T22512
PLEASE HELP ME with KALI
Tue Sep 11, 2018 8:57 pm
I just installed kali on my rasp3
but now how much to install something only appears this to me:
Setting up raspi3-firmware (1.20180619-1) ...
Error: missing /boot/firmware, did you forget to mount it?
dpkg: error processing package raspi3-firmware (--configure):
installed raspi3-firmware package post-installation script subprocess
returned error exit status 1
raspi3-firmware
klricks
Re: PLEASE HELP ME
Tue Sep 11, 2018 11:08 pm
There is very little if any support here for Kali.
Try asking at the Kali web site / forums: https://www.kali.org/
W. H. Heydt
Re: PLEASE HELP ME
Tue Sep 11, 2018 11:39 pm
As I understand it, Kali Linux is intended for security experts and researchers. It assumes considerable expertise with Linux and doesn't do "hand holding". All I can suggest if you are having difficulties with it is to pick a distribution designed to be easier for beginners, such as Raspbian, until you have an in depth familiarity and comfort level with Linux before you try using Kali again.
In the mean time, two minor suggestions. First, do not use all caps subject lines (it makes it look like you are shouting at people). Second, in your subject line, give some indication of what your actual problem is. "Please help" does not really convey anything and many knowledgeable people will never read the post.
Return to “Other”
