in3vrr
fail2ban & VNC - it works ?
Sun Nov 20, 2016 2:15 pm
I would check the VNC access with fail2ban as well as I did for SSH .... is it possible ?
Is it okay to add these lines in jail.local after [ssh] jail ?
[vnc]
enabled = true
vnc port = 5900
filter = vnc
logpath = /var/log/auth.log
maxretry = 3
filter = vnc ?
VNC also uses /var/log/auth.log ?
Suggestions?
Thank you
regards
Bob
topguy
Re: fail2ban & VNC - it works ?
Sun Nov 20, 2016 2:48 pm
I would suggest that you disable VNC from external connections and use ssh tunneling.
https://www.theurbanpenguin.com/creatin ... ecure-vnc/
in3vrr
Sun Nov 20, 2016 4:45 pm
topguy wrote:I would suggest that you disable VNC from external connections and use ssh tunneling.
Thanks for the great advice!
It works perfectly.
Done !
Regards
Bob
Return to “Off topic discussion”
