trigu75
Stremio on RPI (Finally , kind of .. )
Fri Dec 07, 2018 3:06 am
I'm new to RPI , but after some tweaks I kind of made it work
I tried to compile it , but there is a missing module and for some reason apt-get doesn't find it as well ..
as for their website
" If you find: Project ERROR: Unknown module(s) in QT: webengine
Then install:
sudo apt-get install libkf5webengineviewer-dev "
libkf5webengineviewer-dev is not found on RPI repository ... so ... this is what I did
you need to have node.js installed
1. download Stremio engine/cast server
wget https://dl.strem.io/four/v4.4.10/server.js ; wget https://dl.strem.io/four/v4.4.10/stremio.asar
once we have these files , we need to do a small tweak to make it work with omxplayer (full gpu acceleration)
edit the downloaded file server.js , and search for MPV (caps)
it will look like this
mpv: {
            title: "MPV",
            args: ['--no-terminal'],
            subArg: '--sub-file=', // DOESN'T WORK ON MAC
            timeArg: '--start ',
            playArg: '',
            darwin: {
                path: ["/usr/local/bin/mpv", "/opt/local/bin/mpv", "/sw/bin/mpv"] // Homebrew, MacPort, Fink
            linux: {
                path: ["/usr/bin/mpv"]
            win32: {
                path: []
add this after that and save
omx: {
          title: "OMX",
          args: [''],
          subArg: '', // DOESN'T WORK ON MAC
          timeArg: '',
          playArg: '',
          darwin: {
          linux: {
              path: ["/usr/bin/omxplayer"]
          win32: {
              path: []
that's it , open a terminal window , execute node server.js , if everything is ok you will get
pi@raspberrypi:~ $ node server.js
hls executables located -> { ffmpeg: '/usr/bin/ffmpeg', ffsplit: null }
Using app path -> /home/pi/.stremio-server
Enabling casting...
Discovery of new external device "vlc" - VLC
Discovery of new external device "omx" - OMX
EngineFS server started at http://127.0.0.1:11470
EngineFS HTTPS endpoint at https://local.strem.io:12470
open the web browser and go to app.strem.io , login (to get your saved addons and library) , or go straight to addons and install the addons you use
select a video from the library , once it starts playing (with no GPU acceleration , WHY CANT WE SET AN EXTERNAL PLAYER FOR THE BROWSER ????????????????? ) , right click , choose play in OMX , and that's it , the browser will stop playing , OMXplayer will start playing the stream (while stremio engine continues to download)
I will keep looking if I can make an RPI version ... let me know what you think
trigu75
Re: Stremio on RPI (Finally , kind of .. )
Fri Dec 07, 2018 11:41 pm
OK
I managed to find all the packages needed to compile it , and succesfully created their Client
and it works , but still needs some tweaking to be perfect (add omxplayer to the main binary)
maybe someone here can step in and help?
I will keep you updated
screenshot attached
stremio on RPI3
Return to “Off topic discussion”
