Installing Ubuntu-Mate to Raspberry Pi 1
Posted: Wed Nov 28, 2018 5:36 am
by Azmath.Verticross
Hi!
Can anyone help me installing Ubuntu-Mate on my RBPi 1, I'm trying to install it but I'm stuck with start up page.
Please help out in this
Re: Installing Ubuntu-Mate to Raspberry Pi 1
Posted: Wed Nov 28, 2018 10:36 am
by DirkS
AFAIK Mate needs a 2B or later.
Posted: Wed Nov 28, 2018 2:55 pm
by Fidelius
[Edit: Yes indeed.]
The Ubuntu Mate flavour also bundles a ready-to-run image for the Pi, using Raspbian's kernel plus some driver and Ubuntu's normal 32-Bit ARM7 packages from the Ubuntu server.
https://ubuntu-mate.org/raspberry-pi/
Posted: Wed Nov 28, 2018 2:57 pm
by Fidelius
Ubuntu compiles their 32-Bit ARM packages against ARM7, so it won't run on a Pi1 with ARM6.
At least you need a Pi2 with ARM7 or a Pi3 with ARM8 to run ARM Ubuntu.
P.S. And you won't have the OpenGL driver and other Raspbian-only bits, like hardware accelerated VLC, etc.
Since Debian based Raspbian (Stretch) and Debian based Ubuntu is very similar, I'd recommend to use Raspbian which runs much more smoothly and then just apt-install the Mate or Xfce desktop packages from Raspbian's apt-repository.
Posted: Wed Nov 28, 2018 3:05 pm
by DirkS
No. Ubuntu Mate and Xfce etc run happily on a Pi2 or Pi3 with 1 GB RAM.
What do you mean with 'No' ? :?
That's exactly what I'm saying. There is no 2 without a B
Posted: Wed Nov 28, 2018 3:23 pm
by Fidelius
You're right; I read "2G" (RAM) instead of your 2B.
Posted: Wed Nov 28, 2018 3:24 pm
by fruitoftheloom
Hi!
Ubuntu various flavours requires a ARMv7 / ARMv8 Raspberry Pi SBC.
The Raspberry Pi Zero and 1 family are ARMv6 so are not supported.
Best to stick with Raspbian Stretch with Desktop or Arch Linux Arm which is command line only but you can install the Mate Desktop.
Posted: Wed Nov 28, 2018 4:00 pm
by code_exec
Hi!
Sorry, but Ubuntu armhf requires ARMv7 or later, the Pi 1 and Zero use ARMv6 which are not supported by Ubuntu. There used to be an Ubuntu armel port for ARMv5 which could have actually been run on the Pi 1 using a custom kernel compiled with armel support, but 12.10 was the last version that included armel support.
Posted: Thu Dec 13, 2018 7:15 am
Hi!
Thank you sir,
can share that ubuntu armel port link or file with me i would like to check it.
Posted: Sat Dec 29, 2018 6:35 am
by code_exec
Hi!
Thank you sir,
Sorry for the late reply, I only just saw this.
Ubuntu's armel port was dropped at 13.04 and the latest LTS version available for this port was 12.04, which reached End of Life in April 2017.
Also, Ubuntu armel would use emulation for floating point applications which would be slow.
You would need to compile the Pi's kernel with support for running old ARM EABI binaries.
Posted: Tue Jan 08, 2019 7:07 am
by code_exec
Both Ubuntu and Raspbian are based on Debian, and therefore are like each other in many ways. Try installing Raspbian Lite and then installing the mate-desktop-environment package. This will give you an Ubuntu MATE-like experience on your Pi 1.
