redhawk
Circuit design software??
Mon Sep 10, 2012 9:24 pm
Can anyone recommend a Windows freeware tool for drawing electronic schematics?? I need symbols for both analog and digital, simulation would be nice but not necessary.
Richard S.
jackokring
Contact: ICQ
Re: Circuit design software??
Mon Sep 10, 2012 10:06 pm
I assume you mean schematic layout tool. If so try Eagle free version. There is no simulation. Finding free simulation tools is more difficult if you require graphical input. Design software implies some of the design is performed by the computer.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
pygmy_giant
Mon Sep 10, 2012 10:11 pm
I use 'Ideal Circuit' on my windows PC - its simple and free.
Ostendo ignarus addo scientia.
TonyD
Tue Sep 11, 2012 12:16 pm
Have a look at DesignSpark PCB, it has schematic capture and PCB layout and this some simulation software. It's free just need to register with a email address.
I used it to design quite a few add-on boards for the RPi and Arduino, check my blog
http://zuzebox.wordpress.com/
Tony
meltwater
Wed Sep 12, 2012 8:04 am
Been searching for that perfect FREE software too, here are some which i have tried (images taken from the source websites):
Online Design and simulation - Circuit Lab
https://www.circuitlab.com/
Not bad for drawing some circuits out, but never quite worked out easy way to run the simulation side of it. Shame, has great potential.
Yenka (the result of the OLD-SCHOOL Croc-Clips)
http://www.yenka.com/
An excellent program, with excellent simulation, although has a very annoying timed free licence so that you can't use it during the day (there may be ways to resolve this, but extra hassle).
Fritzing
http://fritzing.org/
A nice looking program for schematics, breadboard and pcb designs. My main issue with it is that the side view of components (designed to make it easy to see what it is) makes it hard to design compact layouts. Also the stripboard layout (which was my main need) support is limited (track cuts are between holes only, and side view of components make it difficult). The schematics, breadboard and pcb are even linked, so that you can confirm that connections are matching (can be difficult to confirm it is correct though, may be bugs in that aspect). Editing components is also difficult but they are clearly working on that, hopefully they will bring in a top-down view for designing - option to use PCB component view on the layout). Has massive potential, but just doesn't quite work YET.
Stripboard layouts - VeeCAD
http://veecad.com/
This basic looking program in fact is one I like the most... It's main use is for laying out components on stripboards, which is essentially all it does. However, it is simple (once you get used to it - creating components manually and then laying them out) and allows you to layout stripboards and play with the design.
It does support importing of netlists, which is a standard output of a circuit designer such as Sparkfun - although I've not tried this so I don't know how much is available for the free version (details to try this here). So far all the circuits I've done I've just used it for layout and traced through in my head (still easier than using paper, but anything complicated is sure to make your head hurt!).
Android App - EveryCircuitFree
https://play.google.com/store/apps/deta ... free&hl=en
I like this app a lot but unfortunately the free version is VERY limited (you get tiny prototype area) and the full app is expensive for a phone app (although it may be worth it perhaps, since it seems to be quite extensive). In fact, having another try with it, it is superb for basic level stuff, could do with some IC support though.
______________
http://www.themagpi.com/
A Magazine for Raspberry Pi Users
Read Online or Download for Free.
My new book: goo.gl/dmVtsc
Meltwater's Pi Hardware - pihardware.com
Like the MagPi? @TheMagP1 @TheMagPiTeam
tufty
Sat Sep 15, 2012 8:17 pm
Everycircuit is an android packaging of the open source falstad.com circuit sim tool.
meltwater
Mon Sep 17, 2012 7:31 am
tufty wrote:Everycircuit is an android packaging of the open source falstad.com circuit sim tool.
I didn't know that!
http://www.falstad.com/circuit/
The java applet is quite useful on it's own cheers.
______________
Neil
Tue Sep 25, 2012 8:23 am
I've put together a list of free CAD software here:
http://www.milton.arachsys.com/nj71/ind ... &submenu=7
Neil
mahjongg
Tue Sep 25, 2012 8:32 am
Wikipedia has an extensive list of electronic design aids.
http://en.wikipedia.org/wiki/Comparison_of_EDA_Software
dbagchi
Thu Oct 04, 2012 1:31 pm
I found another cool one at http://www.DoCircuits.com. This has real looking components and devices.
tufty
Thu Oct 04, 2012 4:28 pm
I didn't know that!
The source for the Java app is available as well, so if you need to model (for example) oscillators built using schmitt trigger inverters, you can add them yourself.
redhawk
Fri Oct 19, 2012 1:10 pm
Thank you everyone who commented on circuit building software I never knew so many existed.
At the moment I've settled for Electronic Workbench it's a little old and lacks some symbols but it's by far the easiest tool to build with.
My only misgivings so far are the massive blobs as wire links and the inability to add new symbols to the parts list like a loud speaker.
In any case I could always improvise with photoshop / gimp missing so it's no skin off my nose :)
One of my reasons for acquiring circuit drawing software is that in time I would like to publish some of my work without relying on hand drawn diagrams.
This leads me to another query, could anyone recommend some good web sites for publishing circuits??
So far http://electroschematics.com/ looks promising but it’s unclear if registered users are only allow permitted to post comments or allowed to publish circuits diagrams as well??
Richard S.
electroschematics
Sat Feb 09, 2013 9:10 am
@redhawk - electroschematics.com accepts schematics submission.and is also looking for contributors to write article related to Raspberry Pi. You can use the contact form to get in touch with the administrator. Thank you.
klricks
Sat Feb 09, 2013 2:16 pm
For schematic drawing I have used Dia. Sort of a Visio clone. Has support for custom symbols and a repository for symbols where you can download more symbol libraries.
https://live.gnome.org/Dia
For circuit simulation I use Solve Elec
Works pretty good once you get used to the finicky drawing and parts placement scheme.
(analog only no digital)
- Does AC or DC circuit analysis and shows equations.
- Can add volt and ammeters anywhere in the circuit and make plots.
- Oscilloscope, transfer functions etc.
http://www.physicsbox.com/indexsolveelec2en.html
linuxgnuru
Thu Dec 04, 2014 12:58 pm
I realize it's been over a year since anyone posted to this; but anyway, I've found gEDA (https://packages.debian.org/stable/electronics/geda) and I'm going to give it a try.
Tage
Fri Dec 05, 2014 2:04 am
LTSpice
ame
Fri Dec 05, 2014 8:02 am
KiCAD :roll:
Fri Dec 05, 2014 8:53 am
LibreCAD :roll:
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
ame
Fri Dec 05, 2014 8:37 pm
fruitoftheloom wrote:LibreCAD :roll:
We were talking about circuit design, but thanks for trying.
mahjongg
Fri Dec 05, 2014 8:50 pm
Altium is one of the best (some say the best) circuit design CAD programs for professionals, but it requires very large license fee's, only affordable for companies.
The makers of Altium now have brought out a free design CAD program with similar features as Altium, but only for "open designs", it is called circuit maker, its still in development, but you can express interest in it here:
http://circuitmaker.com/#why_circuitmaker
Jednorozec
Mon Dec 08, 2014 1:29 am
CircuitMaker is in closed beta.
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
mahjongg
Thu Dec 11, 2014 12:16 am
thats why i said it is still in development, if it comes out of beta it will be available for everybody.
I've signed up for the beta btw.
billw
Mon Feb 23, 2015 10:32 pm
Just a note about circuit design software running on a Pi 2. I've got gschem and pcb from the gEDA project working on my Pi 2. For gschem working means it's usable as long as the circuit design density is not too great. If you zoom out on a dense schematic, it bogs down. The pcb from the repository uses gl and is too slow to tolerate, but I compiled a pcb binary without gl support and that is happily working very well. I'm now looking forward to a warm day when I can work on my next pcb layout outside on the patio with my Pi 2 attached to an Atrix lapdock.
blc
Tue Feb 24, 2015 8:45 am
This was already suggested, but KiCad is getting a lot of attention these days. From what I understand, the foundation has also contributed funding to KiCad development.
iinnovations
Tue Feb 24, 2015 8:55 am
I use EasyEDA. Totally web-based, which is nice. There is simulation, but I don't use it. Very easy to make parts, which I also like.
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Return to “Off topic discussion”
