Ubuntu Mate booting problem
Posted: Tue Apr 03, 2018 8:41 am
by KlSchlitzohr
I'm tried to install Ubuntu mate to my Raspberry Pi 3b+.
I put the SD Crad into the raspberry Pi if I'm booting I'm get an rainbow screen.
I search a long time but I didn't found an fix.
Sry for my bad englich
Thanks for Helping
Re: Ubuntu Mate booting problem
Posted: Tue Apr 03, 2018 9:39 am
by Crazyhead
viewtopic.php?f=63&t=208538
I guess you didnt search long enough
Posted: Tue Apr 03, 2018 5:48 pm
by fruitoftheloom
Thanks for Helping
5 pages......
Posted: Tue Apr 03, 2018 5:53 pm
by KlSchlitzohr
Thats really great 5 pages
And I'm not really good in englich.
I'll will try to understand it.
It should be nice if somebody can wirite a short easy summery
Posted: Tue Apr 03, 2018 5:57 pm
by B.Goode
The version of Ubuntu Mate that can be downloaded from https://ubuntu-mate.org/raspberry-pi/ is not compatible with your RPi Model 3B+.
Posted: Tue Apr 03, 2018 6:21 pm
by MaxVMH
If you can't figure out how to do it, I made images of Ubuntu Mate ready for Raspberry Pi 3B+
Here are the torrents:
Posted: Tue Apr 03, 2018 6:59 pm
by KlSchlitzohr
I have no torrent client
Posted: Fri Apr 06, 2018 8:11 am
by KlSchlitzohr
Let me know if you don't have a torrent client, then I'll send you the direct download links in a personal message.
It worked
Posted: Tue Aug 21, 2018 12:30 pm
by Ausberry
@MaxVMH Thank you for posting your Ubuntu disc image. Can I ask why it's so large? Over 7 GB? Just curious what I would be installing. I too want Ubuntu on a Pi 3 B+. Cheers!
Posted: Mon Sep 03, 2018 10:14 pm
by MaxVMH
That's the size of the flash drive I used to make the image, I didn't shrink the image afterwards - so it's basically 4GB 'space' on top of Ubuntu Mate, nothing to be worried about ;)
Consider dropping a note on the Ubuntu MATE forums for official support - that way they know there's demand 8-)
Posted: Thu Sep 06, 2018 11:39 am
by dodoms
Hey mate, can you send a direct download link?
Posted: Thu Sep 06, 2018 12:17 pm
by fruitoftheloom
You what ? just click on the text highlighted in red :roll:
Posted: Sun Sep 09, 2018 3:22 pm
by Koia
I downloaded your SD care file for 3B+ from the torrent link above. It loads fine on a 3B card but not on my 3B+.
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004 ... on first line.
Later:Hardware name BCM2708
Any help?
Posted: Wed Sep 19, 2018 4:49 pm
by KlSchlitzohr
Hello
I had no problems With this download.
All worked
I have No Idear
Posted: Tue Nov 06, 2018 4:45 am
by soe ye htet
Hello So sorry. I cannot download from utorrent file. If it is possible, i want to get direct link from personal message.
Posted: Fri Nov 09, 2018 6:08 pm
by MaxVMH
The torrent should still work but I stopped hosting the files. Ubuntu Mate 18.04 and 18.10 were released and I feel it would be of more use to the overall community if people asked for images on their forums or contributed to an official release instead of relying on old hacked together images of a distro that is over 2 years old.
https://ubuntu-mate.community
Alternatively, you can try making your own image based on Ubuntu Mate 16.04:
Copy the following files from Raspbian to Ubuntu Mate:
For Booting: copy bootcode.bin, fixup.dat, fixup_x.dat , start.elf, start_x.elf, bcm2710-rpi-3-b-plus.dtb and kernel7.img
For keyboard/mouse: copy /lib/modules/4.9.80-v7+ (root partition)
For network: copy the contents of /lib/firmware/brcm/ (root partition)
If you want to boot from USB:
edit cmdline.txt, change root=/dev/mmcblk0p2 to root=/dev/sda2 (boot partition)
edit etc/fstab, change/dev/mmcblk0p2 to sda2 and /dev/mmcblk0p1 to sda1 (root partition)
Bonus
After your first boot, enable wifi:
sudo rfkill unblock wifi
And then reboot:
sudo reboot
More information: viewtopic.php?f=56&t=208538
Upgrade Ubuntu Mate 16.04 to Ubuntu Mate 18.04: viewtopic.php?f=56&t=223749&p=1371614
Posted: Sun Nov 11, 2018 10:06 am
by code_exec
I found this guide on the Ubuntu MATE forums:
https://ubuntu-mate.community/t/adaptin ... model-b-3b
