back to Arabic numbers. I re-wrote that code in JavaScript and published it, it's still out there, it's still 100% pointless.
http://www.javascriptsource.com/page-de ... erals.html is one half, don't know if I've got the other half. (It's probably sitting on a hard disk somewhere.)
This is a doctor free zone.
Sat Jun 04, 2016 10:14 am
Burngate,
Did it produce the wrong answer, or was it that what you told it to do and what you thought you told it to do were different? So it's not the computer or the compiler or the language that's at fault, it's you?
That is an oft stated opinion about such programming mistakes.
If we carry that train of thought to the extreme then we could ask:
Why does the compiler issue any syntax or other errors, it should just compile whatever you give it as best it can. If you have it wrong it's your fault.
Why have exceptions for divide by zero, or out of bounds memory access. Just return random numbers like numeric overflow does. If you have it wrong it's your fault.
And so on.
I'm not about to suggest that C be changed to do this. That would hurt performance. If we really want such checks we can use Ada.
The core of the problem is that CPU's don't offer any help in this matter.
Sat Jun 04, 2016 10:29 am
Heater wrote: The core of the problem is that CPU's don't offer any help in this matter.
That's because the hardware makers still haven't introduced the DWIM instruction to fully enable that type of fuzzy logic.
DWIM - Do What I Mean
Sat Jun 04, 2016 10:48 am
Fuzzy Logic?
Are suggesting the random number generator we have now is better?
Did you mean the DIMWIT instruction?
I'm all up for that idea.
Sat Jun 04, 2016 11:32 am
Heater wrote:Fuzzy Logic?
The DIMWIT instruction is already in hardware and used everyday by the folks who can't survive without being assimilated into the Faceborg.
The DWIM (do what I mean) will revolutionise computing, we'll be able to stop blaming all of those bugs on moths dying on our circuit boards.
rurwin
Sat Jun 04, 2016 4:56 pm
Heater wrote:The core of the problem is that CPU's don't offer any help in this matter.
Unless the ARM is highly unusual, the CPU will correctly raise the overflow flag. It may even attempt to signal an exception. If the user's code doesn't check the former and disables the latter, it isn't the CPU's fault.
C was designed to be fast and to allow all sorts of messing about that a decent language would object to, because those are the sorts of things you have to do when you are talking to hardware and wringing every last bit of performance out. The languages about at the same time C was developed -- Pascal, Basic, Fortran, Algol, Cobol, Ada, Coral, Modula, etc., etc. -- were developed for higher-level purposes and do indeed check for overflow and array bounds and all the other stuff that C doesn't do. Even Lisp silently upgrades an integer to long if required, just like Javascript. Unfortunately C took over the world and not only is it being used for projects that should be using a more defensive language, but its laissez faire attitude has become the new normal.
Sat Jun 04, 2016 7:10 pm
rurwin wrote:
Heater wrote:The languages about at the same time C was developed -- Pascal, Basic, Fortran, Algol, Cobol, Ada, Coral, Modula, etc., etc. -- were developed for higher-level purposes and do indeed check for overflow and array bounds and all the other stuff that C doesn't do.
One of the main problems I remember when I was using COBOL-74 was that it didn't check things like array bounds or anything like that.
The majority of problems that I had to diagnose for people was where data had been written past the end of an array (OCCURS) and overwritten other variables with all sorts of invalid values.
timrowledge
Sat Jun 04, 2016 8:07 pm
Y'have to remember that C is just a lot of complex wrapping around a PDP-8 assembler. It isn't *meant* to do much to help you with problems like bounds checking etc. It *is* meant to help you plunder and pillage memory.
The ontological mistake with C++ is the attempt to provide very high level concepts such as object oriented programming *without* stopping the utterly antithetical plunder-and-pillage. Crazy.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Sun Jun 05, 2016 2:39 pm
rpdom wrote: One of the main problems I remember when I was using COBOL-74 was that it didn't check things like array bounds or anything like that.
Which is why COBOL-92 includes SSRANGE - subscript range checking.
Wall-e
Tue Jun 07, 2016 8:01 pm
ARM Processor...
Return to “Off topic discussion”
