xxxxxxyxxx
[Go Ethereum - Geth] Unable to apt-get update and install packages (404)
Thu Jun 07, 2018 7:05 pm
Hey, how are you guys?
I recently started running an Ethereum node (Geth) on a Raspberry Pi 2 following the tutorials provided by Ethembedded.com.
They provide a Raspi2/3 Geth (Go Ethereum) 1.4.10 image. It's an adapted version of Ubuntu Mate and runs fine. I can run the node, interact with it, create accounts, send transactions, etc. Works fine.
But I am experiencing an error everytime I try to apt-get update or install new packages, such as Node.js or Npm. When I try to apt-get update it will wait a long time for headers and in the end it shows me a lot of 404 errors, so I'm unable to update. When I try to install node or npm, it will suggest me to run apt-get update --fix-missing, but the command line returns the same 404 errors, failing to fetch. What am I doing wrong?
There is an old topic about this here in the forum, but I couldn't find a solution there. viewtopic.php?t=18246
Would someone here be able to quickly help me solving this problem?
Best,
bob_binz
Re: Unable to apt-get update and install packages (404)
Thu Jun 07, 2018 8:21 pm
With this being a custom image, you're likely to get more relevant assistance on their forum (if they have one).
However, what are the contents of your apt sources file? e.g.
cat /etc/apt/sources.list
BBz
xxxxxxyxxx
Thu Jun 07, 2018 9:08 pm
Hey Bob, how are you? I've posted on the Ethereum Stack Exchange as well, but I don't think there are many people out there running nodes on Rpis. Not a lot of information about this error, at least.
The contents of apt-source:
deb http://ports.ubuntu.com/ wily main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-updates main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-security main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-security main restricted universe multiverse
deb http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
deb-src http://ports.ubuntu.com/ wily-backports main restricted universe multiverse
buteman
Thu Jun 07, 2018 9:09 pm
It may be irrelevant but are you running
apt-get update
or
sudo apt-get update
There are few rewards greater than accomplishing a difficult task. Just because something doesn't cost money doesn't mean there is no cost. Every success makes the next one easier. Of course that takes determination and patience.
xxxxxxyxxx
Thu Jun 07, 2018 9:18 pm
sudo apt-get update
feelslikeautumn
Sat Jun 09, 2018 12:01 pm
Wily (15.10) is not supported any more. That is why you are getting 404 errors.
Return to “Other”
